HP ProBook 440 G2 Notebook PC - Specifications
Physical specifications
Feature
Weights and dimensions
  • HP ProBook 440 G2 Notebook PC
    • Lightest possible configuration across battery and panel options (HD Panel, Non-Touch, No-ODD, 4-cell (44Whr) Battery, M.2 120GB SSD) at 4.04 lb/1.83 kg
    • Non-Touch, No-ODD, M.2 SSD
      1.83 kg (4.04 lb)
    • Non-Touch, ODD, M.2 SSD
      1.94 kg (4.29 lb)
    • Non-Touch, No-ODD, HDD
      1.92 kg (4.24 lb)
    • Non-Touch, ODD, HDD
      2.03 kg (4.49 lb)
    • Touch, No-ODD, HDD
      2.32 kg (5.10 lb)
    • Touch, ODD, HDD
      2.43 kg (5.35 lb)
    Dimensions (w x d x h)
    • Non-Touch Models
      • 13.35 x 9.61 x 0.91 (front) - 0.99 in (at rear)
      • 33.92 x 24.4 x 2.31 (front) - 2.52 cm (at rear)
    • Touch Models
      • 13.35 x 9.62 x 0.96 (front) - 1.05 in (at rear)
      • 33.92 x 24.45 x 2.45 (front) - 2.66 cm (at rear)
  • HP ProBook 450 G2 Notebook PC
    • Lightest possible configuration across battery and panel options (HD Panel, Non-Touch, No-ODD, 4-cell (44Whr) Battery, M.2 120GB SSD) at 4.66 lb/2.11 kg
      1.83 kg (4.04 lb)
      1.94 kg (4.29 lb)
      1.92 kg (4.24 lb)
      2.03 kg (4.49 lb)
      2.32 kg (5.10 lb)
    • Touch, ODD, HDD
      2.43 kg (5.35 lb)
    • Non-Touch Models
      • 14.76 x 10.35 x 0.92 (front) - 1.00 in (at rear)
      • 37.50 x 26.28 x 2.34 (front) - 2.55 cm (at rear)
    • Touch Models
      • 14.76 x 10.36 x 0.98 (front) - 1.07 in (at rear)
      • 37.50 x 26.32 x 2.50 (front) - 2.71 cm (rear)
Ports/Slots
  • USB 3.0 – Two
  • USB 2.0 – Two
  • HDMI 1.4a – One
  • Headphone/Microphone Combo Jack – One
  • RJ-45 (Ethernet) – One
  • Power connector – One
  • VGA – One
Digital media slots
Multi Media Reader slot supporting:
  • SD
  • SDHC
  • SDXC
System specifications
Specification
Stand-alone power
Nominal operating voltage: 19 V
Requirements (AC power)
Voltage
Average Operating Power
Windows 7
Windows 8
Max
ProBook 440 integrated graphics
6.78 W
6.78 W
38.88 W
ProBook 440 discrete graphics
4.49 W
4.49 W
31.33 W
ProBook 450 integrated graphics
8.89 W
8.89 W
39.33 W
ProBook 450 discrete graphics
6.79 W
6.79 W
38.42 W
ProBook 470 discrete graphics
5.71 W
5.71 W
23.56 W
Temperature
Operating
  • 0° to 35° C (32° to 95° F) (not writing optical)
  • 5° to 35° C (41° to 95° F) (writing optical)
Non-operating
  • -20° to 60° C (-4° to 140° F)
Relative humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 38.7° C (101.6° F) maximum wet bulb temperature
Shock
Operating: 40 G, 2 ms, half-sine
Non-operating: 200 G, 2 ms, half-sine
Random Vibration
Operating: 0.75 grms
Non-operating: 1.50 grms
Altitude (unpressurized)
Operating:
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating:
-15.24 to 12,192 m (-50 to 40,000 ft)
Planned industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC Compliance: Yes
  • ENERGY STAR 6.0: Select models*
  • EPEAT: Registered Gold in United States*
  • ICES: Yes
  • Australia/NZ A-Tick Compliance: Yes
  • CCC: Yes
  • Japan VCCI Compliance: Yes
  • KC: Yes
  • BSMI: Yes
  • CE Marking Compliance: Yes
  • BNCI or BELUS: Yes
  • CIT: Yes
  • GOST: Yes
  • Saudi Arabian Compliance (ICCP): Yes
  • SABS: Yes
  • UKRSERTCOMPUTER: Yes
Display specifications
Specification
14" diagonal LED-backlit HD anti-glare (1366 x 768)
Dimensions (W x H)
32.09 x 18.76 cm (12.63 x 7.39 in)
320g (0.71 lb) (max)
Diagonal size
35.6cm (14.0 in)
Surf ace treatment
Anti-glare
Contrast ratio
400:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Pitch: 0.227 mm
  • Format: 1366 x 768
  • Configuration: RGB Stripe
Backlight
LED
PPI
112 ppi
Viewing angle
  • ±30° Horizontal, ±10° vertical (minimum)
  • 30/30/20/10 (Left/Right/Down/Up) (minimum)
  • 45/45/35/25 (Left/Right/Down/Up) (typical)
HDD specifications
Specification
750 GB 7200 rpm SATA Hard Drive:
Drive Weight
115 g (0.25 lbs)
Capacity
750 GB
Height
9.5 mm (0.37 in)
Width
63.5 mm (2.50 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer Rate
Synchronous (maximum): 300 MB/s (drive capability)
Seek Time
  • Single Track: 1.5 ms
  • Average: 11 ms
  • Maximum: 22 ms
Rotational Speed
7200 rpm
Logical Blocks
1,465, 149, 168
Operating Temperature
0° to 60° C (32° to 140° F) [case temp]
Features
ATA Security
320 GB 5400 rpm SATA Hard Drive:
Drive weight
115 g (0.25 lbs)
Capacity
320 GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Synchronous (maximum) 300 MB/s (Drive Capability)
Seek time (typical reads, including settling)
  • Average: 11 ms
  • Maximum: 22 ms
Rotational speed
7200 rpm
Logical blocks
625, 142, 448
Operating temperature
Features
ATA security
500GB 5400 rpm SATA Hard Drive:
Drive weight
101 g (0.22 lb)
Capacity
500 GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Single Tr ack: 3 ms
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
976, 773, 168
Features
ATA security
750 GB* 5400 rpm SATA Hard Drive:
Drive weight
101 g (0.22 lb)
Capacity
750 GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer Rate
Seek Time
  • Single Track 3: 3ms
  • Average: 13 ms
  • Maximum: 24 ms
Rotational Speed
5400 rpm
Logical Blocks
1,465, 149, 168
Features
ATA Security
1 TB* 5400 rpm SATA Hard Drive:
Drive weight
0.115 g (0.254 lb)
Capacity
1 TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer Rate
Seek Time
  • Single Track 3: 3 ms
  • Average: 13 ms
  • Maximum: 24 ms
Rotational Speed
5400 rpm
Logical Blocks
1,953, 525, 168
Features
ATA Security
500 GB* 5400 rpm SMART SATA II Hybrid HDD/SSHD:
Drive weight
95 g (0.209 lb)
Capacity
500 GB
Height
7 mm (0.276 in)
Width
70.1 mm (2.76 in)
Interface
Transfer Rate
Synchronous (maximum) 600 MB/s (Drive Capability)
Seek Time
  • Single Track 3: 2ms
  • Average: 12 ms
  • Maximum: NIL ms
Rotational Speed
5400 rpm
Logical Blocks
976, 773, 168
Features
ATA Security
SATA 6 Gb/s 128 GB*, 2.5-inch Solid State Drive
Drive weight
73 Grams
Capacity
128 GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum Sequential Read: 415 MB/s
  • Maximum Sequential Write: 175 MB/s
Logical Blocks
250, 069, 680
0° to 70° C (32° to 158° F) [case temp]
Features
ATA Security; ATA-8; SATA 3.0; DIPM; TRIM
120 GB* M.2 Solid State Drive
Drive weight
< 10 g
Capacity
120 GB
Height
22 mm (0.276 in)
Width
42 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum Sequential Read: 540 MB/s
  • Maximum Sequential Write: 480 MB/s
Logical Blocks
234, 441, 648
0° to 70°C (32° to 158°F) [case temp]
Features
ATA Security; ATA-8; SATA 3.0; TRIM
Security
Specification
HP Fingerprint Sensor (optional)
Mobile voltage operation
3.0V-3.6V Single Supply
0° - 70°C (32° - 158°F)
Current consumption at 3.3 V
  • Less than 70 mA peak imaging and scrolling
  • Less than 25 mA hardware finger detection
  • Advanced power management
High-rate image capture
Up to 240 image frames /sec
ESD resistance
IEC 61000-4-2 Level 4 (±15KV)
Detection matrix
  • 192 x 16 pixels
  • 9.7 mm x 0.81 mm
  • 500 ppi High-Resolution images
Networking/Communications
