HP Elitebook 720 G2 Notebook PC - Specifications
Physical specifications
Feature
Dimensions (w x d x h)
  • Touch: 31 x 21.53 x 2.46 cm (12.2 x 8.48 x 0.97 in)
  • Non-touch: 31 x 21.53 x 2.1 cm (12.2 x 8.48 x 0.83 in)
Weights
  • Touch: Starting at 1.52 kg (3.35 lbs)
  • Non-touch: Starting at 1.36 kg (2.94 lbs)
Weight will vary by configuration.
Ports
Ports
  • DisplayPort 1.2: One
  • USB 3.0 Charging Port: One
  • USB 3.0 Port: Two
  • RJ-45 (Ethernet): One
  • Side Docking connector: One
  • Headphone/Microphone Combo: One
  • AC Port: One
  • Media Card Reader
  • Supports SD, SDHC, SDXC
System
Specification
Stand-alone power requirements (AC power)
Nominal operating: 19.5 V
Average operating power
  • Windows 7 (64-bit)
    • Integrated graphics: 4.75 W
  • Windows 8.1 (64-bit)
    • Integrated graphics: 4.26 W
Max operating power:
  • Discrete: < 90 W
  • UMA: < 65W
Temperature
  • Operating:
    • Not writing optical): 0° to 35° C (32° to 95° F)
    • Writing optical: 5° to 35° C (41° to 95° F)
  • Non-operating: -20° to 60° C (-4° to 140° F)
Relative humidity
  • Operating: 10% to 90%, non-condensing
  • Non-operating: 5% to 95%, 38.7° C (101.6° F) maximum wet bulb temperature
Shock
  • Operating: 40 G, 2 ms, half-sine
  • Non-operating: 200 G, 2 ms, half-sine
Random vibration
  • Operating: 0.75 g
  • Non-operating: 1.50 g
Altitude (unpressurized)
  • Operating: -15.24 to 3,048 m (-50 to 10,000 ft)
  • Non-operating: -15.24 to 12,192 m (-50 to 40,000 ft)
Planned industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC compliance: Yes
  • ENERGY STAR: Select models*
  • EPEAT: Registered Gold in United States**
  • ICES: Yes
  • Australia/NZ A-Tick compliance: Yes
  • CCC: Yes
  • Japan VCCI compliance: Yes
  • KC: Yes
  • BSMI: Yes
  • CE Marking compliance: Yes
  • BNCI or BELUS: Yes
  • CIT: Yes
  • GOST: Yes
  • Saudi Arabian compliance (ICCP): Yes
  • SABS: Yes
  • UKRSERTCOMPUTER: Yes
For accessibility information on HP products, please visit: http://www.hp.com/accessibility.
HDD
Security
Networking / Communications
For storage drives, GB = 1 billion bytes. TN = 1 trillion bytes. Actual formatted capacity is less. Upt o 16Gb (for Windows 7) and up to 30GB (for Windows 8) of system disk is reserved for system recovery software.
Audio/Multimedia - DTS sound
Implementation: ALC3228
Function key volume controls: Volume up, volume down, and mute
Full duplex: Yes
Microphone in: Stereo
Headphone/line out: Stereo
Integrated microphone: Yes, dual digital microphone array
Audio output quality
Frequency response: 20 Hz – 20 kHz
Signal to noise ratio: > 85 dB
Total harmonic distortion: 0.01%
Noise Floor: –110 dB
Play/Record sampling rate(s): 8 kHz – 48kHz
DAC: 16, 20 or 24-bit
ADC: 16 or 20-bit
Internal stereo speakers
Power rating: 2 W
Impedance: 4 Ohms
Power
