    Looking for Site Help?
HP LaserJet Pro MFP M435nw - Replace the Tray 1 Roller and Separation Pad
To see a short video demonstrating this procedure, click here.
This video shows only replacement of the Tray 1 roller. The following procedure describes replacement of the Tray 1 roller and the separation pad.
Before you begin
  • Use the table below to identify the correct kit part number for your product, and then go to www.hp.com/buy/parts to order the kit.
    Kit part number
    A3E42–65018
    Tray 1 roller kit with instruction guide
Required tools
  • #2 phillips screwdriver with a magnetic tip and a 152-mm (6-inch) shaft length.
Always use a Phillips screwdriver. Do not use a pozidrive screwdriver or any motorized screwdriver. These can damage screws or screw threads.
Step 1 - Remove the Tray 1 Roller
  1. Do the following:
    1. Turn off the product.
    2. Disconnect the power cord.
      warning:
    Turn the product off, wait five seconds, and then remove the power cord before attempting to service the product.
  2. Open the cartridge door and locate the tray 1 pickup roller.
  3. Push out the two black tabs.
  4. Remove the tray 1 pickup roller.
Step 2 - Unpack the Replacement Roller
Unpack the replacement roller from the packaging.
If your part requires return or recycling, go to Product return and recycling.
HP recommends responsible disposal of defective rollers.
Step 3 - Install the Replacement Roller
  1. Install the replacement roller.
  2. Close the cartridge door.
Step 4 - Remove the Tray 1 Separation Pad Assembly
  1. Grasp the handles and then open the multi-purpose tray door.
  2. Release the two levers.
  3. Lift the input bin.
  4. Remove one screw.
  5. Remove the tray 1 separation pad assembly.
Step 5 - Unpack the Replacement Separation Pad Assembly
Unpack the replacement separation pad assembly from the packaging.
HP recommends responsible disposal of the defective separation pad assembly.
Step 6 - Install the Replacement Separation Pad Assembly
  1. Install the tray 1 separation pad assembly.
  2. Replace the screw.
  3. Lower the input bin.
  4. Latch the input bin in place.
  5. Close the multi-purpose tray door.
  6. Do the following:
    1. Connect the power cable.
    2. Turn on the product.
Country: Flag Serbia
