HP EliteDesk 800 G1 Small Form Factor (SFF) PC Specifications
Product image
HP EliteDesk 800 G1 SFF PC
Product features
Feature
Intel Q87 Express
Processors
Intel 4th Generation Core i5, i7 Processors
Memory
1600-MHz DDR3 SDRAM; (4) DIMM slots enabling up to 32 GB, dual channel memory support
Webcam and microphone
Internal storage
Up to 500 GB SATA hard drive; up to 500 GB self-encrypting solid state drive; up to 160 GB solid state drive
Removable storage
  • Slim DVD-ROM drive
  • Slim SuperMulti DVD drive
  • Slim BDXL Blu-ray Writer drive
  • (2) PCI Express x1 (v2.0)
  • (1) PCI Express x 16 (v2.0 - wired as x4)
  • (1) PCI Express x16 (v3.0)
  • (1) Optional PCI (v2.3)
Graphics
  • Integrated Intel HD Graphics
  • Discrete AMD Radeon HD 8350, 849030, NVIDIA NVS 310, 315, or NVIDIA GeForce GT630 graphics optional
Communications
Integrated Intel I217LM Gigabit Network Connection; optional wireless LAN card available
Ports and connectors
Front:
  • (2) USB 2.0 ports
  • (2) USB 3.0 ports, microphone, headphone
Rear:
  • (4) USB 2.0 ports
  • (2) USB 3.0 ports, stereo audio out, line in, RJ-45 Ethernet, PS/2 mouse and keyboard, VGA, (2) DisplayPort with multi-stream4, power connector, RS-232 serial port
Input devices
  • PS/2 keyboard
  • USB keyboard
  • Wireless Keyboard and Mouse
  • USB CCID SmartCard keyboard
  • USB PS/2 Washable keyboard
  • PS/2 mouse
  • USB Optical mouse
  • USB 1000 dpi Laser mouse
  • USB PS/2 Washable Scroll mouse
Power
Internal 320-W power supply, Active PFC, up to 94% efficient
Audio specifications
Specification
Type
Integrated
HD stereo codec
Realtek 2-channel ALC221 codec
Audio I/O ports
Front microphone-In (150-K ohm Input Impedance)
Internal speaker amplifier
1.5-W amplifier for the internal speaker only. External speakers must be powered externally. Rear Line-in audio port is re-taskable as either Line-in or Microphone-In.
Multi-streaming capable
Multi-streaming can be enabled in the Realtek control panel to allow independent audio streams to be sent to/from the front and rear jacks.
Sampling
8 kHz - 192 kHz
Wavetable syntheses
Yes - Uses OS soft wavetable
Analog audio
Yes
# of channels on Line-Out
Stereo (Left & Right channels)
Internal speaker
Yes
External speaker jack
Yes
Full duplex
Yes
Input/Output devices
HP USB keyboard
Specification
Physical characteristics
Keys
104, 105, 106, 107, 109 layout (depending upon country)
Dimensions (L x W x H)
46.03 x 16.43 x 2.44 cm (18.12 x 6.47 x 0.96 in)
0.9 kg (2 lb)
Electrical
Operating voltage
+ 5 V dc ± 5%
Power consumption
50 mA maximum (with three LEDs On)
System interface
USB Type A plug connector
ESD
CE level 4, 15 kV air discharge
EMI - RFI
Conforms to FCC rules for a Class B computing device
Microsoft PC 99 - 2001
Functionally compliant
Mechanical
Keycaps
Low-profile design
Switch actuation
55 g nominal peak force with tactile feedback
Switch life
20 million keystrokes (using Hasco modified tester)
Switch type
Contamination-resistant switch membrane
Key-leveling mechanisms
For all double-wide and greater-length keys
Cable length
1.8 m (6 ft)
Mechanically compliant
Acoustics
43-dBA maximum sound pressure level
Environmental
Operating temperature
10° to 50°C (50° to 122°F)
Non-operating temperature
-30° to 60°C (-22° to 140°F)
Operating humidity
10% to 90% (non-condensing at ambient)
Non-operating humidity
20% to 80% (non-condensing at ambient)
Operating shock
40 g, six surfaces
Non-operating shock
