    Fix HP Printer issue on macOS
HP EliteDisplay S231d 23-in IPS LED BLU Notebook Docking Monitor - Identifying Components
Front view
Item
Function
1
Webcam and Microphones
720p HD Webcam, LED lights up when webcam is in use and dual microphones
2
Menu
Opens, selects or exits the OSD menu.
3
Minus
If the OSD menu is on, press to navigate backward through the OSD menu and decrease adjustment levels.
4
Plus/source
  • If the OSD menu is On, press to navigate forward through the OSD menu and increase adjustment levels.
  • If the OSD menu is inactive, press to activate the source button that chooses the video signal input (DisplayPort, USB or VGA).
5
OK/auto
  • If the OSD menu is On, press to select the highlighted menu item.
  • If the OSD menu is inactive, press to activate the auto adjustment feature to optimize the screen image. The auto adjustment feature only functions if the active adjustment feature is VGA.
6
Power and Power LED
  • Turns the monitor On or Off.
  • White = Fully powered
  • Amber = Sleep mode
  • Flashing Amber = Sleep Timer mode.
Rear view
Item
1
DC power in
2
DC power out
3
Lock slot
4
DisplayPort
5
VGA connector
6
Headphones out
7
Audio in
8
RJ-45 (network) jack
9
USB 2.0 downstream (2)
10
USB 3.0 downstream (2)
11
USB 3.0 upstream
