HP ProBook 440 G2 Notebook PC
HP ProBook 450 G2 Notebook PC
- ${title}
- ${title}
- ${title}
- ${title}
HP ProBook 440, 450 G2 Notebook PC Specifications
Product image
Product features
Feature
Processors
note: note: |
Integrated with processor
Graphics
Integrated:
Switchable Discrete:
note: |
Internal
External
VGA
HDMI
note: |
Storage and drives
Primary Storage Bay
note: |
Optical drives
Fixed 9.5 mm SATA optical drive
note: |
Memory
Standard
Maximum
Dual-channel
note: |
Networking/Communications
note: |
Audio/Multimedia
Audio
Optional* 720p HD** webcam
note: |
Keyboard/Pointing devices/Buttons and function keys
System specifications
Specification
Stand-Alone power Requirements (AC Power)
Nominal operating voltage: 19 V
Average Operating Power
Windows 7 (64-bit)
Windows 8 (64-bit)
ProBook 440 Integrated
graphics
TBD W
TBD W
ProBook 440 Discrete
graphics
TBD W
TBD W
ProBook 450 Integrated
graphics
TBD W
TBD W
ProBook 450 Discrete
graphics
TBD W
TBD W
Max Operating Power
Temperature
Operating
Non-operating
Relative humidity
Shock
Random Vibration
Altitude (unpressurized)
Planned industry
standard
certifications
note: |
Display specifications
Specification
Dimensions (W x H)
32.09 x 18.76 cm (12.63 x 7.39 in)
320g (0.71 lb) (max)
Diagonal size
35.6cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
400:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
Backlight
LED
PPI
112 ppi
Viewing angle
Specification
Dimensions (W x H)
34.39 x 19.41 cm (13.54 x 7.64 in )
500g max.
Diagonal size
39.6 cm (15.6 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
Backlight
LED
PPI
106 ppi
Viewing angle
Specification
Dimensions (W x H)
36.0 x 22.43 cm (14.17 x 8.83 in)
500g max.
Diagonal size
39.6 cm (15.6 in)
Surface treatment
Anti-glare
Contrast ratio
400:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
Backlight
LED
PPI
106 ppi
Viewing angle
Specification
Dimensions (W x H)
38.2 x 21.5 cm (15.0 x 8.5 in)
570g max.
Diagonal size
43.9 cm (17.3 in)
Surface treatment
Anti-glare
Contrast ratio
400:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
Backlight
LED
PPI
106 ppi
Viewing angle
HDD specifications
Specification
Drive Weight
115 g (0.25 lbs)
Capacity
750 GB
Height
9.5 mm (0.37 in)
Width
63.5 mm (2.50 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer Rate
Synchronous (maximum): 300 MB/s (drive capability)
Seek Time
Rotational Speed
7200 rpm
Logical Blocks
1,465,149,168
Operating Temperature
0° to 60° C (32° to 140° F) [case temp]
Features
ATA Security
Specification
Drive Weight
115 g (0.25 lbs)
Capacity
320 GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer Rate
Seek Time
Rotational Speed
7200 rpm
Logical Blocks
625,142,448
Features
ATA Security
Specification
Drive Weight
101 g (0.22 lbs)
Capacity
500 GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer Rate
Synchronous (maximum): 300 MB/s (Drive Capability)
Seek Time
Rotational Speed
5400 rpm
Logical Blocks
976,773,168
Features
ATA Security
Specification
Drive Weight
101 g (0.22 lbs)
Capacity
750 GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer Rate
Seek Time
Rotational Speed
5400 rpm
Logical Blocks
1,465,149,168
Features
ATA Security
Specification
Drive Weight
115 g (0.254 lbs)
Capacity
