HP Classmate Notebook PC - Overview
Product description
Product features
Feature
Accelerated processing unit
  • Intel® Celeron® N2806 (1.46 GHz, 1 MB L3 cache, 2 cores, 2.5W)*
*Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. 64-bit computing on Intel® architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers, and applications enabled for Intel® 64 architecture. Processors will not operate (including 32-bit operation) without an Intel® 64 architecture-enabled BIOS. Performance will vary depending on your hardware and software configurations. Intel's numbering is not a measurement of higher performance.
Intel integrated soldered on circuit (SoC)
Graphics
  • Integrated: Intel® HD* Graphics
  • Support for HD decode and HDMI
*High definition (HD) content is required to view high-definition images.
  • Internal:
    10.1" diagonal HD* anti-glare (1366x768)
  • External:
    Up to 32-bit per pixel color depth
  • HDMI:
    Port supports up to 1080p, 1920 x 1080 at 60Hz
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Storage and drives
Primary storage bay: Hard Drives
  • 320/500 GB*5400 rpm SMART SATA II HDD
*For hard drives GB = 1 billion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 8.1) of system disk is reserved for the system recovery software.
Memory
Standard:
  • DDR3L SDRAM (1066)
  • 4096 MB (1 DIMM) standard memory
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed.
Networking/Communications
Wireless LAN (WLAN)
  • LiteOn/AzureWave 802.11 b/g/n (1x1) + Bluetooth® 4.0 Combo*
Communications
Realtek RTL8105E-VL
  • Supports 10 and 100 Mb/sec
  • Full and half Duplex operation
*Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited.
Audio/Multimedia
Audio
  • Digital microphone
  • 2 Integrated speakers
  • Headphone / Microphone Combo Jack
1.0 MP HD* webcam
  • USB 2.0 interface
  • 15 fps, 1280 x 720 resolution
  • Support both 4:3 and 16:9 aspect ratio
Keyboard/Pointing devices/Buttons and function keys
Keyboard
  • Integrated 83 UK / 84 US QWERTY keyboard with hot key
  • Optional chocolate-colored keyboard
Pointing devices
  • Smart Pad / Click Pad with Left / Right Click and scrolling bar
  • Power button:
    • Press power button down for 1 second to enter suspend mode
    • Press power button down for 5 seconds to power off system
    • LED under power button
    • Fn + F1 - Airplane mode on/off
    • Fn + F2 - Sleep
    • Fn + F3 - Audio mute
    • Fn + F4 - Volume Down
    • Fn + F5 - Volume Up
    • Fn + F6 - Display Switch
    • Fn + F7 - Backlight Down
    • Fn + F8 - Backlight Up
Software overview
Feature
Preinstalled Software with Windows Operating System
Buy Office
Security
TPM 1.2 Embedded Security Chip
Security Cable Lock (Slot) (lock must be purchased separately)
For more information on HP security solutions refer to: http://www.hp.com/go/security.
