HP Officejet 5740 Printers - Printing Photos from a Memory Card
This document is for HP Officejet 5740, 5741, 5742, 5743, 5744, 5745, and 5746 e-All-in-One printers.
To load small-size paper
  1. Pull out the main paper tray and then pull out the photo tray. If you do not see the photo tray, remove the output tray from the printer.
    Remove any previously loaded media.
    Figure : Graphic - Move the photo tray out
  2. Load paper.
    • Insert a stack of photo paper into the photo tray print side down.
      Figure : Graphic - Load photo paper in the paper tray
    • Slide the photo paper forward until it stops.
    • Insert the output tray if you removed it previously.
  3. Push the paper tray back in.
  4. Change or retain the paper settings on the printer display.
To load larger photo paper
If you want to print on larger photo paper, load it into the main paper tray as follows.
  1. Pull out the paper tray, slide the paper-width guides outward, and then remove any previously loaded media.
    Figure : Graphic - Slide the paper-width guide to its outermost position
  2. Load paper.
    • Insert a stack of paper into the paper tray with the short edge forward and the print side down.
    • Slide the paper forward until it stops.
    • Slide the paper-width guides inward until they stop at the edges of the paper.
      Figure : Graphic - Adjust the paper-width guide
To print photos from a memory device
  1. Insert a memory device into the slot.
    Figure : Graphic - Insert a memory card in the slot
    Do not remove the memory device while it is being accessed by the printer. This can damage the files on the device. You can safely remove a memory device only when the memory device light is not blinking.
  2. On the printer display, select a photo that you want to print and touch Continue.
  3. Specify the number of photos to print.
  4. Touch (Edit) to change brightness, crop, or rotate the selected photo, or touch (Print Settings) to use such features as Red Eye Removal or Photo Fix.
  5. Touch Continue and preview the selected photo.
  6. Touch Print to begin printing.
