HP Color LaserJet Enterprise M855 and HP Color LaserJet Enterprise flow MFP M880 - Load the 3,500-sheet high-capacity tray
The 3,500-sheet high-capacity tray supports only A4 and Letter-size paper.
  1. Open the right and left sides of the tray.
    Figure : Open the tray
  2. On each side, adjust the paper-size lever to the correct position for the paper you are using.
    Figure : Adjust the guides
  3. Load full reams of paper into each side of the tray. The right side holds 1,500 sheets of paper. The left side holds 2,000 sheets of paper.
    For best results, load full reams of paper. Avoid dividing reams into smaller sections.
    Figure : Load the tray
  4. Close the right and left sides of the tray.
    Figure : Close the tray
