    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
HP Products - Getting Started with Touch-to-Print
This document is for HP products that support NFC touch-to-print.
This document is no longer updated after September 2019.
Learn how to get started with NFC touch-to-print and begin using this new feature. NFC touch-to-print is a feature on select HP printers that lets you print wirelessly from mobile devices that support near field communication (NFC) and HP NFC printing standards.
All you need is an HP ElitePad 900 or an Android mobile device that supports NFC and an NFC-compatible HP printer.
Frequently asked questions related to setting up and using touch-to-print.
