HP Tablets - Viewing Notification Details and Changing Quick Settings for HP Slate 7 VoiceTab Ultra, HP Slate 8 Plus, and HP Slate 10 Plus
This document applies to HP Slate 7 VoiceTab Ultra, HP Slate 8 Plus, and HP Slate 10 Plus tablets with the Emotion user interface.
The notification panel drops down from the top left corner of the tablet screen, and shows you details about any notifications that appear in the status bar at the top of the tablet screen, allowing you to quickly access further information about the notification.
The Quick Settings menu drops down from the top right corner of the tablet screen, and provides easy access to a number of commonly-accessed settings options, such as screen brightness and Wi-Fi settings.
Use the information in this document to familiarize yourself with the notification panel, the Quick Settings menu, and their respective functions.
Depending on the version of Android installed on your tablet, some of the images in this document may not match your tablet exactly.
Viewing notifications on your HP tablet
The notification panel displays details about any notifications that appear at the top of the tablet screen. For example, when you receive an email in your Google email account, a mail notification icon displays in the top left corner of the screen. Displaying the notification panel while you are in an app, for example, does not disrupt or close the app. When you expand the notification panel, it displays the email subject line and sender. You can then go directly to the email by touching the notification.
The notification panel can be expanded on top of any screen without disrupting any current processes open on the tablet. However, if you use the HP unlock method to lock the screen, to view and open notifications from the Lock screen, you must enable that setting. Use the following steps to view and open notifications from the Lock screen.
  1. On the Home screen, touch the Settings icon.
  2. In the Privacy and Security section, touch Security, and then touch the button to select it to allow the notification panel to be opened from the HP unlock screen.
    Figure : Allowing the notification panel to be opened from the Lock screen
Use this section to learn more about how you can use the notifications on your tablet.
  • Displaying the notifications: To display your notifications, swipe down from the top left corner of the screen. The notifications expand over the top of the screen you are currently viewing.
    Figure : Notifications
    Notification
  • Hiding the notifications: To exit the notifications, swipe up on the Close icon at the bottom of the screen, or touch the Back icon.
  • Dismissing notifications: To clear all of the notifications, touch Clear. To dismiss notifications one at a time, touch a notification and swipe left or right to remove the item from the list.
  • Viewing more information about a notification: You can view more information about most notifications, or go directly to the notification item, by touching the individual notification. When you view a notification, the notification disappears and it is removed from the notification area at the top of the screen.
Using the Quick Settings menu on your HP tablet
The Quick Settings menu provides easy access to a number of common settings. With Quick Settings, you can switch users, adjust screen brightness, enable or disable Wi-Fi connections, enable or disable the screen rotation feature, and modify other frequently-used settings. Settings available in the Quick Settings menu vary by tablet model.
The Quick Settings menu can be expanded on top of any screen without disrupting any current processes open on the tablet. Displaying the menu while you are in an app, for example, does not disrupt or close the app.
Use this section to learn more about using the Quick Settings menu on your tablet.
  • Displaying the Quick Settings menu: Swipe down from the top right corner of the screen. The Quick Settings menu expands over the top of the screen you are currently viewing.
    Figure : Quick Settings menu
    Quick Settings menu
    Touch the arrow to expand the Quick Settings menu.
    Figure : Expanding the Quick Settings menu
    The expanded Quick Settings menu shows additional settings.
    Figure : Expanded Quick Settings menu
  • Hiding the Quick Settings: To exit the Quick Settings, swipe up on the Close icon at the bottom of the screen, or touch the Back icon.
  • Adjusting screen brightness: Touch the Brightness tile to display a brightness slider. Touch and drag the slider to the left to decrease brightness, or to the right to increase brightness.
    Figure : Brightness slider
    Brightness slider
  • Accessing the full settings menu: Touch the Settings icon in the upper-right corner to access the full tablet settings menu, which features more settings options than the Quick Settings menu.
    Figure : Settings icon
    Settings icon
  • Accessing Wi-Fi settings: Touch the Wi-Fi tile to turn Wi-Fi on or off. To go to the Wi-Fi configuration settings page, touch and hold the Wi-Fi tile until the Wi-Fi settings page displays.
    Figure : Wi-Fi tile
    Wi-Fi tile
  • Accessing Mobile Data settings: Touch the Mobile Data tile to turn Mobile Data on or off. To go to the Mobile Data configuration settings, touch and hold the Mobile Data tile until the Mobile Data settings display.
    Figure : Mobile Data tile
    Mobile Data tile
  • Accessing Sound quick settings: Touch the Sound tile to switch from sound on, to vibrate, to sound off. To go to the Sound configuration settings, touch and hold the Sound tile until the Sound settings display.
    Figure : Sound settings
  • Accessing Bluetooth settings: Touch the Bluetooth tile to turn Bluetooth on or off. Go directly to the Bluetooth configuration settings by touching the Bluetooth tile.
    Figure : Bluetooth tile
    Bluetooth tile
  • Accessing GPS settings: Touch the GPS tile to turn GPS on or off. Go directly to the GPS configuration settings by touching the GPS tile.
    Figure : GPS tile
    GPS tile
  • Changing the screen rotation: Use the screen rotation tile to enable or disable the automatic screen rotation. When screen rotation is disabled, the tablet displays the portrait view.
    Figure : Screen rotation tile
  • Enabling SWS: Touch the SWS tile to enable or disable SWS.
    Figure : SWS tile
    SWS tile
  • Turning Airplane mode on or off: Airplane mode disables Wi-Fi and Bluetooth connections. When Airplane mode is disabled, the connections are restored to their previous settings. Touch the tile to enable or disable Airplane mode.
    Figure : Airplane mode tile
    Airplane mode tile
  • Creating a screenshot: To create a picture of the screen, touch the Screenshot tile.
    You can also create a screenshot by pressing the Power button and the Volume Down button at the same time.
    Figure : Screenshot tile
    Screenshot tile
  • Adjusting the volume
    Touch the Volume tile to adjust the volume level settings including music and video, ringtones, and alarms. Go directly to the Sound configuration settings by touching the Sound tile.
    Figure : Volume tile
    Volume tile
  • Using Multi-screen: Connect your tablet to your TV to wirelessly watch your content on the big screen. Touch Multi-screen to mirror your tablet with your TV, or any other multimedia device.
    Figure : Multi-screen tile
    Multi-screen tile
  • Setting up a Wi-Fi hotspot: Touch the Wi-Fi hotspot tile to turn Wi-Fi hotspot on or off. Go directly to the Wi-Fi hotspot configuration settings by touching the Wi-Fi hotspot tile.
    Figure : Wi-Fi hotspot tile
    Wi-Fi hotspot tile
Country: Flag Serbia
