HP Pro x2 612 G1 Travel Keyboard - Specifications
Product description
Work smarter on the go, get a true notebook keyboard experience, and help protect your HP Pro x2 612 G1 Tablet—a case and keyboard in one that folds out so you can get to work fast.
Product specifications
  • Weight: 715 g (1.57 lbs)
  • Dimension: 22.6 x 31.4 x 0.6 cm (8.89 x 12.38 x 0.23 in)
  • Thin keyboard folio with retaining flap
  • Foldable kickstand
  • 120° viewing angle
  • Docking connector to tablet
  • Ports/Connections:
    • 1 USB 3.0 port
    • Combo audio jack
    • DC-in: 4.5mm
  • Keyboard LED indicators:
    • DC power
    • Speaker Mute (f5)
    • Mic Mute (f8)
    • Wireless OFF (f12)
    • Number Lock and Caps Lock
  • Full size 81/82-key island-style backlit keyboard with full row of function keys and LED indicators
  • ClickPad (87 x 49 mm) with image sensor, multi-touch gestures enabled, on/off function and LED indicator
