    Windows 11 Upgrade Guide
Document ID: c04211962
Version: 1
HP EliteBook 8440p Notebook PCs - No Audio After Undocking Computer
Release date : 20-Mar-2014
Last updated : 20-Mar-2014
DESCRIPTION
The computer does not produce audio after detaching the computer from the docking station. This only occurs when the computer is powered on while being undocked and then the DP-to-HDMI cable is connected directly to the computer.
SCOPE
Computers:
  • HP EliteBook 8440p Notebook PC
Operating Systems:
  • Microsoft Windows 7 Enterprise (64-bit)
RESOLUTION
To resolve this issue, download and install the following SoftPaq:
SoftPaq Description
Release Notes
Download SoftPaq
HP Notebook System BIOS Update
Version: F.23
A more recent version of this software may be available. Check for newer versions at http://www.hp.com/.
Hardware platforms affected : HP EliteBook 8440p Notebook PC
Operating systems affected : Microsoft Windows 7 Enterprise (64-bit) (deleted)
Support Communication Cross Reference ID : IA04211962
