    Fix Windows 10 Update Issues
HP 350 G2 Notebook PC Specifications
Product image
Product features
Feature
Chipset is integrated with processor
Processors
Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. 64-bit computing on Intel architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers, and applications enabled for Intel 64 architecture. Processors will not operate (including 32-bit operation) without an Intel 64 architecture-enabled BIOS. Performance will vary depending on your hardware and software configurations. Intel's numbering is not a measurement of higher performance.
Graphics
Integrated
  • Integrated UMA Graphics
Switchable Discrete Graphics
  • AMD Radeo R5 M240
  • 2G DDR3 with up to 2 GB of dedicated video memory
  • Internal
    15.6-inch diagonal LED-backlit HD* anti-glare (1366 x 768)
  • External
    Up to 32-bit per pixel color depth
  • VGA
    Port supports resolutions up to 1080p, 1920 x 1080 at 60Hz
  • HDMI**
    1.4 port supports up to 1080p, 1920 x 1080 at 60Hz
* HD content required to view HD images.
**HDMI cable sold separately.
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Storage and drives
Hard drives
Support all 7mm/9.5mm, SATA 2.5-inch HDDs
Support for mSATA
Support Intel Smart Response Technology
Accelerometer / HDD protection support
  • 320 GB 5400 rpm SATA
  • 500 GB 5400 rpm SATA
  • 750 GB 5400 rpm SATA
  • 1 TB 5400 rpm SATA
  • 500 GB 7200 rpm SATA
Flash cache
32 GB mSATA*
* Not available with Celeron/Pentium/i3 CPUs.
Optical drives
  • Fixed optical drive
    DVD+/-RW SuperMulti DL* Drive
    Weight saver
* Double-layer discs can store more data than single layer discs. However, double-layer discs burned with this drive may not be compatible with many existing single-layer DVD drives and players. Note that this drive cannot read or write to 2.6 GB single-sided/5.2 GB double-sided – version 1.0 media. Don’t copy copy-right protected materials.
Memory
  • Standard
    DDR3L SDRAM (1600 MHz)
    Two SODIMM slots supporting dual-channel memory
    2048 MB Total System Memory
    4096 MB Total System Memory
    6144 MB Total System Memory
    8192 MB Total System Memory
    16348 MB Total System Memory
  • Maximum
    Upgradeable to 16384 MB with 8192 MB* SODIMMs in slots 1 and 2
  • Dual-channel
    Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed.
* Maximum memory capacities assume Windows 64-bit operating systems or Linux. With Windows 32-bit operating systems, memory above 3 GB may not all be available due to system resource requirements.
Networking/Communications
Wireless
  • 802.11 b/g/n (1x1) wireless LAN module1,2
  • 802.11 b/g/n (1x1) + Bluetooth 4.0 Combo1,2
  • 802.11 a/b/g/n (2x2) + Bluetooth 4.0 Combo1,2
1. Sold separately or as an optional feature.
2. Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited.
Communications
  • Integrated Ethernet 10/100/1000 NIC
Audio/Multimedia
  • Audio
    DTS Sound
    Two integrated Stereo Speaker
    Headphone/Microphone-in Combo Jack
    Dual digital microphone
  • Webcam
    HP HD* Webcam**
    • Supports videoconferencing and still image capture
    • Improved quality for video streaming and still image capture (1280x720 resolution)
