HP Scanjet Flatbed Scanners - Load paper in the Automatic Document Feeder (ADF) input tray
This document provides instructions on how to load same-sized and mixed-sized documents into the Automatic Document Feeder (ADF) input tray of an HP Scanjet Flatbed Scanner.
  • Documents with the same paper size and width are same-sized documents.
  • Documents with different paper width or length are mixed sized documents, for example, legal size, letter size, and a check.
The types of scanners might vary but the procedure in this document applies to most Scanjet Flatbed scanners. The following are the list of HP Scanjet Flatbed scanners:
  • HP Scanjet 5590 Digital Flatbed Scanner series
  • HP Scanjet Enterprise 7000n Document Capture Workstation series
  • HP Scanjet Enterprise 7500 Flatbed Scanner
  • HP Scanjet Enterprise Flow 7500 Flatbed Scanner
  • HP Scanjet 8270 Document Flatbed Scanner
  • HP Scanjet Enterprise 8500 fn1 Document Capture Workstation
  • HP Scanjet N6310 Document Flatbed Scanner
  • HP Scanjet N6350 Networked Document Flatbed Scanner
  • HP Scanjet N8420 Document Flatbed Scanner
  • HP Scanjet N8460 Document Flatbed Scanner
  • HP Scanjet N9120 Document Flatbed Scanner
  • HP Scanjet Enterprise Flow N9120 Flatbed Scanner
Follow the instructions in this document or watch the following video:
If the video does not play, click here to view the video in YouTube.
Required guidelines before loading documents
Before loading the documents in the ADF input tray, make sure to follow these guidelines:
  • Use the recommended paper type and size in the ADF input tray. Refer to your User Guide for paper capacities and capabilities.
  • Smooth any folds or curls in the pages to avoid paper jams.
  • Fan through the pages to remove any staples, paper clips, or sticky notes.
    Figure : Fan the pages of the document
  • Turn on the scanner.
  • Close the ADF hatch properly until it clicks into place.
    A click sound indicates that the ADF hatch is securely latched.
  • Slide the paper guides to fit the width of the document. If there is any gap between the paper guides and the edges of the documents, the scanned image might be skewed.
    When loading small documents like checks, place the longest edge parallel to the paper width guides.
    Figure : Adjust paper guides
It is recommended to clean the rollers, if the scanner rollers are visibly dirty or after scanning a document that has pencil writing on it.
Method to load documents
Determine the type of documents to load in the ADF input tray, and then use one of the following methods:
To scan fragile documents (such as photos or documents on wrinkled or very light paper), place the document face down on the scanning glass.
Method 1: Load same-sized documents
Make sure to refer the section Required guidelines before loading documents, and then follow the following steps to load same-sized documents in the ADF input tray:
  1. Tap the long edge of the pages on a flat surface, then rotate and tap the top edge of the document pages to align the edges of the document pages.
  2. Load the pages with the print side up and the top edge of the pages into the ADF input tray.
    Do not tap the edge of the document stack or drop the paper stack into the ADF input tray.
    Figure : Load same-sized pages in the ADF input tray
  3. Adjust the paper guides to the width of the document.
    Make sure not to push the paper guides so tightly as they bend the documents.
The documents are now ready to be scanned.
Method 2: Load mixed-sized documents
Make sure to refer the section Required guidelines before loading documents, and then follow the following steps to load mixed-sized documents:
  1. Align the document pages from the widest to the narrowest.
  2. Load the documents by width with the print side up and the top edge of the document in the ADF input tray. Make sure to center the top pages.