1 TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer Rate
Seek Time
Rotational Speed
5400 rpm
Logical Blocks
1,953,525,168
Features
ATA Security
Specification
Drive Weight
118 g (0.26 lbs)
Capacity
1.5 TB
Height
9.5 mm (0.37 in)
Width
63.5 mm (2.5 in)
Interface
Transfer Rate
Seek Time
Rotational Speed
5400 rpm
Logical Blocks
293,0277,168
Features
ATA Security
Specification
Drive Weight
95 g (0.209 lb)
Capacity
500 GB
Height
7 mm (0.276 in)
Width
70.1 mm (2.76 in)
Interface
ATA-8, SATA 2.6, 6.0 Gb/s, NCQ
Transfer Rate
Synchronous (maximum): 600 MB/s (Drive Capability)
Seek Time
Rotational Speed
5400 rpm
Logical Blocks
976,773,168
Features
ATA Security
Specification
Drive Weight
73 Grams
Capacity
128 GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Transfer Rate
Performance
Logical Blocks
250,069,680
0° to 70° C (32° to 158° F) [case temp]
Features
ATA Security; ATA-8; SATA 3.0; DIPM; TRIM
Specification
Drive Weight
< 10 Grams
Capacity
120 GB
Height
22 mm (0.276 in)
Width
42 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Transfer Rate
Performance
Logical Blocks
234,441,648
Features
ATA Security; ATA-8; SATA 3.0; TRIM
note:* For storage drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30GB (for Windows 8) of system disk is reserved for system recovery software.
Security
Specification
Mobile voltage operation
3.0V-3.6V Single Supply
Operating temperature
0° - 70°C (32° - 158°F)
Current consumption at
3.3 V
High-rate image capture
Up to 240 image frames /sec
ESD resistance
IEC 61000-4-2 Level 4 (±15KV)
Detection matrix
Specification
Ethernet Features
Power
Management
Performance Features
Manageability
Interface
PCI Express 1.1to fully support ASPM L0s/L1 and CLKREQ
NIC Device Driver Name
Realtek PCIe GBE Ethernet Family Controller
Specification
Technology/Operating bands
Wireless protocol standards
GPS
GPS Standalone, A-GPS: L1 (Internet- and Network assisted)
Wireless parametric standards
Complies with 3GPP specifications
Maximum data rates
Maximum output power
Maximum power consumption
2500mA (peak); 600mA (average)
Power consumption, sleep mode
3.6 mA
Power management
Antenna type
Dual high efficiency 5 band antennae with spatial diversity, mounted in the display enclosure
Form Factor
< 6 g
Dimensions
(Length x Width x Thickness)
42 x 30 x 2.3 mm (2.01 x 1.18 x 0.18 in)
SIM card supply voltage
1.8 V/3.0 V UICC (SIM/UICC/USIM)
Voltage, Operating
3.135V~4.4V (3.3 V recommended)
Temperature, operating
Temperature, storage
-40° to 85° C (-40° to 185° F)
Humidity
5% to 95%
Configuration utilities
HP Connection Manager
LED activity
note: |
Specification
Complies with 3GPP specifications Release 8 for LTE
Maximum data rates
GPS
Standalone
GPS bands
1575.42 MHz (± 1.023 MHz), GLONASS 1596-1607MHz
3 mA
Power management
USB selective suspend, Integrated notebook wireless button
Antenna type
Dual high efficiency multi-band antennae with spatial diversity
Form Factor
M.2, USB 2.0 interface
6 g
Dimensions
42 × 30 × 2.3 mm
Voltage, Operating
3.135 to 4.4 V (3.3 +1.1V/-0.165V)
Temperature, operating (from TIA/EIA/IS-98-D)
–10° to 55° C (14° to 131° F)
Temperature, non-operating 96 hours (from MIL-STD 202 Method 108)
–40° to 85° C (-40° to 185° F)
Humidity, non-operating
95% relative humidity for 48 hours @ 85° C (185° F) (non-condensing)
