    Apache Log4j Update
HP EliteBook 725 G2 Notebook PCs - Specifications
Physical specifications
Feature
System
Weights and dimensions
HP 725 G2 Notebook PC
  • Weight will vary by configuration
Dimensions (w x d x h)
  • Non-Touch
    12.2 x 8.48 x 0.83 in (at front)
    31 x 21.53 x 2.1 cm (at front)
  • Touch
    12.2 x 8.48 x 0.98 in (at front)
    31 x 21.53 x 2.48 cm (at front)
Ports/Slots
HP 725 G2, 745 G2, and 755 G2 Notebook PC
Ports
  • USB 3.0 – Two for EliteBook 725, Three for EliteBook 745 and EliteBook 755
  • USB 3.0 (charging) – One
  • DisplayPort 1.2 – One
  • VGA – One
  • Headphone/Microphone combo port – One
  • RJ-45 (Ethernet) – One
  • Power connector – One
  • Side docking connector – One
  • Secondary battery connector – One (EliteBook 745 G2 only)
Expansion Slots
  • Media Card Reader - supports SD, SDHC, SDXC
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components.
System specifications
Specification
Stand-alone power requirements (AC power)
Nominal operating voltage: 19.5 V
Max operating power: Discreet less than 90 W, UMA less than 65 W
Average operating power
Windows 7 (64-bit)
Windows 8 (64-bit)
EliteBook 725 G2 Integrated graphics
4.75 W
4.26 W
Temperature
Operating
  • 0° to 35° C ( 32° to 95° F) (not writing optical)
  • 5° to 35° C (41° to 95°F) (writing optical)
Non-operating
  • -20° to 60° C (-4° to 140° F)
Relative humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 38.7° C (101.6° F) maximum wet bulb temperature
Shock
Operating: 40 G, 2 ms, half-sine
Non-operating: 200 G, 2 ms, half-sine
Random Vibration
Operating: 0.75 grms
Non-operating: 1.50 grms
Altitude (unpressurized)
Operating:
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating:
-15.24 to 12,192 m (-50 to 40,000 ft)
Planned industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC Compliance: Yes
  • ENERGY STAR: Select models
  • EPEAT: Registered Silver in United States
  • ICES: Yes
  • Australia/NZ A-Tick Compliance: Yes
  • CCC: Yes
  • Japan VCCI Compliance: Yes
  • KC: Yes
  • BSMI: Yes
  • CE Marking Compliance: Yes
  • BNCI or BELUS: Yes
  • CIT: Yes
  • GOST: Yes
  • Saudi Arabian Compliance (ICCP): Yes
  • SABS: Yes
  • UKRSERTCOMPUTER: Yes
Display specifications
12.5-inch diagonal LED-backlit HD anti-glare SVA flat (1366 x 768)
Specification
Outline Dimensions (W x H x D)
29.1 x18.14 x 0.36 cm (11.46 x 7.14 x 0.14 in)
Active area
27.6615 x 15.552 cm (10.89 x 6.12 in)
270 g (0.6 lb) (max)
Diagonal Size
35.75 cm (12.5 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Format: 1366 x 768 (HD)
  • Configuration: RGB Stripe
Interface
eDP 1.2 (1 lane)
LCD Mode
TN
PPI
125 ppi
Viewing angle
SVA 40/40/15/30 (Left/Right/Down/Up)
14-inch diagonal LED-backlit HD anti-glare SVA flat (1366 x 768)
Specification
32.09 x 20.56 x 0.36 cm (12.6 x 8.09 x 0.14 in)
Active area
30.94 x 17.395 cm (12.18 x 6.85 in)
320 g (0.71 lb) (max)
Diagonal Size
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
Interface
eDP 1.2 (1 lane)
LCD Mode
TN
PPI
125 ppi
Viewing angle
14-inch diagonal LED-backlit HD+ anti-glare SVA flat (1600 x 900)
Specification
Active area
30.96 x 17.415 cm (12.19 x 6.86 in)
325 g (0.72 lb) (max)
Diagonal Size
