    Fix HP Printer issue on macOS
Document ID: c04245053
Version: 2
HP ThinClient and HP Flexible ThinClient Computers - Potential OpenSSL Security Vulnerability
Release date : 15-Apr-2014
Last updated : 06-May-2014
DESCRIPTION
A security vulnerability has been identified in products using Open Secure Socket Layer (OpenSSL) libraries.
For more information, refer to the following link: OpenSSL Heartbleed Vulnerability
SCOPE
Systems:
  • HP t505 Flexible Thin Client
  • HP t510 Flexible Thin Client
  • HP t5565 Thin Client
  • HP t5565z Smart Client
  • HP t610 Flexible Thin Client
  • HP t620 Flexible Thin Client
Operating Systems:
  • Thin Pro 4.4.0
  • Thin Pro 4.4.1 (T6X44017)
  • Thin Pro 4.4.2 (T6X44022)
  • Smart Client 4.4.0 (Z6X44017)
  • Smart Client 4.4.2 (Z6X44202)
OpenSSL Versions:
  • 1.0.1
  • 1.0.1f
  • 1.0.2-beta
  • 1.0.2-beta1
RESOLUTION
To resolve this issue, download and install the following SoftPaq:
SoftPaq Description
Release Notes
Download SoftPaq
OpenSSL Service Pack 1.0
Version: 1.0
Revision: 1
NOTE: A more recent version of this software may be available. Check for newer versions at http://www.hp.com/.
Hardware platforms affected : HP t505 Flexible Thin Client (ENERGY STAR) (deleted), HP t510 Flexible Thin Client, HP t5565 Thin Client, HP t5565 Thin Client (ENERGY STAR) (deleted), HP t5565z Smart Client, HP t610 Flexible Thin Client, HP t620 Flexible Thin Client
Support Communication Cross Reference ID : IA04245053