80 g, six surfaces
Operating vibration
2 g peak acceleration
Non-operating vibration
4 g peak acceleration
Drop (out of box)
66 cm (26 in) on carpet, six-drop sequence
Drop (in box)
76.2 cm (30 in) on concrete, 16-drop sequence
Approvals
UL, CSA, FCC, CE Mark, TUV, TUV GS, VCCI, BSMI, C-Tick, MIC
Ergonomic compliance
UL, CSA, FCC, CE Mark, TUV, TUV GS, VCCI, BSMI, C-Tick, KC
Kit contents
Keyboard
Installation guide
Warranty card
Safety and comfort guide
HP PS/2 keyboard
Specification
Keys
Dimensions
46.28 x 16.43 x 2.79 cm (18.22 x 6.47 x 1.1 in)
(L x W x H)
0.9 kg (2 lb) minimum
Electrical
Operating voltage
+ 5 V dc ± 5%
Power consumption
50-mA maximum (with three LEDs On)
System interface
PS/2 6-pin mini din connector
ESD
CE level 4, 15-kV air discharge
EMI - RFI
Mechanical
Keycaps
Low-profile design
Switch actuation
55-g nominal peak force with tactile feedback
Switch life
Switch type
Cable length
1.8 m (6 ft)
Acoustics
50-dBA maximum sound pressure level
Environmental
0° to 40°C (32° to 104°F)
-30° to 65°C (-22° to 149°F)
Operating humidity
15% to 80% (non-condensing at ambient)
15% to 90% (non-condensing at ambient)
Operating shock
N/A
Non-operating shock
2.9 ms (65 in), six surface; 30 g 266 in/s; 50 g 266 in/s six surface
Operating vibration
2-g peak acceleration
Starting at 5 Hz, vary the frequency of vibration from 5 to 500 Hz and back to 5 Hz at a Logarithmic sweep rate of 1 octave per minute.
Drop (out of box)
66 cm (26 in) on carpet, 6-drop sequence
Drop (in box)
76 cm (29.93 in) on concrete, 16-drop sequence
Approvals
CUL, ICES-003 Class B, FCC, CE Mark,TUV GS, VCCI, BSMI, C-Tick, KC
ANSI HFS 100, ISO 9241-4, and TUVGS
HP USB Smart Card (CCID) keyboard
Specification
Keys
46.3 x 16.1 x 3.3 cm (18.2 x 6.3 x 1.3 in)
Electrical
Operating voltage
+ 5 V dc ± 5%
Power consumption
100 mA maximum (with three LEDs On)
System interface
ESD
EMI - RFI
Mechanical
Languages
30+ available
Keycaps
Standard design
Switch actuation
Switch life
Switch type
Cable length
1.8 m (6 ft)
Acoustics
Environmental
Operating humidity
Operating shock
40-g, six surfaces
Non-operating shock
80-g, six surfaces
Operating vibration
4-g peak acceleration
Drop (out of box)
Drop (in box)
107 cm (42 in) on concrete, 16-drop sequence
Support
All ISO 7816 smart cards
Interface
Reads from and writes to all ISO7816-1, 2, 3, 4 memory and microprocessor smart cards (T=0, T=1)
SCM STCIII
Standard APIs supported
PC/SC, EMV2000, CT-API
Power
USB Port Short circuit detection (protects smart card and reader)
SmartCard function
Power consumption
100 mA maximum draw
Communication
  • From card 9600 bps to 330,000 bps
  • From computer 12 Mbps (USB transfer speed)
Landing mechanism
  • Contact device: Friction contact
  • Card insertions rating: Up to 100,000 insertion cycles
Interface modes
CCID protocol
Reader performance interface
USB connection
Electro-magnetic standards
  • Europe: 2004/108/EC
  • USA: USAFCC part 15
Approvals
CE-Mark, UL, CSA, FCC, CE Mark, TUV, TUV GS, VCCI, BSMI, C-Tick, MIC, EMV2000, USB-IF
ISO 9241-4, TUVGS
Kit contents
Keyboard, I/O Security and Documentation CD, warranty card
HP USB PS/2 washable keyboard
Specification
Keys
104 (US) layout or 105 (EU) layout – depending upon country
449 x 168 x 35 mm (17.67x 6.62 x 1.38 in)
0.77 kg (1.7 lb) minimum
Electrical
Operating voltage
+ 5 V dc ±5%
Power consumption
System interface
ESD
EMI - RFI
Mechanical
Keycaps
Stepped -profile design
Switch actuation
Switch life