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
250 nit (typical)
Pixel resolution
  • Format: 1600 x 900 (HD+)
Interface
eDP 1.2 (1 lane)
LCD Mode
TN
PPI
131 ppi
Viewing angle
14-inch diagonal LED-backlit HD+ SVA flat + touch (1600 x 900)
Specification
Active area
Diagonal Size
35.6 cm (14.0 in)
Touch enabled
Yes
TSP Type
Capacitive
Touch point supported
Min 5-point & Max 10-point for Win8
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
250 nit (typical)
Pixel resolution
Interface
eDP 1.2 (1 lane)
LCD Mode
TN
PPI
131 ppi
Viewing angle
14-inch diagonal LED-backlit FHD anti-glare UWVA slim (1920 x 1080)
Specification
32.09 x 20.56 x 0.3 cm (12.6 x 8.09 x 0.12 in)
Active area
30.93 x 17.4 cm (12.18 x 6.85 in)
340 g (0.75 lb) (max)
Diagonal Size
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
600:1 (min)
Refresh rate
60 Hz
Brightness
300 nit (typical)
Pixel resolution
  • Format: 1920 x 1080 (FHD)
Interface
eDP 1.3+PSR (2 lane)
LCD Mode
IPS/FFS/VA
PPI
157 ppi
Viewing angle
UWVA 85/85/85/85 (Left/Right/Down/Up)
15.6-inch diagonal LED-backlit HD anti-glare SVA flat (1366 x 768)
Specification
36.0 x 22.43 x 0.38 cm (14.17 x 8.83 x 0.15 in)
Active area
34.42 x 19.35 cm (13.55 x 7.62 in)
Less than 500 g (1.1 lb) (max)
Diagonal Size
39.62 cm (15.6 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
Interface
eDP 1.2 (1 lane)
LCD Mode
TN
PPI
101 ppi Viewing
Viewing angle
15.6-inch diagonal LED-backlit FHD anti-glare SVA flat (1920 x 1080)
Specification
36.0 x 22.43 x 0.32 cm (14.17 x 8.83 x 0.15 in)
Active area
34.42 x 19.36 cm (13.55 x 7.62 in)
Less than 380 g (0.84 lb) (max)
Diagonal Size
15.6 in (39.62 cm)
Surface treatment
Anti-glare
Contrast ratio
400:1 (typical)
Refresh rate
60 Hz
Brightness
300 nit (typical)
Pixel resolution
Interface
eDP 1.2 (2 lane)
LCD Mode
TN
PPI
142 ppi
Viewing angle
SVA 45/45/25/35 (Left/Right/Down/Up)
15.6-inch diagonal FHD SVA slim (1920 x 1080) Touch
Specification
Active area
Diagonal Size
39.62 cm (15.6 in)
TSP Type
Capacitive
Min 5-point & Max 10-point for Win 8
Contrast ratio
400:1 (typical)
Refresh rate
60 Hz
Brightness
300 nit (typical)
Pixel resolution
Interface
eDP 1.2 (2 lane)
LCD Mode
TN
PPI
142 ppi
Viewing angle
HDD specifications
1TB 5400 rpm SATA Hard Drive
Specification
Drive weight
115 g (0.254 lb)
Capacity
1TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 2.6, 3.0GB/s, NCQ
Transfer rate
Synchronous (maximum) 300MB/s (Drive Capability)
Seek time (typical reads, including settling)
  • Single Track: 3 ms
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
1,953,525,168
Operating temperature
0° to 60° C (32° to 140° F) [case temp]
Features
ATA Security
500GB 5400 rpm SATA FIPS Hard Drive
Specification
Drive weight
95 g (0.25 lbs)
Capacity
500GB
Height
7 mm (0.28 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Single Track: 1.5 ms
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16MB
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA Security
320GB 7200 rpm SATA Hard Drive
Specification
Drive weight
115 g (0.25 lbs)
Capacity
320GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
625,142,448
Features
ATA Security
500GB 7200 rpm SATA Hard Drive
Specification
Drive weight
