    Windows 11 Upgrade Guide
HP LaserJet Pro MFP M225dn and M226dn Printer Specifications
This document applies to the HP LaserJet Pro MFP M225dn and LaserJet Pro MFP M226dn printers.
Review this document for detailed technical data, such as model numbers, system requirements, print speeds, connectivity types, physical dimensions, cartridges, paper handling, and print specifications.
Printer Model
Product Number
HP LaserJet Pro MFP M225dn Printer
Image: HP LaserJet Pro MFP M225dn printer
CF484A
CF486A
HP LaserJet Pro MFP M226dn Printer
C6N22A
Connectivity
The following table contains types of connection methods supported by this printer.
Model
Wireless
Ethernet
USB
Wireless Direct
N/A
10/100Base-T
Hi-speed USB 2.0
N/A
HP LaserJet Pro MFP M226dn printer
N/A
10/100Base-T
Hi-speed USB 2.0
N/A
Mobile printing capability
The following table contains types of mobile printing technologies supported by this printer.
Model
ePrint
ePrint mobile app
Apple AirPrint
Android Built-in Print Solution
Yes
No
Yes
Yes
Yes
No
Yes
Yes
Supported Web Services
The following table describes the Web Services the printers support.
Model
Print apps
Scheduled Delivery Printables
No
Yes
HP LaserJet Pro MFP M226d printer
No
Yes
System requirements
The following sections contain the minimum system requirements for supported Windows and Mac operating systems.
Physical dimensions
The following table provides the printer's height, width, depth, and weight.
Dimension
Measurement
Height
371.3 mm (14.6 in)
Width
442.5 mm (16.1 in)
Depth
288.7 mm (11.4 in)
11.0 kg (24.4 lb)
The measurements reflect the printer's dimensions with the paper trays retracted.
Cartridges
Region
Cartridge
The Americas
Europe
Middle East and Africa
Asia Pacific
HP 83A Black
This printer uses the HP 83A Black Original LaserJet Toner Cartridge (CF283A).
Control panel display
Review the following specifications to learn the size and display type of the printer's control panel.
  • Type:2-line LCD graphical display with push-button navigation
  • Color or black and white: Black and white
  • Special features: Anti-glare finish
Paper-handling specifications
Review the following tables to make sure that you are using the correct paper types and sizes and are not overloading the input tray.
Printing specifications
Review the following for print resolutions, method, and speeds.
  • Output: Black and white only
  • Draft mode resolution: 300 x 300 dots per inch (dpi)
  • Normal mode resolution: 600 x 600 dpi
  • Plain-Best mode resolution: Up to 1200 dpi
  • Device languages: PCL5 GUI
  • Print speed: Up to 26 ppm*
  • First page out: Up to 8 seconds
  • Duty cycle: 8,000 pages per month
* Print speeds vary according to the complexity of the document.
Copy specifications
Review the following information for copy specifications.
  • Copy speeds (default mode)*: Up to 25 copies per minute (cpm)
    *Copy speeds vary according to the printer model and the complexity of the document.
  • First copy out (flat bed): As fast as 10.5 seconds
  • First copy out (ADF): As fast as 13.5 seconds
  • Resolution (text and graphics): Up to 600 x 600 dpi
  • Processing method: Digital image
Scanning specifications
Review the following information for scanning specifications.
  • Resolution (flatbed): up to 1200 x 1200 ppi optical
  • Resolution (ADF): up to 300 x 300 ppi optical
  • Input sensor resolution: 1200 x 1200 dpi
  • Scan speed: Up to 15 ppm (b&w), up to 6 ppm (color)
  • Color: 24-bit color, 8-bit grayscale (256 levels of gray)
  • Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 in)
Faxing specifications
Review the following information for fax specifications.
  • Resolution: up to 300 x 300 dpi optical
  • Fax speed: 3 seconds per page
  • Number of broadcast fax locations: up to 119
  • Fax memory: up to 400 documents
  • Speed dial memory: up to 120 numbers
Power specifications
Review the following information for power specifications.
Acoustic emission specifications
Review the following information for the printer's acoustic emission specifications.
  • Sound pressure (bystander position): LpAm 50 (dBA) (mono Draft print)
  • Sound power: 6.4 B(A)
Environmental specifications
Review the following information for the printer's environmental specifications.
Allowed operating conditions
Review the following information for the printer's allowed operating conditions.
Factor
Temperature
15° to 30° C; 59° to 86° F
Humidity
10% to 80% relative humidity
Energy Star
Energy usage drops significantly while in ENERGY STAR mode, which saves natural resources, and saves money without affecting the high performance of this product. This product qualifies for ENERGY STAR, which is a voluntary program established to encourage the development of energy-efficient office products.
ENERGY STAR is a U.S. registered mark of the U.S. EPA. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency. For more information, go to www.energystar.gov.
Material safety data sheet
For information about material safety data sheets, go to the HP Material safety data sheets (MSDS) website.
Paper and plastic use
This product is suited for the use of recycled paper according to DIN 19309. Plastic parts over 25 grams are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of the product's life.
Recycling program
HP offers an increasing number of product return and recycling programs in many countries/regions and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. More information on these program is available on HP's www.hp.com/go/recycle.
Regulatory model number
For regulatory identification purposes, your printer is assigned a Regulatory Model Number. The Regulatory Model Number for your printer is SHNGC-1302-00 or SHNGC-1302-01. This regulatory number should not be confused with the marketing name (HP LaserJet Pro MFP M225dn, LaserJet Pro MFP M226dn, etc.) or product numbers (CF485A or C6N23A, etc.).