    • Up to 30 frames/sec
    • Fixed focus lens
** Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited.
Keyboards/Pointing Devices/Buttons and Function Keys
  • Keyboard
    Full size island style keyboard
    Spill resistant
  • Touchpad
    Multitouch gestures enabled
    Taps enabled as default
Display specifications
15.6" diagonal LED-backlit HD anti-glare flat (1366 x 768)
Specification
Active area (W x H)
34.4 x 19.4 cm (13.54 x 7.59 in)
Diagonal Size
39.6cm (15.6 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Pitch: .252 mm
  • Format: 1366 x 768
  • Configuration: RGB Stripe
Backlight
LED
PPI
101
Viewing angle
  • ±40° Horizontal, +10°/-30° Vertical (minimum)
  • 40/40/30/10 (Left/Right/Down/Up) (minimum)
Ports/slots
Specification
Ports
  • VGA – One
  • HDMI* – One
  • Headphone / Microphone-in combo jack – One
  • RJ-45 (Ethernet) - One
  • AC Smart Pin adapter plug – One
  • Two - USB 3.0 on one side
  • One - USB 2.0 on other side
Slots
HP Multi-Format Digital Media Reader
  • Support SD/SDHC/SDXC
  • Push-Push Insertion/Removal
Storage and drives
500GB* 7200 rpm SATA Hard Drive
Specification
Drive weight
115 g (0.25 lb)
Capacity
500GB
Height
7 mm (0.276 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer rate
Synchronous (maximum) 300MB/s (Drive Capability)
Seek time (typical reads, including settling)
  • Single Track: 1.5 ms
  • Average: 11 ms
  • Maximum: 22 ms
Rotational speed
7200 rpm
Logical blocks
976,773,168
Operating temperature
0° to 60° C (32° to 140° F) [case temp]
Features
ATA security
1TB 5400 rpm SATA Hard Drive
Specification
Drive weight
115 g (0.254 lb)
Capacity
1TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Single Track: 3 ms
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
1,953,525,168
Features
ATA security
750GB* 5400 rpm SATA Hard Drive
Specification
Drive weight
101 g (0.22 lb)
Capacity
750GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
1,465,149,168
Features
ATA security
500GB* 5400 rpm SATA Hard Drive
Specification
Drive weight
101 g (0.22 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Synchronous (maximum) 150MB/s (Drive Capability)
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA security
320GB* 5400 rpm SATA Hard Drive
Specification
Drive weight
101 g (0.22 lb)
Capacity
320GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
625,142,448
Features
ATA security
* For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 36 GB (for Windows 8.1) of system disk is reserved for the system recovery software.
Optical drive specifications
DVD+/-RW SuperMulti DL Drive
Specification
Access times
Random:
Less than 140 ms CD (typical)
Less than 160 ms DVD (typical)
Max data transfer rate
  • 24X CD-ROM
  • 8X DVD
  • 24X CD-R
  • 24X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 5X DVD-RAM
Transfer Mode
UDMA Mode 5
Interface
Gen 1 SATA
Supported Media (read)
CD-DA, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
Supported Media (write)
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM, DVD+R DL, DVD-R DL
Max Media Capacity (read)
8.5GB
Max Media Capacity (write)
8.5GB
Transport
Tray Loading
Integrated Realtek 10/100/1000 NIC
Specification
Ethernet Features
  • 10 Mbit/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mbit/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mbit/s operation (100BASE-T; IEEE 802.3ab; IEEE 802.3 clauses 21-30) ( Support in RTL8161FH-CG only)
  • Auto-Negotiation (Automatic Speed Selection)
  • Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mbit/s
  • IEEE 802.1p QoS (Quality of Service) Support
  • IEEE 802.1q VLAN support
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32); configurable
Power Management
  • ACPI compliant - multiple power modes
  • Situation-sensitive features reduce power consumption
  • Advanced link down power saving for reducing link down power consumption
Performance Features
  • TCP/IP/UDP Checksum Offload (configurable)
  • Large send offload and Giant send offload
  • Receiving Side Scaling
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame); Wake-on-LAN from off (Magic Packet only)
  • PXE 2.1 Remote Boot
  • Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite
  • Virtual Cable Doctor for Ethernet cable status
Interface
PCI Express 1.1 x1 to fully support ASPM L0s/L1 and CLKREQ
NIC Device Driver Name
Realtek PCIe FE Ethernet Family Controller
Atheros 802.11b/g/n WiFi Adapter*,**
Specification