115 g (0.25 lbs)
Capacity
500 GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 11 ms
  • Maximum: 22 ms
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA Security
1TB 7200 rpm SATA Hard Drive
Specification
Drive weight
115 g (0.25 lbs)
Capacity
1TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 11 ms
  • Maximum: 22 ms
Rotational speed
7200 rpm
Logical blocks
1,953,525,168
Features
ATA Security
500GB 7200 rpm SMART SATA II Self Encrypting Drive
Specification
Drive weight
115 g (0.25 lbs)
Capacity
500 GB
Height
9.5 mm (0.37 in)
Width
63.5 mm (2.50 in)
Interface
Transfer rate
  • Single Track: 1 ms
  • Average: 12 ms
  • Maximum: 20 ms
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA Security
SATA 6GB/s 128GB, 2.5-inch Solid State Drive
Specification
Drive weight
73 g
Capacity
128GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA 3 (6GB/s)
Performance
  • Maximum Sequential Read: Up to 415MB/s
  • Maximum Sequential Write: Up to 175MB/s
Logical blocks
250,069,680
0° to 70° C (32° to 158° F) [case temp]
Features
ATA Security; ATA-8 compliant; SATA 3.0; DIPM; TRIM
SATA 6GB/s 180GB, 2.5-inch SATA Solid State Drive
Specification
Drive weight
78 g
Capacity
180 GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA Gen 3 (6GB/s)
Performance
  • Maximum Sequential Read: Up to 550MB/s
  • Maximum Sequential Write: Up to 520MB/s
Logical blocks
351,651,888
Features
SATA 6GB/s 240GB, 2.5-inch Solid State Drive
Specification
Drive weight
78 g
Capacity
240 GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA Gen 3 (6GB/s)
Performance
  • Maximum Sequential Read: 550MB/s
  • Maximum Sequential Write: 520MB/s
Logical blocks
468,862,128
Features
SATA 6GB/s 180GB, 2.5-inch SATA SED Solid State Drive
Specification
Drive weight
78 g
Capacity
180 GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA Gen 3 (6GB/s)
Performance
Logical blocks
351,651,888
Features
ATA Security; ATA-8 compliant; SATA 3.0; DIPM; TRIM, TCG Opal Compliant
SATA 6GB/s 256GB, 2.5-inch SATA SED Solid State Drive
Specification
Drive weight
73 g
Capacity
256GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA 3 (6GB/s)
Performance
  • Maximum Sequential Read: Up to 460MB/s
  • Maximum Sequential Write: Up to 260MB/s
Logical blocks
500,118,192
Features
Security
HP Fingerprint Reader (optional)
Specification
Mobile Voltage Operation
3.0V-3.6V
Operating Temperature
-10° – 75° C (14° – 167° F)
Current Consumption Image
36 mA peak
Low Latency Wait for Finger
950 uA
Capture Rate
3000 lines/second
ESD Resistance
IEC 61000-4-2 4B (±15KV)
Detection Matrix
  • 200*1 (plus another secondary line)
  • 508 dpi
  • 12*3 mm sensor area
Smart Card Reader
Specification
Smart card standard
PC/SC 2.0 for Windows smart card standard
Dimensions (L x W x H)
10.5 x 2 x 8.2 mm (0.41 x 0.08 x 0.32 in)
Smart Card support
ISO 7816 Class A and AB smart cards
Smart Card Interface
  • Smart Card Interface with T = 0 and T = 1 support
  • Support I2C memory card, SLE4418, SLE4428, SLE4432, SLE4442, SLE4436, SLE5536, SLE6636, AT88SC1608, AT45D041 card and AT45DB041 card via external EEPROM
Operating systems
No driver is required for this device. Native support is provided by the operating system.
