Document ID: c04225912
Version: 1
2013 EliteBook Notebooks and Workstations - No Support in WinPE 4.0 Driver Pack sp60858
Release date : 03-Apr-2014
Last updated : 08-Apr-2014
DESCRIPTION
After starting Windows Preinstall Environment 4.0 (WinPE), the driver pack sp60858 will not install. WinPE 4.0 built with SoftPaq sp60858 containing x86 and x64 Driver Pack is not supported by 2013 EliteBook and Workstation products.
SCOPE
Computers:
  • 2013 EliteBook products
  • 2013 Workstation products
RESOLUTION
To resolve this issue, download and install the following SoftPaq:
SoftPaq Description
Release Notes
Download SoftPaq
HP Client WinPE 4.0 x86 and x64 Driver Pack
Version: 1.01
Revision: A
A more recent version of this software may be available. Check for newer versions at http://www.hp.com/. 2013 models requiring this driver pack may not be listed within the release notes or .cva file.
Hardware platforms affected : HP ZBook 15 Mobile Workstation
Support Communication Cross Reference ID : IA04225912