Wireless LAN Standards
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency Band
2.402 - 2.482 GHz
Data Rates
  • 802.11b: 1, 2, 5.5, 11Mbps
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54Mbps
  • 802.11n: 150Mbps for MCS7
Frequency Support
20 MHz: 2.4 GHz bands
Modulation
  • Direct Sequence Spread Spectrum
  • DBPSK, DQPSK, CCK, OFDM, BPSK, QPSK, 16-QAM, 64-QAM
Security1
  • Supports 64- and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, LEAP, EAP-FAST
  • Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 5) with Microsoft Windows 7 only
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations
Media Access Protocol
CSMA/CA (Collision Avoidance) with ACK
Network Architecture Models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between access points
Output Power2
13.5 dBm, minimum
Power Consumption
  • Idle associated: 250 mW avg (CLKREQ enabled)
  • Idle unassociated: 100 mW avg
  • Transmit/Receive channel: 2.0 /1.6 W
Power Management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Receiver Sensitivity3
  • 11b:-88dBm at 11Mbps
  • 11g:-74dBm at 54Mbps
  • 11n:-70dBm at 72Mbps
Antenna type
High efficiency dual antenna with spatial diversity, usually mounted in the display enclosure
Form Factor
PCI-Express Half-MiniCard
4 g
Dimensions
3.3 x 26.65 x 29.85 mm
Operating Voltage
3.3v +/- 9%
Temperature
  • Operating: -10° to 70° C
  • Non-operating: -40° to 80° C
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 95% (non-condensing)
Altitude
  • Operating: 0 to 3,048 m (10,000 ft)
  • Non-operating: 0 to 15,240 m (50,000 ft)
LED Activity
Amber LED on-Radio OFF; White LED on-Radio ON
1. Check latest software/driver release for updates on supported security features.
2. Maximum output power may vary by country according to local regulations.
3. Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CCK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
WLAN supplier's client utility is required for Cisco Compatible Extensions support with Microsoft Windows XP. WLAN may also be compatible with certain third-party software supplicants. WLAN supplier IHV extensions required for Cisco Compatible Extensions support for Microsoft Windows Vista and Win7.
* Wireless access point and internet service required. Availability of public wireless access points limited.
** Sold separately or as an optional add-on feature.
Ralink 802.11b/g/n Bluetooth 4.0 Combo Card*, **
Specification
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency Band
2.402 – 2.482 GHz
Data Rates
Modulation
Security1
  • Supports 64- and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, LEAP, EAP-FAST, WAPI
  • Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 5) with Microsoft Windows Vista and XP only
Sub-channels
Roaming
Output Power (for CCK)2
13.5dBm, minimum
Power Consumption
  • Idle unassociated: 150 mW
  • Transmit: 2.0 W (max)
  • Receive: 2.0 W (max)
Power Management
  • 11b:-88 dBm at 11Mbps
  • 11g:-74 dBm at 54Mbps
  • 11n:-70 dBm at 72Mbps
Antenna type
High efficiency dual antenna with spatial diversity, mounted in the display enclosure
Form Factor
PCI-Express Half-MiniCard v1.2
6 g
Dimensions
Operating Voltage
3.3v +/- 10%
Temperature
  • Operating: -10° to 65° C (14° to 149° F)
  • Non-operating: -40° to 80° C (-40° to 176° F)
Humidity
Altitude
LED Activity
LED Off – Radio OFF; Solid LED On – Radio ON
Bluetooth Specification
V4.0 High Speed, V2.1+EDR, backwards compatible with V1.1, 1.2 and 2.0
Number of Available Channels
79 (1 MHz) available channels
Data Rates and Throughput
  • 3 Mbps data rate; throughput up to 2.17 Mbps
  • Synchronous Connection Oriented links up to 3, 64 kbps, voice channels
  • Asynchronous Connection Less links 2178.1 kbps/177.1 kbps asymmetric or 1306.9 kbps symmetric
Transmit Power
-6 dBm to 4 dBm (Bluetooth Class II)
Better than -80 dBM at 0.1 % raw bit error rate
Power Consumption
  • Peak (Tx) 330 mW
  • Peak (Rx) 230 mW
  • Sleep less than 17 mW
Antenna
Internally integrated within module
Range
Up to 10 m (33 ft)
Electrical Interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Bluetooth Software Supported
  • Broadcom Bluetooth for Windows
  • Microsoft Windows Bluetooth Software
Link Topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Security
Full support of Bluetooth Security Provisions
Power Management
  • Microsoft Windows ACPI, and USB Bus Support
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Bluetooth Profiles Supported