Power
Normal Mode
  • With card present, before being suspended: 40.9 mA
  • Without card present, before being suspended: 33.16 mA
  • With card present, after being suspended: 380 μA
  • Without card present, after being suspended: 380 μA
Power Saving Mode
  • With card present, before being suspended: 40.6 mA
  • Without card present: 380 μA
Features
  • Support single slot
  • Support T0, T1 protocol
  • Support ISO7816 Class A, B and C (5V/3V/1.8V) card
  • Implemented as an USB full speed device with bulk transfer endpoint
  • Mass Storage endpoint
  • Built-in PLL for USB and Smart Card clocks requirement
  • Support EEPROM for USB descriptors customization (PID/VID/ iManufacturer/iProduct/Serial Number), Direct Web Page Link, and accessing memory card module
  • EEPROM programmable via USB interface
  • Support software update for memory card module
  • Support Direct Web Page Link via configuration in external EEPROM
  • Support short APDU and extended APDU
  • Compatible with Microsoft USB-CCID driver
  • Support remote wake up through inserting card/removing card
  • Support USB selective suspend
  • Support Power Saving Mode (Using one pin to select between Normal/PWR Saving Mode)
  • Support card power over current protection mechanism
  • Built in resonator
  • Support USB LPM (Link Power Management) features
  • Embedded clock source
Networking/Communications
Networking
Integrated Realtek 10/100/1000 NIC
Specification
Ethernet Features
  • 10 Mbit/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mbit/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mbit/s operation (1000BASE-T; IEEE 802.3ab; IEEE 8023 clauses 40)
  • Auto-Negotiation (Automatic Speed Selection)
  • Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mbit/s
  • IEEE 802.1p QoS (Quality of Service) Support
  • IEEE 802.1q VLAN support
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
  • IEEE 802.3az EEE (Energy Efficient Ethernet)
  • Jumbo Frame 9K
  • Auto MDI/MDIX Crossover cable detection
Power Management
  • ACPI compliant - multiple power modes
  • Situation-sensitive features reduce power consumption
  • Advanced link down power saving for reducing link down power consumption
Performance Features
  • TCP/IP/UDP Checksum Offload (configurable)
  • Protocol Offload (ARP & NS)
  • Large send offload and Giant send offload
  • Receiving Side Scaling
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame); Wake-on-LAN from off (Magic Packet only)
  • PXE 2.1 Remote Boot
  • Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite
  • Virtual Cable Doctor for Ethernet cable status
Interface
PCI Express 1.1 x1 to fully support ASPM L0s/L1 and CLKREQ
NIC Device Driver Name
Realtek PCIe GBE Ethernet Family Controller
HP hs3110/3114 HSPA+ Mobile Broadband Module
Specification
Technology/Operating bands
  • HSPA+: 2100 (Band1)/1900 (Band 2)/1700 (Band 4)/850 (Band 5)/900 (Band 8) MHz
  • E-GPRS: 1900 (Band 2)/1800 (Band 3)/850 MHz (Band 5)/900 (Band 8) MHz
Wireless protocol standards
  • E-GPRS: Class B, Multi-slot class 33, coding schemes CS1 - CS4 and MSC1 - MSC9
  • UMTS/WCDMA: Release 99 and Release 7
GPS
Standalone, A-GPS
GPS Bands
1575.42 MHz ± 1.023 MHz, GLONASS 1596-1607 MHz
Maximum data rates
  • HSPA+: UL 5.76 Mbps / DL 21.6 Mbps
  • HSPA: UL 5.76 Mbps / DL 7.2 Mbps
