HP ProBook 430 G1 Notebook PC Product Specifications
Product image
Product features
Feature
Processors
4th generation Intel Core Processors
Mobile Intel HM77
Graphics
Integrated graphics
  • Internal: 13.3-inch diagonal HD LED-backlit anti-glare (1366 x 768)
  • External: Up to 32-bit per pixel color depth
  • VGA: Up to 2048 x 1536 external resolution at 75 Hz
  • HDMI: Up to 1920 x 1200 at 60Hz resolution
Storage and drives
Hard drives
  • 320/500GB 5400 rpm SMART SATA II
  • 500GB 7200 rpm SMART SATA II
Solid State Drives
  • 120GB M.2 Solid State Drive1
  • 128GB 2.5-inch Solid State Drive
Optical drives
External optical disk drive
Memory
Standard
  • DDR3L SDRAM (1600 MHz)
  • Two SODIMM slots supporting dual-channel memory 2GB, 4GB, and 8GB SODIMMs
Maximum
  • Upgradeable to 16384MB with optional 8192MB SODIMMs in slots 1 and 2
Dual-channel
  • Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Networking/Communications
Broadband wireless (WWAN)2
  • HP hs3110 HSPA+ Mobile Broadband Module
  • HP lt4112 LTE/HSPA+ Gobi 4G Module
Wireless LAN (WLAN)2
  • Realtek 802.11 b/g/n (1x1)
  • Mediatek 802.11 b/g/n (1x1) with Bluetooth® v4.0 combo
  • Broadcom 802.11 a/b/g/n (2x2) with Bluetooth® v4.0 combo
  • Intel Dual Band Wireless-N 7260AN 802.11 a/b/g/n (2x2) WiFi + Bluetooth 4.0 Combo
Communications
  • Realtek 10/100/1000 ethernet controller
720p HD webcam3
1: Available in Fall 2013.
2: Sold separately or as an optional feature.
3: HD content required to view HD images.
Display specifications
Specification
13.3-inch LED HD (1366 x 768) anti-glare
active Area (w x h)
29.3 x 16.5 cm (11.53 x 6.49 in)
Diagonal size
33.8cm (13.3 in)
Surf ace treatment
Anti-glare
Contrast ratio
400:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Pitch: 0.252 mm
  • Format: 1366 x 768
  • Configuration: RGB Stripe
Backlight
LED
PPI
118 ppi
Viewing angle
  • ±30° Horizontal, ±10° Vertical (minimum)
  • 30/30/20/10 (Left/Right/Down/Up) (minimum)
  • 45/45/35/25 (Left/Right/Down/Up) (typical)
HDD specifications
Specification
500GB 7200 rpm SATA Hard Drive
Drive weight
115g (0.25 lb)
Capacity
500GB
Height
7 mm (0.276 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer rate
Synchronous (maximum) 300MB/s (Drive Capability)
Seek time (typical reads, including settling)
  • Single Tr ack: 3 ms
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
7200 rpm
Logical blocks
976,773,168
Operating temperature
0° to 60° C (32° to 140° F) [case temp]
Features
ATA security
320GB 5400 rpm SATA Hard Drive
Drive weight
101 g (0.22 lb)
Capacity
320GB
Height
7 mm (0.276 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
625,142,448
Features
ATA security
500GB 5400 rpm SATA Hard Drive
Drive weight
101 g (0.22 lb)
Capacity
500GB
Height
7 mm (0.276 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA security
SATA 6Gb/s 128GB, 2.5-inch Solid State Drive
Drive weight
73 Grams
Capacity
128GB
Height
7 mm (0.276)
Width
70 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance Rate
  • Maximum Sequential Read
    : 415 MB/s
  • Maximum Sequential Write: 175MB/s
Specification
Broadband Wireless (WWAN)
  • HP hs3110 HSPA+ Mobile Broadband Module 1
  • HP lt4112 LTE/HSPA+ Gobi 4G** Module 1
Wireless LAN (WLAN)
  • Realtek 802.11 b/g/n (1x1) 1
  • Mediatek 802.11 b/g/n (1x1) with Bluetooth v4.0 combo 1
  • Broadcom 802.11 a/b/g/n (2x2) with Bluetooth v4.0 combo 1
  • Intel Dual Band Wireless-N 7260AN 802.11 a/b/g/n (2x2) WiFi + Bluetooth 4.0 Combo 1
Communications
Supports Bluetooth v2.1 on Linux operating systems.
