HP Pavilion 15-p027tx Notebook PC - Product Specifications
Product Name
Product Number
J2C46PA
1.9 GHz Intel Core i3-4030U with Intel HD Graphics 4400
Microprocessor Cache
3 MB cache
Memory
4 GB 1600 MHz DDR3L SDRAM (1 x 4 GB)
Video Graphics
NVIDIA GeForce 830M (2 GB DDR3 dedicated)
15.6" diagonal HD BrightView LED-backlit (1366 x 768)
Hard Drive
1 TB 5400 rpm SATA
Multimedia Drive
SuperMulti DVD burner
Network Card
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth 4.0 combo
Sound
Beats Audio with 2 speakers
Keyboard
Full-size textured island-style with numeric keypad
Pointing Device
PC Card Slots
External Ports
  • 2 USB 3.0
  • 1 HDMI
  • 1 RJ-45
  • 1 headphone/microphone combo
Dimensions
38.45 x 26.02 x 2.39 cm
Starting at 2.27 kg
Power
65 W AC power adapter
4-cell (41 WHr) Li-ion
What's In The Box
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
Operating System:
Windows 8.1 (64 bits)
