Document ID: c03975303
Version: 1
NOTEBOOK - System BIOS Update F.45 for 8470w, 8470p, 6470b, 8570p, 6570b
Release date : 21-Oct-2013
Last updated : 11-Dec-2017
DETAILS OF CHANGE
  • Fixed an intermittent issue where the computer would hang when booting with certain USB head sets attached to the USB 3.0 port.
  • Fixed an issue where the computer would not be able to complete a UEFI PXE boot if Secure Boot was enabled.
  • Fixed an issue where the Smart Card reader would disappear from Device Manager after resuming from Standby.
  • Added support for Intel Indonesia Taylor Peak Card WLAN cards.
SUPPORT URL
Get the latest BIOS update from the HP Software dowload site for the 8470w, 8470p, 6470b, 8570p, and 6570b.
REASON FOR CHANGE
Quarterly refresh for the factory and Web release.
IMPACT OF CHANGE
After upgrading to this BIOS version, you will not be able to downgrade to versions older than F.30, if the Secure Boot option has been enabled in F10 (BIOS) Setup.
If upgrading to this BIOS from a version older than F.30, it is recommended that the user enter the F10 (BIOS) Setup and restore defaults after backing up existing F10 (BIOS) Setup settings. For information on restoring F10 (BIOS) Setup settings, see System BIOS Update F.45 for 8470w, 8470p, 6470b, 8570p, and 6570b..
Components affected:
HP EliteBook 8470w Mobile Workstation, HP EliteBook 8470p Notebook PC, HP ProBook 6470b Notebook PC, HP EliteBook 8570p Notebook PC, and HP ProBook 6570b Notebook PC
DATE OF CHANGE
Effective date : 07-Oct-2013
Hardware platforms affected : HP EliteBook 8470p Notebook PC, HP EliteBook 8470w Mobile Workstation, HP EliteBook 8570p Notebook PC, HP ProBook 6470b Notebook PC, HP ProBook 6570b Notebook PC