Specification
Integrated Realtek RTL8161GSH-CH 10/100/1000 NIC:
Ethernet Features
  • 10 Mbit/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mbit/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mbit/s operation (1000BASE-T; IEEE 802.3ab; IEEE 8023 clauses 40)
  • Auto-Negotiation (Automatic Speed Selection)
  • Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mbit/s
  • IEEE 802.1p QoS (Quality of Service) Support
  • IEEE 802.1q VLAN support
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
  • IEEE 802.3az EEE (Energy Efficient Ethernet)
  • Jumbo Frame 9K
  • Auto MDI/MDIX Crossover cable detection
Power Management
  • ACPI compliant - multiple power modes
  • Situation-sensitive features reduce power consumption
  • Advanced link down power saving for reducing link down power consumption
Performance Features
  • TCP/IP/UDP Checksum Offload (configurable)
  • Protocol Offload (ARP & NS)
  • Large send offload and Giant send offload
  • Receiving Side Scaling
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame); Wake-on-LAN from off (Magic Packet only)
  • PXE 2.1 Remote Boot
  • Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite
  • Virtual Cable Doctor for Ethernet cable status
Interface
PCI Express 1.1 to fully support ASPM L0s/L1 and CLKREQ
NIC Device Driver Name
Realtek PCIe GBE Ethernet Family Controller
Realtek 802.11 b/g/n (1x1)*:
Wireless LAN Standards
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency Band
2.402 – 2.482 GHz
Data Rates
  • 802.11b: 1, 2, 5.5, 11 Mbps
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
  • 802.11n: card will support rates for NSS=1 for RX and TX for 20 MHz channels. Short and long guard interval will be supported.
Modulation
  • Direct Sequence Spread Spectrum
  • BPSK, QPSK, CCK, 16-QAM, 64-QAM
Security1
  • IEEE and WiFi compliant 64 / 128 bit WEP encryption for a/b/g mode only AES-CCMP: 128 bit in hardware 802.1x authentication types WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES.
  • WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through V5
  • WAPI
Network Architecture
Ad-hoc (Peer to Peer)
Models
Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between access points
Output Power2
13.5 dBm, nominal
Power Consumption
  • Transmit: 2.0 W (max)
  • Receive: 1.6 W (max)
  • Associated to Access Point, Idle: 250 mW nominal
  • Wireless Button Off: 100 mW nominal
  • Radio disabled: 75 mW nominal
Power Management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Receiver Sensitivity3
  • 802.11b:
    • -95 dBm (1 Mbps)
    • -93 dBm (2 Mbps
    • -91 dBm (5.5 Mbps)
    • -88 dBm (11 Mbps)
  • 802.11g:
    • -90 dBm (6 Mbps)
    • -89 dBm (9 Mbps)
    • -87 dBm (12 Mbps)
    • -85 dBm (18 Mbps)
    • -82 dBm (24 Mbps)
    • -79 dBm (36 Mbps
    • -76 dBm (48 Mbps)
    • -74 dBm (54 Mbps)
  • 802.11n:
    • -70dBm (72.2 Mbps)
Antenna Type
High efficiency antenna with spatial diversity, mounted in the display enclosure
Form Factor
PCI-Express Half-MiniCard
Less than 10 g
Dimensions (Length x Width x Thickness)
4.75 x 26.8 x 30 mm (0.19 x 1.06 x 1.18 in)
Voltage, Operating
3.3v +/- 9%
Temperature
  • Operating
    –10° to 70° C (14° to 158° F)
  • Non-operating
    –40° to 80° C (–40° to 176° F)
Humidity
  • Operating
    10% to 90% (non-condensing)
  • Non-operating
    5% to 95% (non-condensing)
Altitude
  • Operating
    0 to 10,000 ft (3,048 m)
  • Non-operating
    0 to 50,000 ft (15,240 m)