Audio/Multimedia - DTS sound
Specification
Implementation
IDT 92HD91
Function key volume
Volume up, volume down, and mute
Full duplex
Yes
Microphone in
Stereo
Headphone/line out
Stereo
Integrated microphone
Yes, dual digital microphone array when equipped with optional webcam
Audio output quality
Frequency response
20 Hz - 20 kHz
Signal to noise ratio
Less than 85 dB
Total harmonic distortion
0.01%
Noise floor
- 110 dB
Play/Record sampling rate(s)
8 kHz - 48 kHz
D ac
16, 20 or 24-bit
ADC
16 or 20-bit
Internal stereo speakers
Power rating
2 W
Impedance
4 ohms
Power
HP 65W EM Smart AC Adapter
Specification
Dimensions
12.65 x 5.0 x 3.0 cm (4.98 x 1.97 x 1.18 in)
290 g (0.62 lb)
Input
190 to 265 V ac
Input Efficiency: 87% min at 115 V ac
Input frequency range: 47 to 63 Hz
Input ac current: 1.7 A at 90 V ac
Output
Output power: 65W
DC output: 19.5V
Hold-up time: 5 msec at 115 V ac input
Output current limit: less than 11 A, Over voltage protection- 29V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
Operating temperature: 0° to 35° C (32° to 95° F)
Non-operating (storage) temperature: -20° to 85° C (-4° to 121° F)
Altitude: 0 to 5,000 m (0 to 16,405 ft)
Humidity: 0% to 95%
Storage Humidity: 0% to 95%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; Reliability - failure rate of less than 0.1% annually within the first three years of operation.
4-Cell (44 WHr) Lithium- Ion battery
Cells/Type
4-cell Lithium-Ion
Dimensions(H x W x L)
2.18 x 3.56 x 27.72 cm (0.86 x 1.4 x 8.0 in)
Weight (max)
Greater than 250 g (0.551 lb)
Energy
Voltage
14.8V DC
Amp-hour capacity
2850mAh
Watt-hour Capacity
44 WHr
4-Cell (41 WHr) Lithium-Ion battery
Cells/Type
4-cell Lithium-Ion
Energy temperature
Watt-hour cap acity: 41 WHr
Operating (Charging): 0° to 45° C (32° to 113° F)
Operating (Discharging): (-10° to 60° C)
Non-operating: (-20° to 60° C) -4° to 140° F
Battery re-Charge time
System in OFF or Standby Mode: 2.5 hours
System ON: 3 to 5 hours (depending on system power consumption)
HP Fast Charge Technology: Charges the battery up to 90% within 90 minutes when system is OFF
HP 45W Smart AC Adapter
Dimensions
9.6 x 4.95 x 2.24 cm (3.78 x 1.95 x 0.88 in)
Input
90 to 265 VAC
  • Input Efficiency: 87% min at 115 VAC
  • IInput frequency range: 47 to 63 Hz
  • Input AC current: 1.4 A at 90 VAC and maximum load
Output
  • Output power: 45W
  • DC output: 19.5V
  • Hold-up time: 5 msec at 115 VAC input
  • Output current limit: Less than 8A, Over voltage protection- 29V max automatic shutdown
Connector
Environmental Design
  • Operating temperature: 0° to 35° C (32° to 95° F)
  • Non-operating (storage) temperature: -20° to 85° C (4° to 121° F)
  • Altitude: 0 to 5,000 m (0 to 16,405 ft)
  • Humidity: 0% to 95%
  • Storage Humidity: 0% to 95%
EMI and Safety Certifications
Energy description
Specification
Energy consumption
  • 115 V ac
  • 230 V ac
  • 100 V ac
Normal operation
  • 6.02 W
  • 6.10 W
  • 5.91 W
Sleep (Energy Star low power mode)
  • 0.52 W
  • 0.60 W
  • 0.51 W
Off
  • 0.30 W
  • 0.37 W
  • 0.28 W
Heat Dissipation 1
  • 115 V ac
  • 230 V ac
  • 100 V ac
Normal operation
  • 21 BTU/hr
  • 21 BTU/hr
  • 20 BTU/hr
Sleep
  • 2 BTU/hrr
  • 2 BTU/hr
  • 2 BTU/hr
Off
  • 1 BTU/hrr
  • 1 BTU/hr
  • 1 BTU/hr
Heat dissipation is calculated based on the measured watts, assuming the service level is attained for one hour.
