    Apache Log4j Update
HP Color LaserJet Enterprise M651 and HP Color LaserJet Enterprise MFP M680 Printers - 10.31.70 Message
Issue:
A 10.31.70 Replace Toner Collection Unit alert message is displayed on the control panel when the toner collection unit (TCU) is full and needs to be replaced.
The TCU is a toner collection unit housed within the printer that collects paper debris and un-transferred toner generated during the operation of the printer. The TCU is an easy-to-replace, high-yield HP supply designed to reduce user intervention rates. The printer control panel will provide a proactive alert when the TCU is approaching the end of life and you need to order a replacement. The alert provides the product number to order for replacement.
You must replace the TCU when the alert 10.31.70 Replace Toner Collection Unit is displayed on the control panel. If printing continues after the Replace alert, the printer displays a 59.00.B0 error message on the printer’s control panel, and stops printing until the TCU is replaced to prevent damage to the printer.
Solution
To order the TCU (CE265A), go to HP SureSupply.
