An 'Out of Paper' Message Displays and the Printer Does Not Pick Up Paper for the HP Officejet Pro 8610, 8620, 8630, 8640, and 8660 e-All-in-One Printer Series
This document is for the HP Officejet Pro 8610, 8620, 8630, 8640, and 8660 e-All-in-One Printer series.
An 'Out of paper' message displays on the control panel, and the printer does not pick up or feed paper. The printer might make noises as though it is printing, but no paper moves through it.
Solution one: Check the paper, and then reload it
Follow these steps to check the condition of the paper, and then print a test page.
Step 1: Check the condition of the paper
Make sure that the paper you use to print is in good condition, that it is neatly stacked in the tray, and that the paper path and tray are free from obstructions.
  1. Press the Power button to turn off the printer.
      warning:
    You must disconnect the power cord before reaching inside the printer to avoid risk of injuries or electric shock.
  2. Disconnect the USB or Ethernet cable from the rear of the printer.
  3. Grasp the underside of Tray 1, and then pull out the tray.
    Figure : Pull out the paper tray
    Image: Pull out the paper tray.
  4. Remove any paper from the input tray, and then examine the condition of the paper:
    • Replace any ripped, curled, wrinkled, or bent paper.
    • Avoid printing on paper that is dusty. Reload paper that has been in the photo tray for a time.
    • Make sure that all the paper in the stack is the same size and type. The printer can only process one type of paper at a time.
  5. Load plain white paper in the input tray. Make sure that the print side is face-down and the short edge is forward.
    You need to load no fewer than 10 sheets and no more than 25 sheets of plain white paper only for troubleshooting. When the issue is resolved, you can load paper according to the specifications for your printer.
    Do not fill the paper above the yellow, dotted lines on the sides of the paper tray.
    Figure : Load paper into the paper tray
    Image: Load paper into the paper tray.
  6. Check for obstructions inside the input tray. Make sure that nothing blocks the paper from engaging with the rollers. Even small pieces of paper can cause paper feed issues.
  7. If you find obstructions inside the input tray or photo tray, skip to the solution Clean the paper feed and pick rollers.
Step 2: Reload the paper
Follow these steps to reload U.S. letter or A4 size paper in the printer.
  1. Grasp the underside of Tray 1, and then pull out the tray.
  2. Pinch the paper width guide tabs, and then slide the paper width guides to their outermost positions.
    Figure : Slide out the paper width guides
    Image: Slide out the paper width guides.
  3. Insert plain white paper in the tray. Make sure that the print side is face-down and the short edge is forward.
  4. If necessary, slide the paper width guides inward so that they rest on the edges of the paper.
  5. Push the tray toward the printer until it locks into place.
    Figure : Push in the paper tray
    Image: Push in the paper tray.
  6. Pull out the output tray extender, and then raise the paper catch.
    Figure : Pull out the tray extender
    Image: Pull out the tray extender.
Step 3: Print a Printer Status Report
Print a test page from Tray 1 to make sure that the printer hardware functions properly.
If your printer includes Tray 2 as an optional accessory, load only U.S. letter, legal, or A4 size paper. Specialty paper is not supported in Tray 2.
  1. Load U.S. Letter or A4 size, unused, plain white paper into the input tray.
  2. On the printer control panel, swipe the display to scroll to Setup, and then touch the Setup icon (). The Setup menu displays.
  3. Touch Print Reports, and then touch Printer Status Report. The printer prints the report.
    Figure : Example of a Printer Status Report
    Image: Example of a Printer Status Report
Solution two: Adjust the paper settings in the print driver
The printer might not pick up paper if the paper size and type in the paper tray do not match the size and type settings in the print driver. Choose your operating system for steps to change the paper size and type settings.
Solution three: Clean the paper feed and pick rollers
Dust, paper fiber, and other debris might accumulate on the paper feed rollers and paper feed issues. Follow these steps to clean the rollers inside the printer, the duplexer, and the ADF, and then print a test page.
Step 1: Clean the paper feed rollers in the cartridge access area
Follow these steps to clean the paper feed rollers in the cartridge access area.
  1. Gather the following materials:
    • A clean, lint-free cloth, or any cloth that will not come apart or leave fibers
    • Distilled, filtered, or bottled water (tap water might damage the printer)
    • Clean, lint-free cotton swabs
  2. Press the Power button to turn off the printer.
  3. Disconnect the power cord from the rear of the printer, and then unplug the power cord from the power source or electrical outlet.
      warning:
  4. Disconnect the USB or Ethernet cable from the rear of the printer, if you have a cable connection to the printer.
  5. Place your fingers into the slot on the left side of the printer, and then pull forward to open the cartridge access door.
      Image: Open the cartridge access door
    1. Slot on the side of the printer
  6. Lightly dampen the swab with the water, and then squeeze any excess liquid from the swab.
  7. Press the swab against the rollers inside the printer, and then rotate the rollers upwards with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup.
    Figure : Clean the rollers in the cartridge access area
    Image: Clean the rollers in the cartridge access area
  8. Allow the rollers to dry completely (approximately 10 minutes).
  9. Close the cartridge access door.
    Figure : Close the cartridge access door
    Image: Close the cartridge access door
Step 2: Clean the ADF rollers and the separator pad (optional)
If you are trying to copy or fax a document, and the document does not feed into the Automatic Document Feeder (ADF), clean the ADF rollers and the separator pad. If you are not using the ADF, continue to the next step.
  1. Lift the top cover of the ADF. This provides easy access to the rollers and separator pad.
      Figure : Lift the ADF cover
      Image: Lift the ADF cover to access the rollers and separator pad.
