HP ProBook 450 G0 Notebook PC Product Specifications
Product description
HP ProBook 450 G0 has a choice of 3rd generation Intel Core, Celeron, or Pentium processors. It comes with a 15.6-inch HD anti-glare display. There's an optional touchscreen display for this laptop series. Switch to the storage, the laptop offers up to 1 TB of HDD and 128GB SSD.
Product features
Feature
Processors
  • 3rd Generation Intel Core i7-3632QM (2.2 GHz, 6MB L3 cache, 4 cores)
    Up to 3.20 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i5-3380M (2.9 GHz, 3MB L3 cache, 2 cores)
    Up to 3.60 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i5-3340M (2.7 GHz, 3MB L3 cache, 2 cores)
    Up to 3.40 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i5-3230M (2.6 GHz, 3MB L3 cache, 2 cores)
  • 3rd Generation Intel Core i3-3130M (2.6 GHz, 3MB L3 cache, 2 cores)
  • 3rd Generation Intel Core i3-3120M (2.5 GHz, 3MB L3 cache, 2 cores)
  • Intel Pentium 2020M (2.4 GHz, 2MB cache, 2 cores)
  • Intel Celeron 1000M (1.8 GHz, 2MB L3 cache, 2 cores)
Mobile Intel HM76 Express
Graphics
Integrated:
  • Intel HD Graphics 4000 (3rd Generation Intel Quad-Core i7 and Dual-Core i5 and i3)
  • Intel HD Graphics (Celeron and Pentium configurations)
Discrete:
  • AMD Radeon HD 8750M, with 1 or 2GB dedicated DDR3 video memory
  • Internal
    • 15.6" diagonal LED-backlit HD anti-glare Touch Display supports Anti-scratch, Anti-smudge, Anti-reflection and Anti-Shatter (1366 x 768)
    • 15.6" diagonal LED-backlit HD anti-glare (1366 x 768)
  • External: Up to 32-bit per pixel color depth.
  • VGA: Port supports resolutions up to 2048 x 1536 external resolution at 75 Hz
  • HDMI: Supports direct connection to high-definition displays with up to 1920 x 1200 at 60Hz resolution and 7-channel audio with one convenient cable (not included)
Storage and drives
Primary storage bay
Hard drives
  • 320/500/750GB/1TB 5400 rpm SMART SATA II HDD
  • 500GB 7200 rpm SMART SATA II HDD
  • 500GB 5400 rpm SMART SATA II Hybrid HDD
Solid state drive
  • 128 GB 2.5 inch Solid state drive
HP 3D DriveGuard (Windows only)
  • The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive.
Optical drives
Fixed 9.5 mm SATA optical drive
  • Blu-ray ROM DVD+/-RW SuperMulti DL drive1
  • DVD+/-RW SuperMulti DL drive
  • DVD-ROM drive
Memory
Standard
  • DDR3L SDRAM (1600 MHz)
  • Two SODIMM slots supporting dual-channel memory
  • 2GB, 4GB, and 8GB SODIMMs
Maximum
  • Upgradeable to 16384MB with optional 8192MB SODIMMs in slots 1 and 2
Dual-channel
  • Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Networking/Communications
Wireless
  • Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Broadband Wireless (WWAN) requires a Windows operating system and is available in select countries as a standard, factory configurable feature only. Integrated Bluetooth is also available (factory configurable only) and can be combined with any of the supported wireless LAN and wireless WAN options.