LED Activity
LED Off – Radio OFF; Solid LED On – Radio ON
1. Check latest software/driver release for updates on supported security features.
2. Maximum output power may vary by country according to local regulations.
3. Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CKK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
*Wireless access point and internet service required. Availability of public wireless access points limited.
Intel Dual Band Wireless-AC 3160 802.11 ac (1x1) WiFi and Bluetooth 4.0 Combo* Adaptor
Dimensions (H x W x D)
Standard: 26.80 mm x 30.00 mm x 2.4 mm Max (Top Side) / 1.35 mm Max (Bottom Side)
Low profile: 22 mm x 30.00 mm x 1.5 mm Max (Top Side) / 0.6 mm Max (Bottom Side)
NGFF: 22 mm x 30 mm, single sided
Diversity
No diversity support
Radio ON/OFF Control
Supported in both hardware and software
Connector interface
Half Mini Card form factor, based on PCIe electrical interface
Next Generation Form Factor, A-SD electrical interface definition support
LED Output
On/Off
Operating Temperature (Adapter Shield)
0° to +80° C
Humidity Non-Operating
50% to 90% RH non-condensing (at temperatures of 25°C to 35°C)
Operating Systems
Microsoft Windows 7, Microsoft Windows 8, Linux
Wi-Fi Alliance
Wi-Fi CERTIFIED for 802.11ac, Wi-Fi CERTIFIED a/b/g, Wi-Fi CERTIFIED n, WMM, WPA, WPA2, and WPS, WPS 2.0, Protected Management Frames, Wi-Fi Direct for peer to peer device connections
Microsoft WHQL
Yes
IEEE WLAN Standard
  • IEEE 802.11abgn
  • 802.11ac
  • 802.11d
  • 802.11e
  • 802.11i
  • 802.11h
  • 802.11w
Architecture
Infrastructure and SoftAP; Supports simultaneous Client and SoftAP modes in 2.4 GHz or 5GHz
Roaming1
ACPI and PCI Express compliant power management
Authentication
  • WPA
  • WPA2
  • 802.1X
    • EAP-TLS
    • TTLS
    • PEAP
    • LEAP
    • EAP-FAST
  • EAP-SIM
  • EAP-AKA
Authentication Protocols
  • PAP
  • CHAP
  • TLS
  • GTC
  • MS-CHAP
  • MS-CHAPv2
Encryption
  • WEP
    • 64-bit
    • 128-bit
  • AES-CCMP
  • TKIP
Wi-Fi Direct Encryption and Authentication
  • WPA2
  • AES-CCMP
Product Safety
UL, C-UL, CB (IEC 60950-1)
Management Frame Protection
802.11w (WFA- Protected Management Frames)
Retail (Credit Card Processing)
  • PCI
  • CISP
Government
  • FIPS2
  • FISMA
1. Roaming is supported only within each respective band and mode of access points.
2. Microsoft Windows 7 only.
HP Integrated Module with Bluetooth 4.0+EDR Wireless Technology
Bluetooth Specification
Dual Mode Bluetooth* 2.1, 2.1+EDR, 3.0, 3.0+HS, 4.0 (BLE)
Dimensions (H. W. D.)