  • WCDMA PS: UL 384 kbps / DL 384 kbps
  • WCDMA CS: UL 64 kbps / DL 64 kbps
  • E-GPRS: UL 236.8 kbps/DL 296 kbps
  • GPRS: UL 85.6 kbps / DL 107 kbps
Maximum output power
  • HSPA+ MHz: 24 dBm
  • E-GPRS 1800/1900: 26 dBm
  • E-GPRS 850/900: 27 dBm
  • GPRS 1800/1900: 30 dBm
  • GPRS 850/900: 33 dBm
Maximum power consumption
2500 mA (peak); 600 mA (average)
Form Factor
M.2, 3042-S3 Key B
6 g
Dimensions (Length x Width x Thickness)
42 x 30 x 2.3 mm (1.65 x 1.18 x 0.09 in)
HP lt4211 LTE/EVDO/HSPA+ Qualcomm Gobi 4G Module (Planned to be available July 2014)
Specification
  • LTE: 1900 (Band 2)/1700 (Band 4)/850 (Band 5)/700 (Band 13), 700 (Band 17), 1900 (Band 25) MHz
  • HSPA+: 2100 (Band 1)/1900 (Band 2)/1700 (Band 4)/850 (Band 5), 800 (Band 8) MHz
  • E-GPRS: 1900 (Band 2)/1800 (Band 3)/850 (Band 5)/900 (Band 8) MHz
  • EV-DO: 800 (BC0)/1900 (BC1) MHz
  • 3GPP Release 9 LTE Specification
  • WCDMA R99, 3GPP Release 5, 6 and 7 UMTS Specification
  • EVDO Release 0 and Release A
GPS
Standalone
GPS bands
1575.42 MHz, GLONASS 1602 MHz
Maximum data rates
  • LTE (Category 3): 100 Mbps (Download), 50Mbps (Upload)
  • DC-HSPA+: 42 Mbps (Download), 5.76 Mbps (Upload)
  • HSPA+: 21.6 Mbps (Download), 5.76 Mbps (Upload)
  • WCDMA PS: 384 kbs (Download), 384 kbs (Upload)
  • WCDMA CS: 64 kbs (Download), 64 kbs (Upload)
  • E-GPRS: 236.8 kbps (Download), 236.8 kbps (Upload)
  • GPRS: 85.6 kbps(Download), 85.6 kbps (Upload)
  • EV-DO Rev.B: 14.7 Mbps (Download), 5.4 Mbps (Upload)
  • EV-DO Rev.A: 3.1 Mbps (Download), 1.8 Mbps (Upload)
  • LTE: +23 dBm (+1/- 2 dBm)
  • HSPA+: +24 dBm (+1/- 2 dBm)
  • E-GPRS Band 1800/1900: +25 dBM (+/-1 dBm)
  • E-GPRS Band 850/900: +26 dBM (+/-1 dBm)
  • GPRS 1800/1900: +30 dBm (+1/-2 dBm)
  • GPRS 850/900: +32 dBm (+/- 1 dBm)
  • EV-DO: +24 dBM (+/-1 dBm)
  • LTE: 1,200 mA (peak);: less than 900 mA (average)
  • HSPA+: 1,100 mA (peak);: less than 800 mA (average)
  • E-GPRS: 2,800 mA (peak);: less than 500 mA (average)
  • EV-DO: 1000 mA (peak);: less than 700 mA (average)
Form Factor
M.2, 3042-S3 Key B
6 g
1.65 x 1.18 x 0.09 in (42 x 30 x 2.3 mm)
HP lt4112 LTE/HSPA+ Qualcomm Gobi 4G Module
Specification
  • LTE: 2100 (Band 1)/1900 (Band 2)/1800 (Band 3)/850 (Band 5), 2600 (Band 7), 900 (Band 8), 800 MHz (Band 20, DD800) MHz
  • HSPA+: 2100 (Band 1)/1900 (Band 2)/850 (Band 5)/900 (Band 8) MHz
  • 3GPP Release 8 LTE Specification
GPS
Standalone
GPS bands
1575.42 MHz ± 1.023 MHz, GLONASS 1596-1607MHz
Maximum data rates
  • EDGE: 236.8 kbps (Download), 236.8 kbps (Upload)
  • LTE: 23 dBm
  • HSPA+: 23.5 dBm
  • HSPA+E-GPRS 1900/1800: 26.5 dBM
  • E-GPRS 900/850: 27.5 dBM
  • GPRS 1900/1800: 29.5 dBm
  • GPRS 900/850: 32.5 dBm
  • LTE: 1,200 mA (peak); 900 mA (average)
  • HSPA+: 1,100 mA (peak); 800 mA (average)
  • E-GPRS: 2,800 mA (peak); 700 mA (average)
Form Factor
M.2, 3042-S3 Key B
6 g
Broadcom 802.11a/b/g/n (2x2) and Bluetooth 4.0
Specification
Wireless LAN Standards
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency Band
  • 802.11b/g/n
    • 2.402 – 2.482 GHz
  • 802.11a/n
    • 4.9 - 4.95 GHz (Japan)
    • 5.15 - 5.25 GHz
    • 5.25 - 5.35 GHz
    • 5.47 - 5.725 GHz
    • 5.825 - 5.850 GHz
    • 2.402 - 2.482 GHz
Data Rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54Mbps
  • 802.11b: 1, 2, 5.5, 11Mbps
