HP VoiceTabs - Making and Receiving Phone Calls (Android 4.2/Jelly Bean)
This document applies to HP VoiceTabs with Android 4.2/Jelly Bean operating system.
HP VoiceTabs have built-in voice calling features that allow you to use the phone-tablet in the same way you would use a smart phone. Use this document to learn more about the phone features on your VoiceTab.
Inserting SIM cards
HP VoiceTabs have two SIM card slots, enabling the simultaneous use of two services in one device. Both SIM cards are in standby mode when not in use. When you make or receive a phone call on one SIM card, the other SIM card is temporarily inactive for the duration of the call.
To access the SIM card slots, remove the back cover of the device. The slots are located beside the battery in the Slate 7 VoiceTab, and above the battery in the Slate 6 VoiceTab.
    Figure : Card slots: microSD, miniSIM, and microSIM (Slate 7 example)
  1. microSIM card slot (SIM1)
  2. miniSIM card slot (SIM2)
  3. microSD memory card slot
When both SIM card slots are in use, the status bar at the top of the VoiceTab screen displays two signal-strength bars, accompanied by the numbers 1 and 2. If one of the SIM card slots is empty, the signal-strength bar is replaced by a SIM icon with a question mark.
Figure : Signal-strength bars
The microSIM, which supports W-CDMA and GSM, is number 1 (SIM1). The miniSIM, which supports GSM only, is number 2 (SIM2). When making a call with both SIM card slots in use, you can select which SIM card you want to bill each time you make a call.
Making a phone call
Follow the steps in this section to place an outgoing call using the VoiceTab.
  1. On the Home screen, touch the blue phone icon.
  2. The keypad appears, with three tabs at the top of the screen: phone , call history , and contacts . Select the phone tab to enter a phone number using the keypad.
  3. Touch the numbers on the keypad to enter the phone number you want to call.
    Figure : Phone keypad
    Phone keypad
  4. Touch one of the green phone icons (either 1 or 2 ) to place the call from the corresponding SIM card.
    If only one SIM card is installed in the device, only one green phone icon is active.
  5. To end the phone call, touch the red bar with a white phone icon at the bottom of the screen.
Answering a phone call
Use the information in this section to answer or decline an incoming call on your VoiceTab.
When you make or receive a phone call on one SIM card, the other SIM card is temporarily inactive for the duration of the call. Incoming calls to the other SIM card go directly to voicemail.
When there is an incoming call on the VoiceTab, the screen shows a white phone icon with a circle of dots:
Figure : Incoming call
Incoming call
Place your finger on the white phone icon in the center of the dotted circle to display the following call options:
Figure : Call answering options
Answer or decline the incoming call by sliding your finger along the surface of the screen to one of the icons in the outer circle:
  • Accept the call: Swipe your finger toward the green phone icon to answer the incoming call.
  • Decline the call: Swipe your finger toward the red phone icon to decline the incoming call.
  • Decline the call and send a text message: Swipe your finger toward the message icon to decline the call and send a text message reply. You can then choose from a menu of default messages, or create a custom message to send to the caller.
    Figure : Text message options
Phone call settings and options
You can change the phone ringtone, vibration, and other settings in the call settings menu. To access the call settings menu, use the following steps:
  2. Call settings can be accessed from either the phone, history, or contacts tab. From any tab, touch the menu icon, and then touch Settings in the drop-down list.
    Figure : Settings (history tab example)
  3. Configure the call settings according to your preferences.
    Figure : Call settings menu
    Call settings menu
The following options are available on the main call screen when a phone call is active on your device:
  • End call: To end the current phone call, touch the white phone icon in the red bar at the bottom of the screen.
  • Access the keypad: To access the keypad while in a call, touch the keypad icon.
  • Speakerphone: To turn on the speaker, touch the speaker icon.
  • Mute: To turn off the microphone (mute the call), touch the mute icon.
  • Hold: To place an active call on hold, touch the pause icon.
  • Add a caller: To add another caller to a phone call, touch the add caller icon. See Making a conference call for more information.
  • Record the call: To record the call, touch the record icon.
  • Swap call: To switch back and forth between two calls, touch the swap call icon. This option is only available when you have one call active and one call waiting.
  • Join a conference: When two calls are active on the device at once, touch the start/resume conference call icon to allow each caller to hear and speak to the other participants. This option is only available when you have at least one call active and one call waiting. See Making a conference call for more information.
You can begin a conference call whenever there is more than one active call on your VoiceTab (either incoming or outgoing). Join multiple active calls into a conference call, and manage the conference call settings, using the steps in this section.
  1. Begin a call with the first person you want to add to the conference. See Making a phone call for instructions, if needed.
  2. Touch the add caller icon at the bottom of the screen. The first caller is put on hold while you dial the next caller.
  3. Use the keypad to enter a phone number, or select the contacts tab at the top of the screen to find the saved contact you want to call.
  4. When the second contact answers the phone call, touch the start/resume conference call icon to merge the two active calls, allowing each participant to hear and speak to the others on the call.
    Once the conference call begins, the add caller icon replaces the start/resume conference call icon.
  5. To add more conference call participants, repeat steps 2 through 4.
  6. To pause the conference, putting all callers on hold, touch the pause icon.
  7. You can manage the conference call by putting individual callers on hold, or removing individual callers from the conference. Touch the Manage conference option to view the conference call settings.
    Figure : Manage conference
    Manage conference
  8. In the Manage conference call menu, touch the exit conference icon next to any caller you want to put on hold. Touch the end call icon next to any caller you want to remove from the conference call.
    Figure : Manage conference call
    To return to the conference call main screen, touch the back arrow icon at the top of the screen.
Using the contacts list
You can add new contacts, search for contacts, view contact details, and place calls to contacts within the contacts tab.
On the Home screen, touch the blue phone icon, and then touch the contacts icon at the top of the screen to open the contacts tab and view your contacts.
Figure : Contacts tab
Contacts tab
In the contacts list, do any of the following:
  • To add a new contact, touch the add contact icon, and then select the storage location where you want to save the contact: SIM1 or SIM2, your Google account (or other cloud account), or local storage on the VoiceTab. Enter the contact information and save the new contact.
  • To call a saved contact, touch the contact name. Select the SIM card you want to use to place the call.
  • To search for an existing contact, touch the search icon, and then start typing the contact name.
  • To view details for a saved contact, touch the contact image.
Viewing call history
The call history tab displays a list of calls made or received by the phone on either SIM card.
On the Home screen, touch the blue phone icon, and then touch the history icon at the top of the screen to open the history tab and view your call history. People from your contacts list can be identified by the small grey triangle at the bottom of the contact image. The triangle indicates that the contact's details can be edited.
Figure : Call history tab
Call history tab
Each call is identified with a SIM card icon and the number 1 or 2, on the right side of the screen, corresponding to SIM1 and SIM2. The direction and color of the arrows under the contact information indicate whether you placed the call (green), received the call (blue), or missed the call (red). To call a contact listed in the history tab, touch the white phone icon next to the contact.
