    Windows 11 Upgrade Guide
HP SlateBook PCs - Using and Customizing the Lock Screen (Android 4.3, 4.2/Jelly Bean)
This document applies to HP notebook computers with Android 4.3 or 4.2/Jelly Bean operating system.
When your notebook is in sleep mode with the screen locked, the LCD screen is turned off and does not respond to touch. To begin using the notebook again, you must unlock the screen using whichever unlock method is currently set. Use this document to learn more about the available lock screen settings and unlock methods.
Depending on the version of Android installed on your tablet, some of the images in this document may not match your tablet exactly.
Locking and unlocking the screen
The power button of the SlateBook is located in the top right corner behind the notebook display. Use the power button to turn the LCD screen on or off.
  • With the screen on, press the power button briefly to turn off and lock the LCD screen.
  • With the screen off, press the power button briefly to display the lock screen. To unlock the default lock screen, touch the lock icon and slide your finger over to the unlocked icon, or click and drag the lock icon to the outer circle. Or, if you have set a pattern, PIN, or password for the lock screen, unlock the screen with your personalized unlock method. See the next sections for more information.
Choosing a pattern, PIN, or password for your lock screen in Android 4.2 or 4.3
Setting a pattern, PIN, or password for your SlateBook can enhance the security of the private information you have stored on your notebook. With personalized lock screen protection set, no unauthorized person can use your notebook without resetting it to factory settings.
  1. On the Home screen, click or touch the All apps icon, and then click or touch the Settings icon.
  2. In the Personal section, click or touch Security.
    Figure : Security
    Security in the Personal section of Settings
  3. Click or touch Screen lock.
    Figure : Screen lock
    Screen lock in the Security settings menu
  4. Choose your preferred unlock method:
    Figure : Choose screen lock
    Choose screen lock
    • Pattern: With the pattern lock method, draw a personalized pattern by sliding your finger over the screen to connect a series of dots in any order. Or, click and drag the mouse pointer over the screen to connect the dots. When you press the power button, the dots appear on-screen. To unlock the screen, draw the pattern using your finger or mouse.
    • PIN: This method uses a 4-digit PIN code to unlock the notebook. When you touch the power button, a keypad appears on-screen. To unlock the notebook, click or touch the keypad numbers to enter your four-digit PIN number, and then click or touch OK.
    • Password: Create a password with letters, numbers, and/or symbols to unlock your notebook. When you press the power button, a password entry field appears. Click or touch inside the entry field, type your password, and then click or touch Done.
