HP LaserJet Enterprise MFP M630 - Clear jams in the 1,500-sheet high-capacity input tray (Tray 5)
The following information describes how to clear a paper jam in the 1,500-sheet high-capacity tray (Tray 5). When a jam occurs, the control panel displays an animation that assists in clearing the jam.
  1. Open the 1,500-sheet high-capacity input tray.
    Figure : Open the tray
  2. Remove and discard any damaged sheets.
    Figure : Remove the jammed paper
  3. Remove the paper from the tray.
    Figure : Remove the paper
  4. Lift the tray up and then pull it straight out to remove it.
    Figure : Remove the tray
  5. If jammed paper is in the feed area, pull it down to remove it.
  6. Reinstall the tray, and then load full reams of paper into the tray. The tray holds 1,500 sheets of paper.
    For best results, load full reams of paper. Avoid dividing reams into smaller sections.
    Figure : Load the tray
  7. Close the tray.
    Figure : Close the tray