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54Mbps
  • 802.11n: MCS 0 ~ MCS 15, (20MHz, and 40MHz)
Modulation
  • Direct Sequence Spread Spectrum
  • BPSK, QPSK, CCK, 16-QAM, 64-QAM
Security
  • IEEE and WiFi compliant 64/128-bit WEP encryption for a/b/g mode only
  • AES-CCMP: 128 bit in hardware
  • 802.1x authentication
  • WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES
  • WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through V5
  • WAPI
Network Architecture Models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between access points
Output Power
  • 2.4G: +13.5dBm minimum
  • 5G: +12dBm minimum
  • Maximum output power must be able to achieve modular regulatory certification with notebooks that have antennas greater than 20cm from the user and peak gain of +3dBi at 2.4GHz and +4dBi at 5GHz
Power Consumption
  • Transmit: 2.0 W (max)
  • Receive: 1.6 W (max)
  • Idle associated: 250 mW
  • Idle unassociated: 100 mW
  • Radio disabled: 75 mW
Power Management
  • ACPI and PCI Express compliant power management
  • 802.11 compliant power saving mode
Receiver Sensitivity
  • 11b:
    • -95 dBm at 1Mbps
    • -93 dBm at 2Mbps
    • -91 dBm at 5.5Mbps
    • -88 dBm at 11Mbps
  • 11a/g:
    • -90 dBm at 6Mbps
    • -89 dBm at 9Mbps
    • -87 dBm at 12Mbps
    • -85 dBm at 18Mbps
    • -82 dBm at 24Mbps
    • -79 dBm at 36Mbps
    • -76 dBm at 48Mbps
    • -74 dBm at 54Mbps
  • 11n:
    • -69 dBm at 72.2Mbps
    • -66 dBm at 300Mbps
Antenna type
  • High efficiency antenna with spatial diversity, mounted in the display enclosure
  • Two embedded dual band 2.4/5 GHz antennas are provided to the card to support WLAN MIMO communications and Bluetooth communications
Form Factor
PCI-Express Half-MiniCard
3.1 g
Dimensions
4.75 x 26.8 x 30 mm (0.19 x 1.06 x 1.18 in)
Operating Voltage
3.3v +/- 9%
Temperature
  • Operating: -10° to 70° C (14° to 158° F)
  • Non-operating: -40° to 80° C (-40° to 176° F)
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 95% (non-condensing)
Altitude
  • Operating: 0 to 3,048 m (10,000 ft)
  • Non-operating: 0 to 15,240 m (50,000 ft)
LED Activity
LED Off – Radio OFF
Solid LED On – Radio ON
Bluetooth Specification
V4.0 High Speed, V2.1+EDR, backwards compatible with V1.1, 1.2 and 2.0
Number of Available Channels
79 (1 MHz) available channels
Data Rates and Throughput
  • 3 Mbps data rate; throughput up to 2.17 Mbps
  • Synchronous Connection Oriented links up to 3, 64 kbps, voice channels
  • Asynchronous Connection Less links 2178.1 kbps/177.1 kbps asymmetric or 1306.9 kbps symmetric
Transmit Power
-6 dBm to 4 dBm (Bluetooth Class II)
Better than -80 dBM at 0.1 % raw bit error rate
Power Consumption
  • Peak (Tx) 330 mW
  • Peak (Rx) 230 mW
  • Sleep less than 17 mW
Antenna
Internally integrated within module
Range
Up to 10 m (33 ft)
Electrical Interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Bluetooth Software Supported
  • Broadcom Bluetooth for Windows
  • Microsoft Windows Bluetooth Software
Link Topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Security
Full support of Bluetooth Security Provisions
Power Management
  • Microsoft Windows ACPI, and USB Bus Support
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Bluetooth Profiles Supported
  • Generic Access Profile (GAP)
  • Service Discovery Application Profile (SDAP)