  • HP hs3110 HSPA+ Mobile Broadband Module
  • HP lt4112 LTE/HSPA+ Gobi 4G Module
Wireless LAN (WLAN)
  • Atheros 802.11 b/g/n (1x1)
  • Ralink 802.11 b/g/n (1x1) with Bluetooth v4.0 combo
  • Broadcom 802.11 a/b/g/n (2x2) with Bluetooth v4.0 combo
  • Intel Centrino Wireless-N 2230 802.11 a/b/g/n (2x2) WiFi and Bluetooth 4.0 Combo Adaptor
Communications
  • Realtek 10/100/1000 Ethernet controller
Audio/Multimedia
Audio
  • DTS sound
  • Integrated stereo speakers
  • Integrated digital microphone (dual-microphone array when equipped with optional webcam)
  • Function keys for microphone mute, volume up, volume down
  • Stereo headphone/line out
  • Stereo microphone/line in
Optional 720p HD webcam
  • HD format (widescreen)
  • Supports videoconferencing (non-HD) and still image capture
  • High quality fixed focus lens
  • Video capture at various resolutions up to 1280x720 resolution (720p) and up to 30fps
  • M-JPEG compression supports higher frame rates for video capture and videoconferencing
  • Improved low light sensitivity
  • Improved dynamic range
  • Skype-ready
Keyboard/Pointing devices/Buttons and function keys
Keyboard
  • The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard. The 101/102-key compatible keyboard features a full-pitch key layout with desktop keyboard features, such as editing keys, both left and right control and alt keys, and function keys. US and International key layouts are available.
Pointing devices
  • Touchpad with gestures support, on/off button with LED indicator, two-way scroll, two pick buttons.
  • Separate launch buttons provide easy access to wireless on/off Volume mute. Function keys provide control of features including: standby mode, display brightness, external display, microphone mute, volume down, and volume up.
System specifications
Specification
Stand-Alone power
Nominal operating: 19 V
Requirements (AC Power)
Voltage
Average operating power:
  • ProBook 450 integrated graphics:
    • Windows 7 (64-bit): 8.8 W
    • Windows 8 (64-bit): 8.7 W
  • ProBook 450 discrete graphics:
    • Windows 7 (64-bit): 9.68 W
    • Windows 8 (64-bit): 9.22 W
Temperature
Operating
  • 0° to 35° C (32° to 95° F) (not writing optical)
  • 5° to 35° C (41° to 95° F) (writing optical)
Non-operating
  • -20° to 60° C (-4° to 140° F)
Relative humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 101.6° F (38.7° C) maximum wet bulb temperature
Shock
Operating: 40 G, 2 ms, half-sine
Non-operating: 200 G, 2 ms, half-sine
Random Vibration
Operating: 0.75 grms
Non-operating: 1.50 grms
Altitude (unpressurized)
Operating:
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating:
-15.24 to 12,192 m (-50 to 40,000 ft)
Planned industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC Compliance: Yes
  • ENERGY STAR: TBD models
  • EPEAT: Registered TBD in United States
  • ICES: Yes
  • Australia/NZ A-Tick Compliance: Yes
  • CCC: Yes
  • Japan VCCI Compliance: Yes
  • KC: Yes
  • BSMI: Yes
  • CE Marking Compliance: Yes
  • BNCI or BELUS: Yes
  • CIT: Yes
  • GOST: Yes
  • Saudi Arabian Compliance (ICCP): Yes
  • SABS: Yes
  • UKRSERTCOMPUTER: Yes
Display specifications
Specification
14.0-inch LED HD (1366 x 768) anti-glare
Dimensions (W x H)
32.09 x 18.76 cm (12.63 x 7.39 in)
Diagonal size
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
400 : 1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Pitch: 0.227 mm
  • Format: 1366 x 768
