    Fix HP Printer issue on macOS
Document ID: c04094760
Version: 1
Advisory: HP Z230 Tower Workstation - The 320W Power Supply Fan May Not Always Spin
Release date : 22-Jan-2014
Last updated : 22-Jan-2014
DESCRIPTION
The 320W power supply fan may not always spin.
Symptoms:
The 320W power supply used on the HP Z230 Tower Workstation may have a fan that does not spin in low temperatures or low system workloads. This is expected behavior and no action is required.
PSU part numbers affected are 702306-001, 702306-002.
SCOPE
Systems:
  • HP Z230 Tower Workstation
Operating Systems:
  • Non-OS Specific
RESOLUTION
Hardware platforms affected : HP Z230 Tower Workstation
Support Communication Cross Reference ID : IA04094760