  • Serial Port Profile (SPP)
  • Dial_Up Networking Profile (DUN)
  • Generic Object Exchange Profile (GOEP)
  • Object Push Profile (OPP)
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)
  • Personal Area Networking Profile (PAN)
  • Human Interface Device Profile (HID)
  • Generic Audio/Video Distribution Profile (GAVDP)
  • Advanced Audio/Video Distribution Profile (A2DP)
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Basic Printing Profile (BPP)
  • Video Distribution Profile (VDP)
  • Audio Video Remote Control Profile (AVRCP)
Atheros 802.11 b/g/n (1x1)
Specification
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency Band
2.4 GHz
Data Rates
  • 802.11n: many possible data rates, ranging from 6 Mbps to 300 Mbps, depending on the combination of Bandwidth, Modulation Coding Scheme, and Guard Interval used, as defined in IEEE 802.11n specification
Modulation
  • DBPSK, DQPSK, CCK, OFDM, BPSK, QPSK, 16-QAM, 64-QAM
Security
Supports 64- and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAPMSCHAPv2, LEAP, EAP-FAST
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations
Media Access Protocol
CSMA/CA (Collision Avoidance) with ACK
Roaming
Output Power
13.5 dBm, nominal
Power Consumption
  • Transmit:: 2.0 W (max)
  • Associated to Access Point, Idle: 250 mW nominal
  • Wireless Button Off: 100 mW nominal
  • Radio disabled: 75 mW nominal
Power Management
  • ACPI compliant power management
  • 72.2 Mbps: -70 dbm
  • 54 Mbps: -74 dBm
  • 11 Mbps: -88 dBm
  • 1 Mbps: -95 dBm
Antenna type
High efficiency dual antenna with spatial diversity, usually mounted in the display enclosure
Form Factor
PCI-Express Half-MiniCard 1.2
6 g (0.013 lb)
Dimensions
Operating Voltage
3.3v +/- 9%
Temperature
Humidity
Altitude
LED Activity
LED Off - Radio OFF
Solid LED On - Radio ON
Audio/Multimedia - DTS sound
Specification
Implementation
IDT 92HD91
Volume Controls
Volume up, volume down, and mute
Full duplex
Yes
Microphone in
Stereo
Headphone/line out
Stereo
Integrated microphone
Yes, dual digital microphone array when equipped with optional webcam
Audio output quality
Frequency response
20 Hz – 20 kHz
Signal to noise ratio
Greater than 85 dB
Total harmonic distortion
0.01%
Noise floor
- 110 dB
Play/Record sampling rate(s)
8 kHz – 48kHz
DAC
16, 20 or 24-bit
ADC
16 or 20-bit
Integrated stereo speakers
Power rating
2 W
Impedance
4 ohms
Power
HP 45W Slim Smart AC Adapter non-slim
Specification
Dimensions (H x W x D)
95.0 x 40.0 x 26.5 mm
Input
  • 90 to 265 VAC
  • Input Efficiency: 88% min at 115 VAC / 89% min at 230VAC
  • Input frequency range: 47 to 63 Hz
  • Input AC current: 1.4 A at 90 VAC and maximum load
Output
  • Output power: 45W
  • DC output: 19.5V
  • Hold-up time: 5 msec at 115 VAC input
  • Output current limit: Less than 8A, Over voltage protection- 29V max automatic shutdown
Connector
3 pin/grounded, mates with 4.5mm barrel type Smart ID DC connector
Environmental design
  • Operating temperature: 0° to 35° C (32° to 95° F)
  • Non-operating (storage) temperature: -20° to 85° C (-4° to 121° F)
  • Altitude: 0 to 5,000 m (0 to 16,405 ft)
  • Humidity: 0% to 95%
  • Storage Humidity: 0% to 95%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; Reliability - failure rate of less than 0.1% annually within the first three years of operation.
