HP LD4235 42-inch LED Digital Signage Display - Specifications
Physical specifications
Feature
Dimensions (W x D x H)
  • Unpacked (head only):
    96,22 x 77 x 56,08 cm (37.88 x 3.03 x 22.08 in)
  • Packaged:
    105,9 x 20,8 x 71,2 cm (41.6 x 8.1 x 28 in)
Bezel width
  • Left/right and top:
    14,8 mm (0.586 in)
  • Bottom:
    19,4 mm (0.763 in)
  • Unpacked:
    12,8 kg (28.22 lb)
  • Packaged:
    15.7 kg (34.61 lb)
Tilt range
None
Pivot rotation
None
Swivel range
None
Height adjustable
None
Base (feet/stand)
There is no stand included.
Electrical specifications
Feature
Energy consumption (in accordance with US ENERGY STAR test method)
115 V ac, 60 Hz
230 V ac, 50 Hz
100 V ac, 60 Hz
 Normal Operation
86.1 W
84.7 W
88.9 W
Sleep
1.88 W
1.96 W
1.82 W
Off
0.29 W
0.43 W
0.28 W
Heat dissipation
115 V ac, 60 Hz
230 V ac, 50 Hz
100 V ac, 60 Hz
 Normal Operation
294 BTU/hr
290 BTU/hr
304 BTU/hr
Sleep
6 BTU/hr
7 BTU/hr
6 BTU/hr
Off
1 BTU/hr
1 BTU/hr
1 BTU/hr
Packaging materials
External:
PAPER/Corrugated 2636 g
Internal:
  • PLASTIC/EPP (Expanded Polypropolene) 618 g
  • PLASTIC/Polyethylene low density 81 g
Environmental specifications
Feature
Temperature - operating
0° to 40°C (32° to 104°F)
Temperature - non-operating
-20° to 60°C (-4° to 140°F)
Humidity - operating
10% to 80% non-condensing
Humidity - non-operating
5% to 95%, 38.7°C max wet-bulb
Altitude - operating
0 to 5000 m (0 to 16,400 ft)
Altitude - non-operating
0 to 12192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free display glass
Yes
Low halogen
No
Mercury-free display backlighting
Yes
Safety certifications
Feature
Certification and compliance
  • CE
  • CB
  • NOM
  • PSB
  • ICE
  • TUV-S
  • CCC
  • CEL
  • FCC
  • C-UL
  • PSB
  • C-Tick
  • SmartWay Transport Partnership (NA), Microsoft WHQL Certification (Windows 8, Windows 7).
Security Lock-Ready
Yes
Country: Flag Serbia