  • Configuration: RGB Stripe
Backlight
LED
PPI
112 ppi
Viewing angle
  • ±30° Horizontal, ±10° Vertical (minimum)
  • 30/30/20/10 (Left/Right/Down/Up) (minimum) or
  • 45/45/35/25 (Left/Right/Down/Up) (typical)
15.6-inch LED HD (1366 x 768) anti-glare with Touch
Dimensions (W x H)
34.39 x 19.41 cm (13.54 x 7.64 in)
Diagonal size
39.6 cm (15.6 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Pitch: 0.252 x 0.252
Backlight
LED
PPI
106 ppi
Viewing angle
Dimensions (W x H)
36.0 x 22.43 cm (14.17 x 8.83 in)
Diagonal size
39.6 cm (15.6 in)
Surface treatment
Anti-glare
Contrast ratio
400 : 1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Pitch: 0.252 mm
Backlight
LED
PPI
106 ppi
Viewing angle
17.3-inch LED HD+ antiglare
Dimensions (W x H)
38.2 x 21.5 cm (15.0 x 8.5 in)
Diagonal size
43.9 cm (17.3 in)
Surface treatment
Anti-glare
Contrast ratio
400 : 1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Pitch: 0.23868 x 0.23868 mm
  • Format: 1600 x 900
Backlight
LED
PPI
106 ppi
Viewing angle
HDD specifications
Specification
500 GB 7200 rpm SATA Hard Drive
Drive weight
115g (0.25 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer rate
Synchronous (maximum) 300MB/s (Drive Capability)
Seek time (typical reads, including settling)
  • Single Track: 1.5 ms
  • Average: 11 ms
  • Maximum: 22 ms
Rotational speed
7200 rpm
Logical blocks
976,773,168
Operating temperature
0° to 60° C (32° to 140° F) [case temp]
Features
ATA security
320 GB 5400 rpm SATA Hard Drive
Drive weight
101 g (0.22 lb)
Capacity
320GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Single Track: 3 ms
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
625,142,448
Features
ATA Security
500 GB 5400 rpm SATA Hard Drive
Drive weight
101 g (0.22 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA security
750 GB 5400 rpm SATA Hard Drive
Drive weight
101 g (0.22 lb)
Capacity
750GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
1,465,149,168
Features
ATA security
1 TB 5400 rpm SATA Hard Drive
Drive weight
115 g (0.254 lb)
Capacity
1TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
1,953,525,168
Features
ATA security
500 GB 5400 rpm SMART SATA II Hybrid Hard Drive
Drive weight
95 g (0.209 lb)
Capacity
500GB
Height
7 mm (0.276 in)
Width
70.1 mm (2.76 in)
Interface
Transfer rate
Synchronous (maximum) 600MB/s (Drive Capability)
  • Single Track: 2 ms
  • Average: 12 ms
  • Maximum: NIL ms
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA security
SATA 6 Gb/s 128 GB, 2.5- inch Solid State Drive
Drive weight
73 Grams
Capacity
128GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance rate
Maximum Sequential Read: 415MB/s
Maximum Sequential Write: 175MB/s
Logical blocks
250,069,680
0° to 70°C (32° to 158°F) [case temp]
Features
ATA security; ATA-8; SATA 3.0; DIPM; TRIM
Optical drives
Specification
DVD+/-RW SuperMulti DL Drive
Access times
Random
  • Less than 140ms CD (typical)
  • Less than 160 ms DVD (typical)
Max data transfer rate
  • 24X CD-ROM
  • 8X DVD
  • 24X CD-R
  • 24X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 5X DVD-RAM
Transfer mode
UDMA Mode 5
Interface
Gen 1 SATA
Supported media (read)
CD-DA, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
Supported media (write)
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM, DVD+R DL, DVD-R DL
Max media capacity (read)
8.5GB
Max media capacity (write)
8.5GB
Transport
Tray loading
Blu-ray ROM DVD+/-RW SuperMulti DL Drive
