    Windows 11 Upgrade Guide
HP V241a 23.6-inch LED Backlit Monitor - Specifications
Physical specifications
Dimensions (W x D x H)
  • Unpacked w/stand
    56.33 x 20.41 x 41.24 cm (22.19 x 8.04 x 16.25 in)
  • Unpacked w/o stand (head only)
    56.33 x 4.69 x 34.77 cm (22.19 x 1.85 x 13.7 in)
  • Packaged
    63.4 x 12.5 x 47.5 cm (24.98 x 4.93 x 18.72 in)
  • Base area (footprint)
    21.91 x 20.41 cm (8.63 x 8.04 in)
  • Head only
    3.7 kg (8.2 lb)
  • Unpacked
    4 kg (8.8 lb)
  • Packaged
    5.8 kg (12.8 lb)
Technical specifications
On Screen Display (OSD) controls
Buttons or switches
  • Menu
  • Minus ("-")
  • Plus ("+")/Source
  • OK/Auto
  • Power
User controls
  • Brightness
  • Contrast
  • Image control
  • OSD control
  • Languages
  • Color
  • Management
  • Factory Reset
  • Input control
  • Exit
Signal interface/Performance
Horizontal frequency
24 to 94 kHz
Vertical frequency
50 to 75 Hz
Native resolution
1920 x 1080 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
  • 1920 x 1080 @ 60 Hz
  • 1680 x 1050 @ 60 Hz
  • 1600 x 900 @ 60 Hz
  • 1440 x 900 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 720 x 400 @ 70 Hz
  • 640 x 480 @ 60 Hz
Maximum pixel clock speed
170 MHz
User programmable modes
Yes (10)
Anti-glare
Yes
Default color temperature
6500 K
Video/Other inputs
Plug and play
Yes
Input connectors
  • VGA (analog)
  • DVI-D (HDCP support on DVI-D)
Video cable
  • (1)VGA
  • (1)DVI-D
Video cable lengths
1.8 m (5.9 ft)
Audio
Yes, (1) Audio input; integrated 1W/channel speakers
Audio cable
(1) 3.5mm audio cable
Audio cable length
1.8 m (5.9 ft)
Electrical specifications
Power supply
Internal
Input power
90 - 265 V ac at 45 - 63 Hz
Typical power consumption
26 W
Maximum power consumption
30 W
Power saving
0.5 W
Power cable length
1.9 m (6.2 ft)
Environmental specifications
Temperature
  • Operating: 5°C to 35°C (41°F to 95°F)
  • Non-operating: -20°C to 60°C (-4°F to 140°F)
Humidity
  • Operating: 20% to 80% non-condensing
  • Non-operating: 5% to 95%, 38.7°C (101.66°F) max wet-bulb
Altitude
  • Operating: 0 to 5,000 m (16,404 ft)
  • Non-operating: 0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free display glass
Yes
Mercury- free display backlighting
Yes
Certification and compliance
Certifications
  • UKRAINE
  • CB
  • CE
  • TUV
  • TUV-GS
  • TCO
  • ETL
  • S-mark
  • ENERGY STAR
  • EPEAT Silver