30 x 6.5 x 3.25 mm (1.18 x 0.26 x 0.13 in)
Frequency Band
2402 to 2480 MHz
Number of Available Channels
79 (1 MHz) available channels
Data Rates and Throughput
  • 3 Mbps data rate; throughput up to 2.17 Mbps
  • Synchronous Connection Oriented links up to 3, 64 kbps, voice channels
  • Asynchronous Connection Less links 2178.1 kbps/177.1 kbps asymmetric or 1306.9 kbps symmetric
Transmit Power
-1.5 dBm to 4 dBm (Bluetooth Class II)
Better than -20 dBM at 0.1 % raw bit error rate
Power Consumption
  • Peak (Tx) 264 mW
  • Peak (Rx) 231 mW
  • Sleep <1 mW
Antenna
Internally integrated within module
Range
Up 33 ft (10 m)
Electrical Interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Bluetooth Software Supported
  • Broadcom Bluetooth for Windows
  • Microsoft Windows Bluetooth Software
Link Topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Security
Full support of Bluetooth Security Provisions
Power Management
  • Microsoft Windows ACPI, and USB Bus Support
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Temperature
  • Operating
    -10° to 70° C (-14° to 158° F)
  • Non-operating
    -40° to 100° C (-40° to 212° F)
Humidity
  • Operating
    0% to 90%
  • Non-operating
    0% to 95%
Altitude
  • Operating
    4,572 m (15,000 ft)
  • Non-operating
    12,192 m (40,000 ft)
Bluetooth Profiles Supported
  • Serial Port Profile (SPP)1
  • Service Discovery Application Profile (SDAP)
  • Dial-Up Networking (DUN)1,2
  • Generic Object Exchange Profile (GOEP)1,2
  • Object Push Profile (OPP)1,2
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)1,2
  • Personal Area Networking Profile (PAN)1,2
  • Human Interface Device Profile (HID)1,2
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)2
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Advanced Audio Distribution Profile (A2DP)
1. indicates the profile is supported by Microsoft Windows XP SP2
2. indicates the profile is part of Windows Vista
* Wireless access point and internet service required. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it may affect the ability of the notebook to communicate with other 802.11ac WLAN devices.
Optical Drives
Fixed 9.5 mm SATA optical drive
Blu-ray ROM DVD+/-RW SuperMulti DL Drive*†
No optical drive option
* Sold separately as an optional feature.
For Blu-ray drives, certain disc, digital connection, compatibility and/or performance issues may arise, and do not constitute defects in the product. Flawless playback on all systems is not guaranteed. In order for some Blu-ray titles to play, they may require an HDMI digital connection and your display may require HDCP support. HD-DVD disks cannot be played on this drive. Note that DVD-RAM cannot read or write to 2.6 GB Single Sided/5.2 GB Double Sided – Version 1.0 media. Actual speeds may vary. Don’t copy copyright-protected materials. Double Layer discs can store more data than single layer discs; discs burned with this drive may not be compatible with many existing single-layer DVD drives and players.
Audio/Multimedia - DTS sound+
Specification
Implementation
Realtek ALC3227-CG
Function key volume controls
Volume up, volume down, and mute
Full duplex
Yes
Microphone in
Stereo
Headphone/line out
Stereo
Integrated microphone
Yes, dual digital microphone array
Audio output quality
Frequency response
10 Hz – .454*Fs
Signal to noise ratio
95 dB (DAC), 88dB (ADC)
Total harmonic distortion
0.01%
Play/Record sampling rate(s)
44.1k/48k/96k/192kHz
DAC
16, 20 or 24-bit
ADC
16, 20 or 24-bit
Internal stereo speakers
Power rating
2 W
Impedance
4 ohms
Power
HP 45W Smart AC Adapter:
Dimensions
9.5 x 4.0 x 2.65 cm (3.74 x 1.57 x 1.04 in)
Input
90 to 265 VAC
Input Efficiency: 87.74% min at 115 VAC
Input frequency range: 47 to 63 Hz
Input AC current: 2.31 A at 100 VAC and maximum load
Output
Output power: 45W
DC output: 19.5V +5.0%∕-5%
Hold-up time: 5 msec at 115 VAC input
Output current limit: <8A, Over voltage protection- 29V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
Operating temperature: 0° to 35° C (32° to 95° F)
Non-operating (storage) temperature: -20° to 85° C (-4° to 121° F)
Altitude: 0 to 5,000 m (0 to 16,405 ft)
Humidity: 0% to 95%
Storage Humidity: 0% to 95%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; Reliability - failure rate of less than 0.1% annually within the first three years of operation.
