Document ID: c04561073
Version: 1
HP EliteDisplay S140u LED Backlit Monitor - Magnets in the Protective Cover and the Display Back Cover Could Damage Hard Disk Drive or Other Magnetic-Sensitive Objects
Release date : 30-Jan-2015
Last updated : 30-Jan-2015
DESCRIPTION
Magnets in the HP EliteDisplay S140u protective cover and display back cover have the potential to damage hard disk drives and other objects that are sensitive to magnetic fields. Some potential issues include
  • Notebook computer hard disk drive failures occur (does not affect solid state drives)
    - In case of hard drive failure, data may be unrecoverable
  • Notebook computer display switches off (as if the notebook lid were closed)
The issues can occur if a notebook computer, while powered on (even in stand by), is stacked together with the display or if placed in a carrying case with the display.
Figure 1: examples of stacking that could cause the problem (if the computer is powered on)
SCOPE
Monitor:
Computers:
Any notebook or tablet computer that has a mechanical hard disk drive (not solid state drive)
RESOLUTION
Observe the following precautions to avoid possible issues:
  1. Power the computer off before placing it into a carrying case with the monitor.
  2. Do not place the monitor on top or underneath a computer while the computer is powered on, either in active or sleep state. This could damage the running hard disk drive, or influence the notebook lid sensor causing it to switch the display off.
CAUTION! Simply closing the cover does not power off the computer. You must shut down the computer to be safe.
If your notebook computer experiences hard disk drive issues after being stacked together with the monitor in the SCOPE, be sure to mention this when contacting HP for assistance.
Hardware platforms affected : HP EliteDisplay S140u 14-inch USB Portable Monitor, HP Notebook PCs
Support Communication Cross Reference ID : IA04561073
