HP Officejet Enterprise Color X555, MFP X585 - Replace the formatter-access cover
This document provides the procedure to replace the formatter-access cover for the HP Officejet Enterprise Color X555 and HP Officejet Enterprise Color MFP X585/X585 Flow.
Figure : Formatter access cover
  1. Turn off the product, and then disconnect the power cable.
    Figure : Turn off product, disconnect power cable
  2. Disconnect either the USB cable or the network ethernet cable.
    Figure : Disconnect cables
  3. Remove the output bin by pulling up on the edge of the bin closest to the output flap, tilting it away from the product, and then pulling the assembly up.
    Figure : Remove the output bin
  4. Disconnect the thumbscrew, and then pull the access cover up.
    Figure : Remove the access cover
  5. Remove the new access cover from its packaging, and then reuse the packaging to send the old cover to a recycling center.
    Figure : Unpackage the new access cover and recycle the old one
  6. Install the new formatter access cover by sliding it down into place and then fastening the thumbscrew.
    Figure : Install the new cover
  7. Reinstall the output bin.
    Figure : Install the output bin
  8. Reconnect either the USB cable or the network cable.
    Figure : Reconnect cable
  9. Reconnect the power cable, and then press the power button to turn on the product.
    Figure : Reconnect the power cable, turn on the product