    1. ADF cover
    2. Rollers
    3. Separator pad
  2. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  3. Press the cloth against the rollers, and then rotate them upwards with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup.
      Figure : Clean the rollers and separator pad
      Image: Clean the rollers and separator pad.
    1. Rollers
    2. Separator pad
  4. Allow the rollers to dry completely (approximately 10 minutes).
  5. Close the ADF cover tightly at both ends.
    Figure : Close the ADF cover tightly at both ends
    Image: Close the ADF cover tightly at both ends
Step 3: Clean the paper feed rollers in the rear of the printer
Follow these steps to clean the paper feed rollers in the rear of the printer.
  1. Turn the printer so that the rear of the printer faces you.
  2. Remove the duplexer. Push in the buttons on both sides of the duplexer, pull out the duplexer, and then set it aside.
      Figure : Remove the duplexer
      Image: Remove the duplexer
    1. Push in the duplexer buttons
    2. Pull out the duplexer
  3. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  4. Press the cloth against the rollers, and then rotate them upward with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup.
    Figure : Clean the rollers in the rear of the printer
    Image: Clean the rollers in the rear of the printer
  5. Allow the rollers to dry completely (approximately 10 minutes).
Step 4: Clean the paper pick rollers
Follow these steps to clean the paper pick rollers.
  1. Place your fingers in the slot on the front of Tray 1.
    Figure : The slot on the front of Tray 1
    Image: The slot on the front of Tray 1.
  2. Pull the tray toward you to remove it.
    Figure : Pull out the input tray
    Image: Pull out the input tray.
  3. If you use Tray 2, lift the printer off Tray 2, and then set the printer aside.
    Figure : Lift the printer off Tray 2
    Image: lifting the printer off of Tray 2.
  4. Turn the printer so you see its underside, and then locate the pick roller.
    Figure : Locate the pick roller
    Image: Locate the pick roller.
  5. Roll the pick roller to the right so that the rubber part faces you. This might require some force.
    The pick roller should only rotate to the right.
    Figure : The pick roller in its normal position
    Image: The pick roller in its normal position
      Figure : The rubber part of the pick roller
      Image: The rubber part of the pick roller.
    1. The rubber part of the pick roller
    2. Rotate the rubber part of the pick roller so that it faces you
  6. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  7. Press the cloth against the rubber part of the roller, and then rotate the roller to the right with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup.
  8. Rotate the roller back to its original position.
    Figure : The pick roller in its original position
    Image: The pick roller in its original position
  9. Turn the printer back around so that the printer control panel faces you.
  10. Place the printer its normal position.
  11. Reinstall Tray 1.
    Figure : Reinstall Tray 1
    Image: Reinstall Tray 1
  12. If you use Tray 2, lift the printer, and then lower the printer on top of Tray 2.
    Figure : Set the printer on top of Tray 2
    Image: Set the printer on top of Tray 2
Step 5: Clean the rollers in the duplexer
Follow these steps to clean the rollers in the duplexer.
  1. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  2. Press the cloth against the external rollers, and then rotate them upward with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup.
    Figure : The duplexer external rollers
    Image: Duplexer external rollers.
  3. Press the tabs on the sides of the duplexer, and then lower the cover to open the duplexer.
    Figure : Press the tabs to open the duplexer
    Image: Press the tabs to open the duplexer
  4. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  5. Press the cloth against the rollers, and then rotate them upward with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup.
    Figure : Clean the rollers in the duplexer
    Image: Clean the rollers in the duplexer
  6. Allow the rollers to dry completely (approximately 10 minutes).
  7. Close the duplexer cover.
  8. Gently push the duplexer into the printer until it snaps firmly into place. Do not press the buttons on the end of the duplexer while you reattach it.
    Figure : Push the duplexer into place
    Image: Push the duplexer into place
  9. Reconnect the power cord to the rear of the printer, and then plug in the power cord to the electrical outlet.
  10. Reconnect the USB or Ethernet cable, unless your printer is connected on a wireless network.
  11. Press the Power button to turn on the printer.
    The printer might go through a warm-up period. The printer lights might flash, and the carriage might move.
    Wait until the warm-up period finishes before you proceed.
Step 6: Print a Printer Status Report
Print a test page to make sure that the hardware functions correctly.
Solution four: Reset the printer
Sometimes, resetting the printer can clear a paper feed issue. Follow these steps to reset the printer.
Step 1: Perform a power reset
Follow these steps in the order presented to reset the printer.
  1. Turn the printer on, if it is not already on.
  3. With the printer turned on, disconnect the power cord from the rear of the printer.
  4. Unplug the power cord from the wall outlet.
  5. Wait at least 60 seconds.
  6. Plug the power cord back into the wall outlet.
    HP recommends connecting the printer power cord directly to the wall outlet.
  7. Reconnect the power cord to the rear of the printer.
  8. Turn on the printer, if it does not automatically turn on.
  9. Wait until the warm-up period finishes and your printer is idle and silent before you proceed.
Step 2: Print a Printer Status Report
Step 3: Try to print
If the Printer Status Report prints successfully, try to print the original document or photo again.
  • If the document or photo does print successfully, the issue is resolved.
  • If the document or photo does not print, service the printer.
Contacting HP for service in all countries/regions except Asia Pacific.
If you completed all the preceding steps and your product still has an issue, service the product.
Check your product warranty to determine if your product is still under warranty, and then go to Contact HP Support to schedule a repair or replacement.
Country: Flag Serbia
