HP LaserJet P2055 - Product specifications
Product dimensions
Product dimensions, with toner cartridge
Height
Depth
Width
P2055
268 mm
368 mm
360 mm
10.6 kg
P2055d
268 mm
368 mm
360 mm
10.6 kg
P2055dn
268 mm
368 mm
360 mm
10.6 kg
P2055x
405 mm
368 mm
365 mm
14.7 kg
Product dimensions with all doors, trays, and document feeder fully opened
Height
Depth
Width
P2055
268 mm
455 mm
360 mm
P2055d
268 mm
455 mm
360 mm
P2055dn
268 mm
455 mm
360 mm
P2055x
405 mm
455 mm
365 mm
Power consumption, electrical specifications, and acoustic emissions
Power consumption
Power consumption (average, in watts)1, 2
Product Series3
Printing
Ready
Sleep
Off
HP LaserJet P2055
570 W
8.0 W
8.0 W
0.4 W
1Values subject to change.
2Power reported is highest value measured for all product models using standard voltages.
3Speed is 33 ppm A4 size and 35 ppm Letter-size.
Electrical specifications
110-volt input voltage: 100 to 127 VAC (+/- 10%), 50/60 Hz (+/- 2 Hz), 6 A
220-volt input voltage: 220 to 240 VAC (+/- 10%), 50/60 Hz (+/- 2 Hz), 3 A
Power requirements are based on the country/region where the product is sold. Do not convert operating voltages. This will damage the product and void the product warranty.
Acoustic emissions
HP LaserJet P20551
Sound power level
Printing (33 ppm)
Ready
Declared per ISO 9296
LWAd = 6.8 Bels (A) [68 dB(A)]
Inaudible
Sound pressure level - Bystander position
Printing (33 ppm)
Ready
LpAm = 55 dB(A)
Inaudible
1Acoustic values are subject to change. Configuration tested: HP LaserJet P2055dn, printing on A4-size paper at 33 ppm in simplex mode.
Operating-environment specifications
Environment
Recommended
Allowed
Temperature
17.5° to 25°C
7.5° to 32.5°C
Relative humidity
30% to 70% relative humidity (RH)
10% to 90% RH