  • Generic Access Profile (GAP)
  • Service Discovery Application Profile (SDAP)
  • Serial Port Profile (SPP)
  • Dial_Up Networking Profile (DUN)
  • Generic Object Exchange Profile (GOEP)
  • Object Push Profile (OPP)
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)
  • Personal Area Networking Profile (PAN)
  • Human Interface Device Profile (HID)
  • Generic Audio/Video Distribution Profile (GAVDP)
  • Advanced Audio/Video Distribution Profile (A2DP)
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Basic Printing Profile (BPP)
  • Video Distribution Profile (VDP)
  • Audio Video Remote Control Profile (AVRCP)
Broadcom 802.11 a/b/g/n (2x2) with Bluetooth 4.0 combo*, **
Specification
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency Band
  • 802.11b/g/n
    • 2.402 – 2.482 GHz
  • 802.11a/n
    • 4.9 - 4.95 GHz (Japan)
    • 5.15 - 5.25 GHz
    • 5.25 - 5.35 GHz
    • 5.47 - 5.725 GHz
    • 5.825 - 5.850 GHz
    • 2.402 - 2.482 GHz
Data Rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54Mbps
  • 802.11n: card will support rates for NSS=1 and NSS=2 for RX and TX for 20 and 40 MHz channels. Short and long guard interval shall be supported.
Modulation
  • BPSK, QPSK, CCK, 16-QAM, 64-QAM
Security1
  • IEEE and WiFi compliant 64/128-bit WEP encryption for a/b/g mode only
  • AES-CCMP: 128 bit in hardware
  • 802.1x authentication
  • WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES
  • WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through V5
  • WAPI
Roaming
Output Power2
  • 2.4G: +13.5dBm minimum
  • 5G: +12dBm minimum
  • Maximum output power must be able to achieve modular regulatory certification with notebooks that have antennas greater than 20cm from the user and peak gain of +3dBi at 2.4GHz and +4dBi at 5GHz
Power Consumption
  • Receive: 1.6 W (max)
  • Idle mode (PSP): 250 mW (WLAN Associated)
  • Idle mode: 100 mW (WLAN unassociated)
  • Radio disabled: 75 mW
Power Management
  • ACPI and PCI Express compliant power management
802.11b
  • -95 dBm (1 Mbps)
  • -93 dBm (2 Mbps)
  • -91 dBm (5.5 Mbps)
  • -88 dBm (11 Mbps)
802.11a/g
  • -90 dBm (6 Mbps)
  • -89 dBm (9 Mbps)
  • -87 dBm (12 Mbps)
  • -85 dBm (18 Mbps)
  • -82 dBm (24 Mbps)
  • -79 dBm (36 Mbps)
  • -76 dBm (48 Mbps)
  • -74 dBm (54 Mbps)
802.11n
  • -69 dBm (72.2 Mbps)
  • -66 dBm (300 Mbps)
Antenna type
  • High efficiency antenna with spatial diversity, mounted in the display enclosure
  • Two embedded dual band 2.4/5 GHz antennas are provided to the card to support WLAN MIMO communications and Bluetooth communications
Form Factor
Dimensions
4.75 x 26.8 x 30 mm (0.19 x 1.06 x 1.18 in)
Operating Voltage
3.3v +/- 9%
Temperature
  • Operating: -10° to 70° C (14° to 158° F)
Humidity
Altitude
LED Activity
3. Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CKK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
Transmit Power
Power Consumption
  • Peak (Tx) 330 mW
  • Peak (Rx) 230 mW
Antenna
Range
Up to 10 m (33 ft)
  • USB 2.0 compliant
Link Topology
Security
Power Management
Certifications
  • FAX Profile (FAX)
Audio/Multimedia
Specification
Audio hardware
Implementation
Realtek ALC3201-GR High Definition audio
Volume controls
Up, down, and mute function keys
Full duplex
Yes
Microphone in
Stereo
Headphone/line out
Stereo
Integrated microphone
Yes
Audio output quality
Frequency response
10 Hz - 22 kHz
Signal to noise ratio
Typical 95 dB FSA (DAC)
Total harmonic distortion
Typical -88 dB FS (DAC)
Noise floor
- 110 dB
Play/Record sampling rate(s)
Up to 192 KHz
DAC
24 bits
ADC
24 bits
Integrated stereo speakers
Power rating
1.5 W
Impedance
4 ohms
Multimedia integrated HD webcam
Up to 30 frames/sec Fixed focus lens
Power
HP 45W Smart AC Adapter
Specification
Input
  • 100 to 240 VAC
  • Input Efficiency: 87% min at 115 VAC
  • Input frequency range: 47 to 63 Hz
  • Input AC current: 1.7 A at 90 VAC
Output
  • Output power: 65W
  • DC output: 18.5/19.5V
  • Hold-up time: 5 msec at 115 VAC input
  • Output current limit: Less than 11A, Over voltage protection- 29V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
  • Operating temperature: 5° to 35° C (41° to 95° F)
  • Non-operating (storage) temperature: -20° to 85° C (-4° to 185° F)
  • Altitude: 0 to 1,524 m (0 to 5,000 ft)
  • Humidity: 20% to 95%
  • Storage Humidity: 10% to 95%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF - over 200,000 hours at 25°C ambient condition.