Switch type
Cable length
2.2 m (7 ft)
Environmental
Acoustics
Operating humidity
10% to 95% (non-condensing at ambient)
Operating shock
40 g, six surfaces
Non-operating shock
80 g, six surfaces
Operating vibration
Drop (out of box)
Drop (in box)
Operating system support
Windows 7, Windows Vista, Windows XP Professional
Approvals
UL, cUL, FCC, CE, TUV GS, VCCI, BSMI, C-Tick, KCC, USB-IF, WHQL, EN/IEC 60601-1, IP66/NEMA4X
HP Wireless keyboard and mouse specifications
Specification
Keyboard
Dimensions (H x L x W)
27.87 x 460.3 x 164.3 mm (1.09 x 18.1 x 6.47 in)
Weight - without Two AA Alkaline Batteries
880 g (1.94 lb)
Mouse
37 x 115 x 62.9 mm (1.46 x 4.53 x 2.47 in)
67 g (0.15 lb)
Receiver
8.4 x 45.5 x 18.4 mm (0.33 x 1.79 x 0.72 in)
5.9 g (0.21 oz)
Cable length - minimum
1.8 m (6 ft)
Range
10 m (32.8 ft)
System requirements1
  • Windows 7 Home Basic, Windows 7 Home Premium, Windows 7 Professional Edition 32, Windows 7 Professional Edition 64, Windows 7 Ultimate Edition 32, Windows 7 Ultimate Edition 64 Windows Vista or Windows XP
  • Available USB port for the receiver
  • CD-ROM Drive
Approvals
Product Safety
UL; CSA /TUV (Europe only); CE Mark; CB Report
Ergonomics
ANSI; ISO (Europe only); GS Mark (Germany only)
EMC
FCC; CE; ACA (-tick); BSMI; KC ; VCCI
CE Mark
EN 55022:2010; EN 55024; EN 301489-1; EN 61000
Design Guidelines for PCs
PC 99 - connector overmold colors; PC 2001 - full functionality
Telecom
All local telecom requirements and approvals for intended markets
USA
FCC Title 47 CFR, Par 15, Subpart C; other local requirements
Country Support
US, Belgium, Switzerland, Spain, Denmark, Netherlands, France, Germany, Italy, Portugal, Sweden, Norway, Finland, UK, Poland, Czech Republic, Turkey, Greece, Austria, Bulgaria, Cyprus, Estonia, Hungary, Ireland, Latvia, Lithuania, Luxemburg, Malta, Romania, Slovakia, Slovenia, Vietnam, HK, Australia, NZ, Malaysia, Singapore, Indonesia, Philippines, Thailand, Canada, China, Japan, Korea, Taiwan, India, Venezuela, Ecuador, Russia, Ukraine, Israel, Croatia, United Arab Emirates, Peru, Brazil, Chile, Argentina, Mexico, South Africa, and up to 193 countries worldwide.
1: This system may require upgraded and/or separately purchased hardware and/or a DVD drive to install the Windows 7 software and take full advantage of Windows 7 functionality.
HP USB PS/2 washable mouse specifications
Specification
3.95 x 6.21 x 11.7 cm (1.56 x 2.44 x 4.61 in)
126 g (4.44 oz)
Environmental
0° to 40°C (-32° to 104°F)
-20° to 60°C (-4° to 140°F)
Operating humidity
10% to 90% non-condensing
Operating shock
40 g, 6 surfaces
Non-operating shock
80 g, 6 surfaces
Operating vibration
Drop (out of box)
80 cm height onto asphalt tile over concrete or equivalent, 5-drop in 5 direction except the cable face
Electrical
Operating voltage
5 V dc ± 10%
Power consumption
100 mA
System consumption
PS/2 mini-din connector or USB
ESD
CE level 2, 8 kV air discharge
EMI-RFI
Microsoft PC99 – 2001
Mechanical
Resolution
1000 ± 20% DPI
Tracking speed
35.56 cm/s (14 in/s) maximum
Acceleration
2 g
Switch actuation
70 g nominal peak force
Switch life
3,000,000 operations (using Hasco modified tester)
Switch type
Low force micro-switches
Cable length
8.8 ft total 70 cm+ 2m extension
Scroll wheel
Width
6 mm
Diameter
25.4 mm (1 in)
Maximum rotation speed
48 rats/sec
Switch type
Light force micro-switch
Switch life
3 million operations
Mechanical life
Minimum 200,000 revolutions
Regulatory approvals
Compliant
