HP products - My operating system is not listed on HP Software and Driver Downloads
If you do not see the version of your operating system (OS) listed on the software download site for your HP product, HP does not have any downloadable software or drivers for your product for that operating system.
Many issues can be resolved by ensuring you have both the latest OS version supported for your HP product with all updates installed, and the latest HP driver updates.
If you have an HP printer, you might find a driver at 123.hp.com.
Use caution when dealing with non-HP websites offering HP driver downloads or diagnostic tools. Some sites look professional, but may charge fees, steal personal information, or worse.
Only install PC BIOS updates from HP. Installing BIOS updates from other sites can result in loss of data or functionality.
Alternative solutions might be available for your HP printer or computer.