HP 65W AC Adapter
Specification
Dimensions
10.7 x 4.7 x 3.0 cm (4.21 x 1.85 x 1.18 in)
280 g (0.62 lb)
Input
  • 100 to 240 VAC
Output
  • Output power: 65W
Connector
4-Cell (41 WHr) Lithium-Ion battery
Specification
Cells/type
4-cell Lithium-Ion
Energy temperature
  • Watt-hour capacity: 41 WHr
  • Operating (Charging): 0° to 45° C (32° to 113° F)
  • Operating (Discharging): -10° to 60° C (14° to 140° F)
  • Non-operating: -20° to 60° C (-4° to 140° F)
Battery re-charge time
  • System in OFF or Standby Mode: 2.5 hours
  • System ON: 3 to 5 hours (depending on system power consumption)
  • HP Fast Charge Technology: Charges the battery up to 90% within 90 minutes when system is OFF
System specifications
Specification
Stand-alone power requirements (AC power)
Nominal operating voltage: 18.5/19.5 V
Average operating power: Integrated graphics: TBD
Max operating power: Less than 65 W
Temperature
Operating
  • 0° to 35°C (32° to 95°F) (not writing optical)
  • 5° to 35°C (41° to 95°F) (writing optical)
Non-operating
  • -20° to 60° C (-4° to 140° F)
Relative humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 38.7° C (101.6° F) maximum wet bulb temperature
Shock
Operating: 40 G, 2 ms, half-sine
Non-operating: 200 G, 2 ms, half-sine
Random Vibration
Operating: 0.75 grms
Non-operating: 1.50 grms
Altitude (unpressurized)
Operating:
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating:
-15.24 to 12,192 m (-50 to 40,000 ft)
Planned industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC Compliance: Yes
  • ENERGY STAR: Select models
  • EPEAT: Registered Silver in United States
  • ICES: Yes
  • Australia/NZ A-Tick Compliance: Yes
  • CCC: Yes
  • Japan VCCI Compliance: Yes
  • KC: Yes
  • BSMI: Yes
  • CE Marking Compliance: Yes
  • BNCI or BELUS: Yes
  • CIT: Yes
  • GOST: Yes
  • Saudi Arabian Compliance (ICCP): Yes
  • SABS: Yes
  • UKRSERTCOMPUTER: Yes
Physical specifications
Feature
Weights
Starting at 2.30 kg (5.07 lbs)
Weight varies by configuration.
Dimensions (Wx D x H)
26.1 x 38.4 x 2.31 cm (10.28 x 15.12 x .91 in)
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components.
Software/OS
Feature
Preinstalled software with Windows operating system
Buy Office
Recovery Manager Installer
Cyberlink Youcam DE
Cyberlink Power DVD (available on select models)
McAfee Internet Security 2013*
Getting Started with Windows 8.1
* Internet access required. First 60 days included. Subscription required for live updates afterwards.
Security
Security lock slot
Fingerprint Reader (select models only)
TPM 1.2
