    Windows 11 Upgrade Guide
HP ZBook 14 Mobile Workstation - Overview
Product description
HP’s lightest mobile workstation the new HP ZBook 14 utilizes impressive professional 3D graphics.
Product features
Feature
Mobile Intel QM87 Express
Graphics
  • Intel HD 4400 Graphics
  • AMD FirePro M4100 (1GB dedicated GDDR5)
    • Microsoft DirectX 11.1 (Shader Model 5.0) and OpenGL 4.2 capable
  • AMD Dynamic Switchable Graphics supported
Flash cache
  • 32GB M.2 (NGFF)
  • Optional 32GB mSATA flash cache module (available only with standard non-SED hard drive)
Flash cache module
Optional M.2 Flash cache module support for Intel Smart Response Technology.
Memory
Standard
  • DDR3L 1.35-V SDRAM (1600 MHz)
  • Two SODIMM slots supporting dual-channel memory
  • 4GB and 8GB SODIM
Maximum
  • Ungradable to 16384MB with optional 8192MB SODIMMs in both slots
Dual-channel
  • Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Internal
  • 14-inch diagonal LED-backlit HD+ SVA eDP anti-glare (1600 x 900)
  • 14-inch diagonal LED-backlit HD+ SVA eDP anti-glare + touch (1600 x 900)
  • 14-inch diagonal LED-backlit FHD UWVA eDP anti-glare + PSR (1920 x 1080)
External
Up to 30-bit (2^30) per pixel "Deep Color" (total of 1,073,741,824 color variations)
DisplayPort w/MST (Multi-stream Transport)
Supports resolutions up to QFHD 3840 x 2160, 24/30-bit color depth at 60 Hz, and WUXGA (1920 x 1200) monitors, 24/30-bit color depth at 120 Hz.
DisplayPort features
Multi-stream Transport (MST) is a DP 1.2 feature that allows daisy chaining of DP 1.2 monitors
VGA
Port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
DVI-D (single link)
DVI support requires a DP DVI adapter (sold separately)
Storage and drive
M.2 storage bay
120GB M.2 Solid state drive (SSD)
Hard drives
  • 320/500/750GB 7200-rpm SMART SATA II, SMART SATA III
  • 1TB 5400-rpm SMART SATA II, SMART SATA III
  • 500GB 7200-rpm SMART SATA II, SMART SATA III Self Encrypting Drive (SED) (Planned to be available in Oct. 2013)
  • 500GB 5400-rpm SMART SATA II, SMART SATA III I Self Encrypting Drive FIPS 140-2 compliant
HP 3D DriveGuard (Windows only)
The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive.
SSD
  • 120GB M.2 (NGFF) SSD (Expected to be available in 4Q 2013)
  • 180/240/512GB SATA 6 Gb/s
  • 256GB SATA 6 Gb/s SED
Networking & communication
Mobile Broadband options (Win 8 WWAN support will not be available at Win 8 introduction)
  • HP hs3110 HSPA+ Mobile Broadband Module
  • HP lt4111 LTE/EV-DO/HSPA+ Gobi4G Module
  • HP lt4112 LTE/HSPA+Gobi4G Module (EMEA)
All 802.11 integrated wireless LAN options
  • Intel b/g/n (INDO only)
  • Intel Dual Band Wireless-N 7260NB 802.11a/b/g/n (2x2) WiFi
  • Intel Dual Band Wireless-N 7260AN 802.11a/b/g/n (2x2) WiFi and Bluetooth 4.0 combo
  • Intel Dual Band Wireless-AC 7260 802.11ac (2x2) WiFi and Bluetooth 4.0 comb
Communications
Integrated Intel I218-LM Gigabit Network Connection (10/100/1000)
Audio/Multimedia
Audio
  • DTS Studio Sound HD audio (Windows OS only)
  • Integrated stereo speakers
  • Integrated microphone (dual-microphone array when equipped with optional webcam)
  • Button for volume mute; function keys for volume up and down
  • Combo mic-in/stereo headphone-out jack
720p HD webcam (select models):
  • HD format (widescreen)
  • Supports videoconferencing and still image capture
  • High quality fixed focus lens
  • Video capture at various resolutions up to 1280x720 resolution (720p) and up to 30 f/s
  • M-JPEG compression supports higher frame rates for video capture and videoconferencing
  • Improved low light sensitivity
  • Improved dynamic rang
Software overview
Feature
Operating system (Preinstalled)
  • Windows 8 Pro 64
  • Windows 8 64 Windows 7 Professional (available through downgrade rights from Windows 8 Pro)
  • Windows 7 Professional 64
  • Windows 7 Professional 32
  • SUSE Linux Enterprise Desktop 11
  • FreeDOS
Important links
Specifications:
List of available documents for the HP ZBook 14 Mobile Workstation:
Warranty:
Limited 3-year, 1-year and 90-day warranty options available, depending on country, 1-year limited warranty on primary battery.
