HP and Compaq Desktop PCs - motherboard specifications, ColtC
Figure : The ColtC motherboard
Motherboard description
Manufacturer's name: Pegatron
HP/Compaq name: ColtC
Form factor
Form factor: custom
Dimensions: 13.1 cm (5.2 in) x 11.9 cm (4.7 in)
The chipset on this motherboard is combined with the processor into a single integrated circuit called System on a Chip (SoC). This technology combines the processor and chipset functionality into a single physical package.
Processor information
Intel Haswell-U or Broadwell-U processor soldered down on the motherboard
TDP: 15 W
Socket type: Not applicable
Memory upgrade information
Dual channel memory architecture
Two DDR3 DIMM sockets
Supports DDR3 DIMMs
PC3-12800 (1600 MHz)
Supports up to 4 GB on 32-bit* systems
* - 32-bit systems cannot address a full 4.0 GB of memory
Video
Intel integrated graphics
Integrated video is not available if a graphics card is installed
Integrated graphics: Intel HD Graphics
Graphics vary by installed SoC
HDMI and DisplayPort output ports
Audio
Integrated ALC3228-CG audio
Integrated audio is not available if a sound card is installed.
Some features of the tool may not be available at this time. We apologize for this inconvenience and are addressing the issue.Minimize Chat bot windowLoading ChatbotNew Message