FCC, CE Mark, ICES-003-B, IP66/NEMA4X
HP PS/2 mouse
3.70 x 6.29 x 11.50 cm (1.46 x 2.48 x 4.53 in)
3.53 oz (100g; +10g/- 5 g)
Operating humidity
10% to 90% (non condensing at ambient)
Operating shock
40 g, 6 surfaces
Non-operating shock
80 g, 6 surfaces
Operating vibration
Drop (out of box)
Operating voltage
5 V dc ± 10%
Power consumption
100 mA
System consumption
ESD
EMI-RFI
Microsoft PC99 - 2001
Resolution
800 DPI
Tracking speed
10 in/s (25.4 cm/s) maximum
Acceleration
±15%
Switch actuation
65±20 gf
Switch life
Switch type
Tracking mechanism life
80 km
Cable length
1.8 m (6 ft)
Width
6 mm
Diameter
22.5 ± 0.2 mm
Maximum rotation force
50 gf-cm
Switch type
Switch life
1 million operations
Mechanical life
Regulatory Approvals
UL/cUL, FCC, CE Mark, TUV/GS, VCCI, KCC, BSMI, C-Tick
HP USB mouse
Specification
3.8 x 11.6 x 6.3 cm (1.5 x 4.5 x 2.5 in)
0.10 kg (0.22 lb)
Cable length
180 cm (70.9 in)
System requirements
Available USB port
HP USB 1000 dpi laser mouse
Specification
37.3 x 114.97 x 62.86 mm (1.47 x 4.53 x 2.47 in)
102 g (3.360 oz)
Cable length
180 cm (70.9 in)
System requirements
Available USB port
Environmental
Operating humidity
Mechanical
Resolution
1000 dpi
Tracking speed
45 cm/s
Cable length
180 cm (70.9 in)
Power supply specifications
Specification
Standard efficiency
320 W active PFC
High efficiency1
Integrated graphics:
  • 320 W active PFC
  • 87/90/87% efficient at 20/50/100% load
Operating voltage range
90 - 264 V ac
Rated voltage range
100 - 240 V ac
Rated line frequency
50/60 Hz
Operating line frequency   range
47 - 63 Hz
Rated input current
5.5 A
Rated input current with   energy
5.5 A
Current leakage   (NFPA 99)
< 450=>275 µA
Power supply fan
92 mm variable speed
Power cord length
1.83 m (6 ft)
1: High efficiency power supply is a requirement for ENERGY STAR qualification in conjunction with a select range of processors and modules.
Physical specifications
Specification
Chassis (H x W x D)
399 x 170 x 442 mm (15.7 x 6.7 x 17.4 in)
System volume
30 L (1828 cu in)
System weight
9.3 kg (20.5 lb)
Packaging   (H x W x D)
295 x 500 x 590 mm (11.6 x 19.7 x 23.2 in)
Shipping weight
13.1 kg (28.8 lb)
Palletization profile
  • 4-units per layer
  • 8-layer max
  • 32-units per pallet
Software/OS
Feature
Operating Systems
Preinstalled
  • Windows 8 Pro (64-bit)
  • Windows 8 (64-bit)
  • Windows 7 Ultimate (32-bit)
  • Windows 7 Ultimate (64-bit)
  • Windows 7 Professional (32-bit)
  • Windows 7 Professional (64-bit)
  • Windows 7 Professional (32-bit) (available through downgrade rights from Windows 8 Pro)
  • Windows 7 Professional (64-bit) (available through downgrade rights from Windows 8 Pro)
  • Windows 7 Home Premium (32-bit)
  • Windows 7 Home Premium (64-bit)
  • FreeDOS 2.0
  • Novell SUSE Linux Enterprise Desktop 11
Supported
  • Windows 7 Enterprise (32-bit or 64-bit)
  • Windows 8 Enterprise (64-bit)
Limited support
Windows XP Professional (32-bit)
Certified
  • Red Hat Enterprise Linux 64
Test & Document1
  • Windows Vista Enterprise (32-bit or 64-bit)
  • Windows Vista Professional (32-bit or 64-bit)
1: For all Test & Document operating systems HP will perform functional testing of the Operating System on the HP business PC platform. Any issues found will be documented in an Engineering Advisory and/or Service Advisory and posted to HP. HP will not develop or qualify any drivers or perform any integration testing.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
