HP EliteDisplay E231i 23-in IPS LED Backlit Monitor - Option Parts
New model specific parts list
To look up RoHS-compliant information in PartSurfer, use the component’s option part number or the sales order number for a system in which the component is used (available from the product QuickSpecs). Click here to visit the HP PartSurfer website.
Option parts
Component
Option Part Number
Hp USB graphics adapter
NL571AA
HP dual output USB graphics adapter
C5U89AA
HP LCD speaker bar
NQ576AA
HP Business PC security lock kit
PV606AA
HP integrated work center stand - USDT / Thin Clients1
  • E8H16AA/AT (black and meteorite)
  • LH526AA/AT (black and silver)
HP integrated work center stand for Small Form Factors v32
F2P06AA
HP single monitor arm
BT861AA
HP adjustable dual display stand
AW664AA
HP DisplayPort cable kit
VN567AA
HP Display and Notebook stand
AW662AA
HP Adjustable display stand
AW663AA
HP LCD Monitor quick release3
EM870AA
1: The Integrated Work Center Stand has been designed to support 17 to 24-inch diagonal HP LCD monitors from 2.3 kg to 5.2 kg (5.07 lbs to 11.24 lbs).
2: 17 to 24-inch diagonal monitors need to meet supported weight limits of 2.7 to 5.5 kg (6 to 12.1 lbs).
3: The HP Quick Release has been designed to support a maximum of up to 10.9 kg (24 lb) for all devices mounted. Because mounting surfaces vary widely and the final mounting method and configuration may vary, mounting fasteners are not supplied (other than the VESA-compliant screws). HP recommends that you consult with a qualified engineering, architectural or construction professional to determine the appropriate type and quantity of mounting fasteners required for your application and to ensure that your mounting solution is properly installed to support applied loads.