LED activity
note: |
Specification
Wireless LAN Standards
Interoperability
Wi-Fi certified
Frequency Band
2.402 – 2.482 GHz
Data Rates
Modulation
Security1
Network Architecture
Models
Roaming
IEEE 802.11 compliant roaming between access points
Output Power2
13.5 dBm, nominal
Power Consumption
Power Management
Receiver Sensitivity3
Antenna type
High efficiency antenna with spatial diversity, mounted in the display enclosure
Form Factor
PCI-Express Half-MiniCard
Dimensions
4.75 x 26.8 x 30 mm (0.19 x 1.06 x 1.18 in)
Operating Voltage
3.3v +/- 9%
Temperature (from TIA/EIA/IS-98-D)
Humidity
Altitude
LED activity
note: |
Specification
Dimensions (H x W x D)
Diversity
No diversity support
Radio ON/OFF Control
Supported in both hardware and software
Connector interface
LED Output
On/Off
Operating Temperature (Adapter Shield)
0° to +80° C
Humidity (Non-Operating)
50% to 90% RH non-condensing (at temperatures of 25°C to 35°C)
Operating Systems
Microsoft Windows 7, Microsoft Windows 8, Linux
Wi-Fi Alliance
Microsoft WHQL
Yes
IEEE WLAN Standard
Architecture
Infrastructure and SoftAP; Supports simultaneous Client and SoftAP modes in 2.4 GHz or 5GHz
Roaming1
ACPI and PCI Express compliant power management
802.11 compliant power saving mode
Authentication
Authentication Protocols
Encryption
Wi-Fi Direct Encryption and Authentication
Product Safety
Management Frame Protection
802.11w (WFA- Protected Management Frames)
Retail (Credit Card Processing)
Government
note: |
Specification
Bluetooth Specification
Dual Mode Bluetooth* 2.1, 2.1+EDR, 3.0, 3.0+HS, 4.0 (BLE)
Dimensions
30 x 6.5 x 3.25 mm (1.18 x 0.26 x 0.13 in)
Frequency Band
2402 to 2480 MHz
Number of Available Channels
79 (1 MHz) available channels
Data Rates and Throughput
Transmit Power
-1.5 dBm to 4 dBm (Bluetooth Class II)
Better than -20 dBM at 0.1 % raw bit error rate
Power Consumption
Antenna
Internally integrated within module
Range
Up to 10 m (33 ft)
Electrical Interface
Bluetooth Software Supported
Link Topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Security
Full support of Bluetooth Security Provisions
Power Management
Certifications
All necessary regulatory approvals for supported countries, including:
Temperature
Humidity
Altitude
Bluetooth Profiles Supported
note: |
Ports/slots
Specification
Ports
Digital media slots
Multi Media Reader slot supporting:
Optical drives
Blu-ray ROM DVD+/-RW SuperMulti DL Drive*†
DVD-ROM Drive
No optical drive option
note:* Sold separately as an optional feature.† For Blu-ray drives, certain disc, digital connection, compatibility and/or performance issues may arise, and do not constitute defects in the product. Flawless playback on all systems is not guaranteed. In order for some Blu-ray titles to play, they may require an HDMI digital connection and your display may require HDCP support. HD-DVD disks cannot be played on this drive. Note that DVD-RAM cannot read or write to 2.6GB Single Sided/5.2 GB Double Sided – Version 1.0 media. Actual speeds may vary. Don’t copy copyright-protected materials. Double Layer discs can store more data than single layer discs; discs burned with this drive may not be compatible with many existing single-layer DVD drives and players.
