    Apache Log4j Update
HP LD4235 42-inch LED Digital Signage Display - Overview
Product description
Broadcast images, documents, and videos on a 42-inch diagonal Full HD[1] IPS display. Great views from nearly anywhere with 178° viewing angles. For a bigger message, deploy a wall of networked or daisy-chained displays.
Product features
Feature
Model
  • F1M92AA
  • F1M92AC
Spare part number
742831-001
Type
IPS, LED with direct backlighting
106,7 cm (42 in) widescreen; diagonally measured
Panel active area (W x H)
92,79 x 52,19 cm (36.53 x 20.54 in)
Aspect ratio
16:9
Viewing angle (typical)
Up to 178° horizontal/178° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
400 cd/m2
Contrast ratio (typical)
1000:1
Dynamic contrast ratio (typical)
5,000,000:1
Response time (typical)
6 ms (gray to gray)
Pixel pitch
0.4833 mm
Color gamut (typical)
68%
Color support3
Can display up to 16.7 million colors
Horizontal frequency
30 to 83 kHz
Vertical frequency
50 to 60 Hz
Native resolution
1920 x 1080 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
  • 1920 x 1080 @ 60 Hz
  • 1680 x 1050 @ 60 Hz
  • 1600 x 900 @ 60 Hz
  • 1440 x 900 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1280 x 800 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 720 x 400 @ 70 Hz
  • 640 x 480 @ 60 Hz
Maximum pixel clock speed
150 MHz (Digital and Analog)
Anti-glare
Yes
Default color temperature
Medium (9300K)
Plug and play
Yes
Input signal
  • RGB/VGA
  • DisplayPort 1.1a
  • HDMI (HDCP support on DisplayPort and HDMI)
Output
  • RGB/VGA
  • DisplayPort 1.1a out for tiling
Video cables included
  • (1) USB 3.0 included
  • (1) VGA cable
  • (1) DisplayPort cable
Video cable length
1,8 m (5.9 ft )
Audio
(1) audio input jack
USB
  • (1) USB 2.0 input for use with HP Media Sign Player
  • Type A port
RS232C
In and out
Speakers
Not included
IR
(1) input
Buttons or switches
  • Input
  • Minus ("-")
  • Up
  • Down
  • Left
  • Right
  • Auto/set
  • Power
Languages
  • English
  • French
  • Spanish
  • Italian
  • German
  • Dutch
  • Traditional Chinese
  • Simplified Chinese
  • Brazilian Portuguese
User controls
  • Brightness
  • Contrast
  • Backlight
  • Sharpness
  • Color
  • Tint
  • Color temperature
  • Image Control
  • Sound Mode
  • Input
  • Aspect Ratio
  • Audio
  • Time
  • Language
  • Factory Reset
User programmable modes
20
Audio controls4
  • Infinite Sound
  • Treble
  • Bass
  • Standard
  • Music
  • Cinema
  • Sport
  • Game.
Compatibility
Compatible with platforms using the VESA standard video modes. Recommended for use with HP products.
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
3: With the use of FRC technology.
4: Monitor does not ship with speakers (available as an accessory).
Software overview
Feature
Operating system support
  • Windows 8
  • Windows 7
Featured software
  • Network Sign Manager
  • Video Over Ethernet
Important links
Product specifications:
List of available documents for the HP LD4235 42-inch LED Digital Signage Display:
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
