HP Compaq L5009tm 15-inch LCD Touchscreen Monitor - The Touchscreen Keyboard Duplicates Onscreen Keystrokes
This document pertains to the HP rp5800 Retail System using a touchscreen monitor on the Windows 7 operating system.
Some customers have reported that the touchscreen keyboard duplicates onscreen keystrokes.
Adjust custom settings
Use the following instructions to work around this issue.
  1. Click Start , and then click Control Panel.
  2. Click Ease of Access Center, and then click Change how your keyboard works.
  3. Click Turn on Filter Keys.
  4. Click Set up Filter Keys.
  5. Check Turn on Repeat Keys and Slow Keys.
  6. Select Set up Repeat Keys and Slow Keys, to adjust your custom settings.
    The ideal settings are different for each computer. Try different settings to see what gets the best results.