Audio/Multimedia - DTS sound+
Specification
Implementation
Realtek ALC3227-CG
Function key volume controls
Volume up, volume down, and mute
Full duplex
Yes
Microphone in
Stereo
Headphone/line out
Stereo
Integrated microphone
Yes, dual digital microphone array
Audio output quality
Frequency response
10 Hz – .454*Fs
Signal to noise ratio
95 dB (DAC), 88dB (ADC)
Total harmonic distortion
0.01%
Play/Record sampling
rate(s)
44.1k/48k/96k/192kHz
DAC
16, 20 or 24-bit
ADC
16, 20 or 24-bit
Internal stereo speakers
Power rating
2 W
Impedance
4 ohms
Power
Implementation: Realtek ALC3227-CG
Function Key Volume Controls: Volume up, volume down, and mute
Full Duplex: Yes
Microphone In: Stereo
Headphone/Line: Out Stereo
Integrated Microphone: Yes, dual digital microphone array
Frequency Response: 10 Hz – .454*Fs
Signal to Noise Ratio: 95 dB (DAC), 88dB (ADC)
Total Harmonic Distortion: 0.01%
Play/Record Sampling Rate(s): 44.1k/48k/96k/192kHz
DAC: 16, 20 or 24-bit
ADC: 16, 20 or 24-bit
Integrated Stereo Speakers
Power Rating: 2 Watts
Impedance: 4 Ohms
Physical specifications
Feature
Weights and dimensions
Software/OS
Feature
Preinstalled operating system
note: |
Preinstalled software with windows operating system
Windows 8.1
Windows 7
note: |
Security
Standard
Optional
note: |
Power
Power supply
Primary battery
Battery life
System standby time*
Power conservation
Supports enhanced Intel SpeedStep technology (allows Battery Optimized Mode, Maximum Performance Mode, or Automatic mode)
AMD PowerPlay technology (discrete models)
Hibernation
Standby
ACPI compliance
note:HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Environmental
Material usage
This product does not contain any of the following substances in excess of regulatory limits (for reference of these limits please refer to the HP General Specification of the Environment (http://www.hp.com/hpinfo/globalcitizenship/environment/supplychain/gen_specifications.html):
Asbestos
Certain Azo Colorants
Certain Brominated Flame Retardants – may not be used as flame retardants in plastics
Cadmium
Chlorinated Hydrocarbons
Chlorinated Paraffins
Formaldehyde
Halogenated Diphenyl Methanes
Lead carbonates and sulfates
Lead and Lead compounds
Mercuric Oxide Batteries
Ozone Depleting Substances
Polybrominated Biphenyls (PBBs)
Polybrominated Biphenyl Ethers (PBBEs)
Polybrominated Biphenyl Oxides (PBBOs)
Polychlorinated Biphenyl (PCB)
Polychlorinated Terphenyls (PCT)
Polyvinyl Chloride (PVC) – except for wires and cables, and certain retail packaging has been voluntarily removed from most applications.
Radioactive Substances
Tributyl Tin (TBT), Triphenyl Tin (TPT), Tributyl Tin Oxide (TBTO)
Nickel finishes that release greater than 0.5 μgrams/cm2/week, measured according to EN 1811:1998, are not used on any product surface designed to be frequently handled or touched by users.
Packaging usage
HP follows these guidelines to decrease the environmental impact of product packaging:
Eliminate the use of heavy metals such as lead, chromium, mercury and cadmium in packaging materials.
Eliminate the use of ozone-depleting substances (ODS) in packaging materials.
Design packaging materials for ease of disassembly.
Maximize the use of post-consumer recycled content materials in packaging materials.
Use readily recyclable packaging materials such as paper and corrugated materials.
Reduce size and weight of packages to improve transportation fuel efficiency.
Plastic packaging materials are marked according to ISO 11469 and DIN 6120 standards.
End-of-life management and recyling
Hewlett-Packard offers end-of-life HP product return and recycling programs in many geographic areas. To recycle your product, please go to: hp.com/go/reuse-recycle or contact your nearest HP sales office. Products returned to HP will be recycled, recovered or disposed of in a responsible manner.
The EU WEEE directive (2002/95/EC) requires manufacturers to provide treatment information for each product type for use by treatment facilities. This information (product disassembly instructions) is posted on the Hewlett Packard web site at: hp.com/go/recyclers. These instructions may be used by recyclers and other WEEE treatment facilities as well as HP OEM customers who integrate and re-sell HP equipment.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
