    Fix HP Printer issue on macOS
HP Z Display Z30i 30-inch IPS LED Backlit Monitor - Specifications
Physical specifications
Specification
Dimensions (H x W x D)
Highest position: 60.1 x 69.03 x 26.648 cm (23.66 x 27.18 x 10.49 in)
Lowest position: 48.1 x 69.03 x 26.648 cm (18.94 x 27.18 x 10.49 in)
Maximum weight (Unpacked)
9.96 kg (21.96 lbs)
Electrical specifications
Specification
Power source
100 – 240 V ac 50/60 Hz
Environmental specifications
Specification
Temperature
  • Operating: 5 to 35° C (41 to 95° F)
  • Storage: -20 to 60° C (-4 to 140° F)
Technical specifications
Enter para text
Enter para text
76.2 cm wide screen (30 inches wide screen)
Type
IPS LCD
Viewable image size
76.2 cm diagonal (30-inch diagonal)
Performance
Specification
Maximum graphic resolution
1920 x 1200 (60 Hz) analog input
2560 x 1600 (60 Hz) digital input
Optimum graphic resolution