4-Cell (44 WHr) Lithium-Ion battery
Dimensions(H x W x L)
2.18 x 3.56 x 27.72 cm (0.86 x 1.4 x 8.0 in)
Weight (max)
250 g (0.551 lb)
Cells/Type
4-cell Lithium-Ion
Energy
Voltage: 14.8V DC
Amp-hour capacity: 2850mAh
Watt-hour cap acity: 41 WHr
Temperature
Operating (Charging): 0° to 45° C (32° to 113° F)
Operating (Discharging): -10° to 60° C (14° to 140° F)
Non-operating: -20° to 60° C (-4° to 140° F)
Battery re-Charge time
System in OFF or Standby Mode: 2.5 hours
System ON: 3 to 5 hours (depending on system power consumption)
Fuel Gauge LED
No
Warranty (max)
1 year
Optional Travel Battery Available
No
4-Cell (40 WHr) Long Life Lithium- Ion battery:
Cells/Type
4-cell Lithium-Ion
Energy
Amp-hour capacity: 3.0 Ah
Watt-hour Capacity: 40 WHr
Temperature
Operating (Charging) 0° to 45° C (32° to 113° F)
Non-operating: -20° to 60° C(-4° to 140° F)
Battery Re-Charge Time
Fuel Gauge LED
No
Up to 3 years (depending on system warrenty)
No
ENVIRONMENTAL
MATERIAL USAGE
This product does not contain any of the following substances in excess of regulatory limits (for reference of these limits please refer to the HP General Specification of the Environment:
  • Asbestos
  • Certain Azo Colorants
  • Certain Brominated Flame Retardants – may not be used as flame retardants in plastics
  • Cadmium
  • Chlorinated Hydrocarbons
  • Chlorinated Paraffins
  • Formaldehyde
  • Halogenated Diphenyl Methanes
  • Lead carbonates and sulfates
  • Lead and Lead compounds
  • Mercuric Oxide Batteries
  • Ozone Depleting Substances
  • Polybrominated Biphenyls (PBBs)
  • Polybrominated Biphenyl Ethers (PBBEs)
  • Polybrominated Biphenyl Oxides (PBBOs)
  • Polychlorinated Biphenyl (PCB)
  • Polychlorinated Terphenyls (PCT)
  • Polyvinyl Chloride (PVC) – except for wires and cables, and certain retail packaging has been voluntarily removed from most applications.
  • Radioactive Substances
  • Tributyl Tin (TBT), Triphenyl Tin (TPT), Tributyl Tin Oxide (TBTO)
  • Nickel finishes that release greater than 0.5 μgrams/cm2/week, measured according to EN 1811:1998, are not used on any product surface designed to be frequently handled or touched by users.
End-of-life management and recyling
Hewlett-Packard offers end-of-life HP product return and recycling programs in many geographic areas. To recycle your product, please go to: hp.com/go/reuse-recycle or contact your nearest HP sales office. Products returned to HP will be recycled, recovered or disposed of in a responsible manner.
The EU WEEE directive (2002/95/EC) requires manufacturers to provide treatment information for each product type for use by treatment facilities. This information (product disassembly instructions) is posted on the Hewlett Packard web site at: hp.com/go/recyclers. These instructions may be used by recyclers and other WEEE treatment facilities as well as HP OEM customers who integrate and re-sell HP equipment.
Hewlett-Packard Corporate Environmentral Information
For more information about HP's commitment to the environment:
