Product Name
6102ra
Product Number
G1W01PA
Chipset and Microprocessor
Marvel SOC PXA1088 quad-core
1.2 GHx SoC (BGA)
Integrated graphics
Memory
1G LP DDR2 - 533 MHz
16 GB embedded MultiMediaCard (eMMC)
microSD up to 32 GB (also supports SDHC)
17.78 (7 inch) display
Native resolution: 1280x800
HD wide viewing angle LCD with OGS
10-finger capacitive multi-touch touchscreen
400 nits
WLAN: Marvell 88W8787 WiFi/BT 4.0/FM combo w/ 1 x 1 antenna; supports 802.11 B/ g/ nm but Bluetooth is actually 3.0 due to SW driver/stack limitation.
WWAN: 3G data enabled
Network
Optimized for voice calling
GSM at 850/1800/1900 MHz
WCDMA at6 900/2100 MHz primary with a printed circuit board (PCB) design to support 850/2100 MHz
Dual SIM Dual Standby: 1 microSIM (WCDMA/GSM ) and 1 Mini SIM (GSM)
Audio
1 digital microphone
Integrated stereo speakers
Stereo FM radio
External Ports
Micro SD Card Slot supported up to 32GB
Input / Output
3.5mm 4-pole headset jack
1 microUSB2.0; Type B connector (supports charging Host Mode only)
microSD slot
Does not support USB OTG
Dimensions
X=115.4mm, Y=189mm, Z=9.5mm
320 grams
Sensors
Ambient Light sensor
Accelerometer
e-Compass
GPS
aGPS
Gyro
Proximity
Power
Battery: 4100mAh Lithium-ion non-removable
AC Adapter: 5V-2A (10W) duckhead - microUSB- USB cable connects adapter to tablet.
Front: 2 MP fixed-focus camera without webcam indicator LED
Back: 5 Mp camera with auto-focus. HD video recording, and without LED flash, 702P HD video
Buttons
Power
Volume Up
Volume Down
- ${title}
- ${title}
- ${title}
- ${title}
HP Slate 7 6102ra VoiceTab Product Specifications
Operating System:
Android 4.2 .2
Google Software:
Chrome
Gmail
Google Search
Google+
Google Maps
Google Photos
Googel Voice Search
YouTube
HP Software:
HP ePring
HP Wallpaper
HP Connected Photo
HP File Manager
HP Registration
HP Startup animation
HP Homescreen Layout
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
