Removing and Replacing the Top Cover for HP Pavilion 14-v000 Notebook PCs
This document applies to HP Pavilion 14-v000 notebook computers.
Before you begin
  • Have a Phillips head screwdriver and a nonmetallic prying tool.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
Video overview
The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures apply to all configurations for all HP Pavilion 14-v000 notebook computers.
Removing the top cover
Follow the steps in this section to remove the top cover.
  warning:
Step 1
Remove the battery.
For instructions to remove the battery, see the HP support document, Removing and Replacing the Battery for HP Pavilion 14-v000 Notebook PCs.
Removing the battery
Step 2
Remove optical drive.
For instructions to remove the optical drive, see the HP support document, Removing and Replacing the Optical Drive for HP Pavilion 14-v000 Notebook PCs.
Removing the optical drive
Step 3
Remove the service cover by loosening the two captive Phillips-head screws that secure the service cover to the base enclosure.
Location of P1 Phillips-head screws
Step 4
Release the retention tabs that secure the service cover to the base enclosure and remove.
Lifting the service cover
Step 5
Remove the rear corner covers.
On the bottom of the notebook, pry up the two rubber feet from the rear corners.
Prying off feet
Step 6
Remove the Phillips-head screws that secure each of the corner covers to the base enclosure.
Location of Phillips-head screws
Step 7
Carefully lift the corner covers to disengage the tabs that secure them to the base enclosure and remove.
Lifting the corner covers
Step 8
Remove the eleven Phillips-head screws that secure the top cover to the base enclosure.
Locations of 11 Phillips-head screws securing top cover to base enclosure
Step 9
Remove the Phillips-head screw from the optical drive bay that secures the top cover to the base enclosure.
Location of screw that secures the top cover to the base
Step 10
Turn the computer over and open the display panel.
Opening display panel
Step 11
Carefully separate the edges of the top cover from the base enclosure.
Carefully prying the top cover from the base
Step 12
Gently lift the front edge of the top cover until you have access to the touchpad board ZIF connector on the system board.
Location of the touchpad board ZIF connector
Step 13
Using minimal force, lift the locking bar up on the touchpad board ZIF connector...
Lifting the locking bar on the touchpad board ZIF connector
... and disconnect the touchpad board ribbon cable from the system board.
Removing the touchpad ribbon
Step 14
Find the keyboard ribbon cable connector.
Location of keyboard ZIF connector
Step 15
Using minimal force, lift the locking bar up on the keyboard ZIF connector...
Unlocking keyboard locking bar
...then carefully disconnect the keyboard ribbon cable from the system board.
Removing keyboard ribbon cable
Step 16
Using minimal force, lift the locking bar up on the power button board ZIF connector...
Lifting locking bar on power button board ZIF connector
...then disconnect the power button board ribbon cable from the system board.
Disconnecting power button board ribbon cable
Step 17
Remove the top cover.
Lifting top cover
Replacing the top cover
Use the steps in this section to replace the top cover.
Step 1
If installing a new top cover, there are a few preliminary steps to take. First remove the power button board and touchpad board from the old top cover and install them onto the new top cover.
Power button board and touchpad board
For instructions to remove and install the power button board see Removing and Replacing the Power Button Board for HP Pavilion 14-v000 Notebook PCs .
Location of the power button board
For instructions to remove and install the touchpad board see Removing and Replacing the Touchpad Board for HP Pavilion 14-v000 Notebook PCs .
Step 2
Place the top cover into position on the base enclosure so that you have access to the keyboard, touchpad, and power button board ZIF connectors on the system board.
Placing top cover into position
Step 3
Carefully insert the power button board ribbon cable into the power button board ZIF connector on the system board...
Placing the power button ribbon
...and gently press the locking bar down to lock the cable into place.
Pressing down the locking bar on the power button board cable
Step 4
Insert the keyboard ribbon cable into the keyboard ZIF connector on the system board...
Replacing the keyboard ribbon
... and press the locking bar down to lock the cable into place.
Relocking the keyboard ribbon
Step 5
Gently insert the touchpad button board ribbon cable into the touchpad button board ZIF connector on the system board...
Replacing touchpad button board ribbon
...and carefully press the locking bar down to lock the cable into place.
Closing touchpad ribbon locking bar
Step 6
Apply moderate pressure to the edges of the top cover to snap it into place.
Gently pressing down on top cover to snap it into place
Step 7
Close the display panel and turn the notebook over.
Bottom of notebook
Step 8
Replace the Phillips-head screw that secures the top cover to the base enclosure.
Step 9
Replace the eleven Phillips-head screws that secure the top cover to the base enclosure.
Locations of the eleven Phillips-head screws
Step 10
Replace the rear-corner covers by aligning them with the base enclosure...
Aligning the rear corner covers
...and pressing down on the corner covers to secure them into position.
Pressing corner cover into place
Step 11
Replace the two Phillips-head screws that secure the corner covers to the base enclosure.
Location of screws that secure corner covers
Step 12
Replace the two rubber feet onto the rear corners of the base enclosure.
Pressing the rubber feet into the rear corners
Step 13
Replace the service cover.
Fit the tabs on the rear edge of the service cover into the base enclosure...
Placing the service cover tabs into the base enclosure
...and apply pressure to the service cover to snap it into place.
 Applying pressure to the service cover to snap it into place
Step 14
Tighten the two captive Phillips-head screws that secure the service cover to the base enclosure.
Location of the screw holes for the screws that secure the service center to the base enclosure
Step 15
Replace the optical drive.
For instructions to replace the optical drive, see the HP support document, Removing and Replacing the Optical Drive for HP Pavilion 14-v000 Notebook PCs.
Replacing the optical drive
Step 16
Replace the battery.
For instructions to replace the battery, see the HP support document, Removing and Replacing the Battery for HP Pavilion 14-v000 Notebook PCs.
Replacing the battery