Access times
Random
  • Less than 190 ms CD-ROM (typical)
  • Less than 180ms DVD-ROM (typical)
  • Less than 230 ms BD-ROM (typical)
  • 24X CD-ROM
  • 8X DVD-ROM
  • 24X CD-R
  • 16X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 4X - DVD+R Dual Layer
  • 4X - DVD-R Dual Layer
  • 5X DVD-RAM
  • 6X BD-ROM
Transfer mode
UDMA mode 5
Interface
Gen 1 SATA
CD-DA, , CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW. DVD-RAM, BD-ROM, BD-R, BD-RE
CD-R, CD-RW, DVD+R, DVD+R DL, DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVDRAM
50.0GB
8.5GB
Transport
Tray loading
Security
Specification
HP fingerprint sensor
Mobile voltage operation
3.0 V-3.6 V single supply
0° - 70°C (32° - 158°F)
Current consumption at 3.3 V
  • Less than 70 mA peak imaging and scrolling
  • Less than 25 mA hardware finger detection
  • Advanced power management
High-rate image capture
Up to 240 image frames /sec
ESD resistance
IEC 61000-4-2 Level 4 (±15KV)
Detection matrix
  • 192 x 16 pixels
  • 9.7 mm x 0.81 mm
  • 500 ppi High-Resolution images
Specification
Wireless
  • HP hs3110 HSPA+ mobile broadband module
  • HP lt4112 LTE/HSPA+ Gobi 4G module
Wireless LAN (WLAN)
  • Ralink 802.11 b/g/n (1x1) with bluetooth v4.0 combo
  • Broadcom 802.11 a/b/g/n (2x2) with bluetooth v4.0 combo
  • Intel Centrino Wireless-N 2230 802.11 a/b/g/n (2x2) WiFi and Bluetooth 4.0 Combo adaptor
Communications
Realtek 10/100/1000 ethernet controller
Supports Bluetooth v2.1 on Linux operating systems
Audio/Multimedia - DTS sound
Specification
Implementation
IDT 92HD91
Function key volume
Volume up, volume down, and mute
Full duplex
Yes
Microphone in
Stereo
Headphone/line out
Stereo
Integrated microphone
Yes, dual digital microphone array when equipped with optional webcam
Audio output quality
Frequency response
20 Hz - 20 kHz
Signal to noise ratio
Less than 85 dB
Total harmonic distortion
0.01 %
Noise floor
- 110 dB
Play/Record sampling rate(s)
8 kHz - 48kHz
DAC
16, 20 or 24-bit
ADC
16 or 20-bit
Internal stereo speakers
Power rating
2 Watts
Impedance
4 ohms
Power
HP 90W Smart AC Adapter (discrete configurations)
Dimensions
12.7 x 5.0 x 2.9 cm (5.00 x 1.97 x 1.1 in)
370 g (0.82 lb)
Input
100 to 240 Vac
Input efficiency
87% min at 115 Vac
Input frequency range
47 to 63 Hz
Input AC current
  • 1.5 A at 90 VAC, 0.75 A at 180 Vac PFC version
  • 2.4 A at 90 Vac, 1.2 A at 180 Vac NON PFC version
Output
Output power
90 W
DC output
19.0 V
Hold-up time
5 msec at 115 Vac input
Output current limit
11A, over voltage protection- 29 V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
0° to 40° C (32° to 104° F)
Non-operating (storage) temperature
-20° to 65° C (-4° to 149° F)
Altitude
0 to 3,048 m (0 to 10,000 ft)
Humidity
20% to 80%
Storage humidity
10% to 90%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF- over 200,000 hours at 25°C ambient condition.
HP 65W Smart AC Adapter (Configurations with integrated graphics)
Dimensions
10.6 x 4.7 x 2.8 cm (4.17 x 1.85 x 1.1 in)
280 g (0.62 lb)
Input
100 to 240 Vac
Input efficiency
87% min at 115 Vac
47 to 63 Hz
Input AC current
1.7 A at 90 Vac, 0.85 A at 180 Vac
Output power
Output power
65 W
DC output
18.5 V
Hold-up time
11 A, over voltage protection- 29 V max automatic shutdown
Connector
Altitude
Humidity
20% to 80%
Storage humidity
10% to 95%
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF - over 200,000 hours at 25°C ambient condition.
