    Windows 11 Upgrade Guide
HP SlateBook PCs - Frequently Asked Questions About Your HP Notebook (Android 4.3, 4.2/Jelly Bean)
This document applies to HP notebook computers with Android 4.3 or 4.2/Jelly Bean operating system.
Refer to this document for answers to frequently asked questions (FAQs) about your HP notebook.
Depending on the version of Android installed on your tablet, some of the images in this document may not match your tablet exactly.
This video shows features and tips for using your HP notebook (Android 4.2/Jelly Bean)
How do I make the SlateBook screen auto-rotate in Android 4.2 or 4.3?
How do I surf the Internet on my SlateBook in Android 4.2 or 4.3?
How do I install software on my SlateBook in Android 4.2 or 4.3?
Can I use my SlateBook without an Internet connection?
Can I connect the SlateBook to another computer to transfer files?
How do I open files on my SlateBook?
Where do I save files on my SlateBook?
Can I replace the batteries of my SlateBook?
Can I still use the physical keyboard of my SlateBook when the tablet screen is disconnected?
Can I add a screen protector to the SlateBook screen?
Do I need a data plan for my SlateBook?
Where can I find the Wi-Fi MAC address of my SlateBook in Android 4.2 or 4.3?
Can I install a different operating system on my SlateBook, like Windows?
Can I reset my SlateBook?
Where can I find technical support for my SlateBook?