HP 65W EM Smart AC Adapter
Specification
12.65 x 5.0 x 3.0 cm (4.98 x 1.97 x 1.18 in)
290 g (0.62 lb) max
Input
  • 90 to 265 VAC
  • Input Efficiency: 87% min at 115 VAC
  • Input AC current: 1.7 A at 90 VAC
Output
  • Output power: 65W
  • DC output: 19.5V
  • Output current limit: Less than 11A, Over voltage protection- 29V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
  • Non-operating (storage) temperature: -20° to 85° C (-4° to 185° F)
  • Altitude: 0 to 3,048 m (0 to 10,000 ft)
  • Humidity: 20% to 95%
  • Storage Humidity: 10% to 95%
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF - over 200,000 hours at 25°C ambient condition.
HP 65W Slim Smart AC Adapter
Specification
120.0 x 57.6 x 16.7 mm
250 g
Input
  • 90 to 265 VAC
Output
  • Output power: 65W
  • DC output: 18.5V
Connector
  • Operating temperature: 0° to 40° C (32° to 104° F)
  • Non-operating (storage) temperature: -20° to 65° C (-4° to 149° F)
  • Humidity: 20% to 80%
  • Storage Humidity: 10% to 90%
3-cell HP Long Life (24WHr) Lithium-Ion Polymer
Specification
Dimensions (H x W x L)
2.16 x 4.46 x 26.9 cm (0.85 x 1.76 x 10.59 in)
169.3 g
Cells/Type
3-cell Lithium-Ion Polymer
Energy
  • Voltage: 11.1
  • Amp-hour capacity: 4.4Ah
  • Watt-hour capacity: 24Wh
Temperature
  • Operating (Charging): 0° to 45° C (32° to 113° F)
  • Operating (Discharging): -10° to 50° C (14° to 122° F)
  • Non-operating: -20° to 50° C (-4° to 122° F)
Fuel Gauge LED
No
1 year or 3 years
Optional Travel Battery Available
No
3-cell HP Long Life (26WHr) Lithium-Ion Polymer
Specification
168.5 g
Cells/Type
Energy
  • Voltage: 11.1
  • Watt-hour capacity: 26.3Wh
Temperature
Fuel Gauge LED
No
1 year or 3 years
No
3-cell HP Long Life (46WHr) Lithium-Ion Polymer
Specification
259 g
Cells/Type
Energy
  • Voltage: 11.1
  • Watt-hour capacity: 46Wh
Temperature
Fuel Gauge LED
No
1 year or 3 years
No
3-cell HP Long Life (50WHr) Lithium-Ion Polymer
Specification
262 g
Cells/Type
Energy
  • Voltage: 11.1
  • Watt-hour capacity: 50Wh
Temperature
Fuel Gauge LED
No
1 year or 3 years
No
HP 6-cell Lithium-Ion Long Life Slice Battery (60 WHr)
Specification
0.7 x 32 x 21.3 cm (0.28 x 12.6 x 8.39 in)
0.78 kg (1.72 lb)
Cells/Type
6-cell Lithium-Ion
Energy
  • Voltage: 11.4V
  • Amp-hour capacity: 5.4Ah
  • Watt-hour capacity: 60Wh
Temperature
Battery Re-Charge Time
  • System in OFF or Standby Mode: 3.5 to 5 hours
  • System ON: 4 to 7 hours
Fuel Gauge LED
No
No