Physical specifications
Feature
Weights and dimensions
  • Starting at 1.50 kg (3.31 lb)
Dimensions (w x d x h)
  • 12.83 x 9.19 x 0.83 in
  • 32.6 x 23.35 x 2.1cm
Ports/Slots
Ports
  • USB 3.0 – Two
  • USB 2.0 (power port) – One
  • HDMI 1.4a – One
  • VGA – One
  • Stereo microphone input – One
  • Headphone/line out – One
  • RJ-45 (Ethernet) – One
  • Power connector – One
Digital media slots
  • Supports SD (Secure Digital)
  • SDHC
  • SDXC
  • Memory Stick
  • MSXC
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Starting weight requires optional 120 GB SSD drive, planned to be available Fall, 2013.
Software/OS
Feature
  • Windows 8 Pro 64
  • Windows 8 64
  • SUSE Linux Enterprise Desktop 11
  • FreeDOS
Preinstalled software with windows operating system
  • HP Wireless Hotspot
  • Cyberlink Media Suite
  • HP ePrint
  • SMS Roaming Alert
  • HP Mobile Connect
  • HP Hotkey support
  • HP 3D DriveGuard
  • PDF Complete Corporate Edition
  • Skype ready
  • HP Recovery Manager
  • Evernote
  • HP Support Assistant
  • Buy Office
  • Intel Wireless Display
Security
Standard
  • HP Client Security
  • Microsoft Defender
  • Drive Encryption
  • HP BIOS Protection
  • Security lock slot
Environmental specifications
Specification
Stand-Alone power
Nominal operating: 19 V
Requirements (ac Power)
Voltage
Average operating power: 19.19 W
Max Operating Power: 35.84W
Temperature
Operating
  • 0° to 35° C (32° to 95° F) (not writing optical)
  • 5° to 35° C (41° to 95° F) (writing optical)
Non-operating
  • -20° to 60° C (-4° to 140° F)
Relative humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 101.6° F (38.7° C) maximum wet bulb temperature
Shock
Operating: 40 G, 2 ms, half-sine
Non-operating: 200 G, 2 ms, half-sine
Random Vibration
Operating: 0.75 grms
Non-operating: 1.50 grms
Altitude (unpressurized)
Operating:
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating:
-15.24 to 12,192 m (-50 to 40,000 ft)
Planned industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC Compliance: Yes
  • ENERGY STAR: TBD models
  • EPEAT: Registered TBD in United States
  • ICES: Yes
  • Australia/NZ A-Tick Compliance: Yes
  • CCC: Yes
  • Japan VCCI Compliance: Yes
  • KC: Yes
  • BSMI: Yes
  • CE Marking Compliance: Yes
  • BNCI or BELUS: Yes
  • CIT: Yes
  • GOST: Yes
  • Saudi Arabian Compliance (ICCP): Yes
  • SABS: Yes
  • UKRSERTCOMPUTER: Yes
Security
Specification
HP Fingerprint Sensor (optional)
Mobile voltage operation
3.0V -3.6V single supply
0° - 70°C (32° - 158°F)
Current consumption at 3.3 V
  • Less than 70 mA peak imaging and scrolling
  • Less than 25 mA hardware finger detection
  • Advanced power management
High-rate image capture
Up to 240 image frames /sec
ESD resistance
IEC 61000-4-2 Level 4 (±15KV)
Detection matrix
  • 192 x 16 pixels
  • 9.7 mm x 0.81 mm
  • 500 ppi High-Resolution images
Important links
List of available documents for the HP ProBook 430 G1 Notebook PC
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