9-Cell (93 WHr) Lithium- Ion battery
Dimensions (H x W x L)
4.0 x 4.7 x 26.9 cm (1.57 x 1.85 x 10.59 in)
Weight (max)
0.488 kg (1.07 lb)
Cells/Type
9-cell Lithium-Ion
Energy
Watt-hour capacity
93 WHr
Temperature
Operating (Charging)
0° to 45° C (32° to 113° F)
Operating (Discharging)
(-10° to 60° C (14° to 140° F)
Non-operating
Battery Re-Charge Time
System in OFF or standby mode
3 to 4 hours
System ON
4 to 6 hours (depending on system power consumption)
6-Cell (47 WHr) Lithium- Ion battery
2.16 x 4.46 x 26.9cm
0.312kg (90.70lb)
Cells/Type
6-cell Lithium-Ion
Energy
Voltage
10.8 V
Amp-hour capacity
4.4 Ah
Watt-hour capacity
47 Wh
Temperature
Non-operating
Battery re-Charge time
2.5 hours
System ON
3 to 5 hours
Fuel gauge LED
No
1 year
Optional travel battery available
No
Physical specifications
Feature
Weights and dimensions
  • Starting at 2.4 kg (5.28 lb) with optical drive (weight will vary by configuration)
  • Starting at 2.29 kg (5.00 lb) without optical drive (weight will vary by configuration)
Dimensions (w x d x h)
  • 14.76 x10.09 x 0.9 (front) - 1.14 in (at rear)
  • 37.5 x 25.6 x 2.28 (front) - 2.9 cm (at rear)
Ports/Slots
Ports
  • USB 3.0 - Two
  • USB 2.0 - Two
  • HDMI 1.4a - One
  • VGA - One
  • Stereo microphone input - One
  • Headphone/line out - One
  • RJ-45 (Ethernet) - One
  • Power connector – One
Digital media slots
ulti media reader slot supporting SD, SDHC, SDXC, Memory stick, MSXC
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components.
Software/OS
Feature
Preinstalled operating system
  • Windows 8 Pro 641
  • Windows 7 Professional (available through downgrade rights from Windows 8 Pro
  • Windows 8 64
  • Windows 7 Professional 64
  • Windows 7 Home Premium 64
  • Windows 7 Home Basic 64
  • SUSE Linux Enterprise Desktop 11
  • FreeDOS
Preinstalled software with windows operating system
  • HP Wireless Hotspot
  • Cyberlink Media Suite
  • HP ePrint
  • HP Hotkey support
  • HP 3D Driveguard
  • PDF Complete Corporate Edition
  • Skype ready
  • HP Recovery Manager
  • Evernote
  • HP Support Assistant
  • Buy Office
  • Intel Wireless Display
Security
Standard
  • HP Client Security
  • Microsoft Security Essentials(Windows 7)/Microsoft Defender (Windows 8)
  • HP Drive Encryption
  • HP BIOS Protection
  • Security lock slot
Optional
  • Intel Anti-Theft (requires a Computrace subscription)
  • Intel Identity Protection
  • HP Fingerprint reader
Power
Power supply
  • Models with discrete graphics: External 90W HP Smart AC Adapter
  • Models with integrated graphics: External 65W HP Smart AC Adapter
  • Power cord included is 6-foot (1.8 meter)
  • Total length including external AC adapter is 12 feet (3.66 meter)
  • HP Fast Charge
Primary battery
  • HP 9-cell Lithium-Ion Battery (93 WHr)
  • HP 6-cell Lithium-Ion Battery (47 WHr)
Battery life
  • TBD
System standby time
  • Up to TBD weeks
Power conservation
  • Supports enhanced Intel SpeedStep technology (allows Battery Optimized Mode, Maximum Performance Mode, or Automatic mode)
  • AMD PowerPlay technology (discrete models)
  • Hibernation
  • Standby
  • ACPI compliance
Important link
List of available documents for the HP ProBook 450 G0 Notebook PC
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
