HP Tablets - How Do I Find My Model Number?
This document describes how you can find the model number or product number that represents your exact type of HP or Compaq tablet. You can use the model number or product number to find helpful documents or get online support. If needed, you may also use this document to find the serial number, which is always listed near the model number or product number.
Compaq 7, Compaq 7 Plus, and Compaq 8 Tablets
The model number and product number are located on the back of your tablet, near the bottom edge.
Figure : Compaq 7 product number and model number location
HP Slate 6 VoiceTab and Slate 7 VoiceTab
The model number is located on a service tag under the back cover of your VoiceTab. Remove the back cover plate to view the service tag, located near the SIM and memory card slots.
Figure : VoiceTab service tag location
HP 7 Tablet
The product number is located on a label on the back of your tablet.
Figure : HP 7 product number location
HP 7.1, HP 7 Plus, and HP 8 Tablets
The model number and product number are located on the back of the tablet, near the bottom edge.
Figure : HP 8 tablet model number and product number location
HP ElitePad 900 G1 Tablet
The product number is located on the bottom edge of your tablet.
Figure : ElitePad 900 Tablet product number location
HP Elite x3
The product number is on the back of the phone, in the center and near the bottom.
Figure : HP Elite x3 product number location
HP Omni 10 Tablet
The product number is laser-etched on the bottom edge of your tablet, to the left of the power plug.
Figure : Laser-etched tablet product number (example)
HP Slate 2 Tablet
The label tray is located on the right edge near the power slide button. Pull the label tray out to view the product number label.
Figure : Slate 2 label tray location
Label tray location
Figure : Pulling out the tray
HP Slate 7 Tablet
The product number is laser-etched on the left edge of your tablet.
Figure : Slate 7 Tablet product number location
HP Slate 7 Beats Special Edition Tablet
The model number is located on a label on the back of your tablet, under the Beats Audio logo.
HP Slate 7 Extreme Tablet
The model number is located on a label on the back of your tablet.
Figure : Slate 7 Extreme model number location
HP Slate 7 HD Tablet
The product number is laser-etched on the bottom edge of your tablet.
HP Slate 7 Plus Tablet
Figure : Slate 7 Plus model number location
HP Slate 8 Pro 76xx Tablet
The product number is laser-etched on the bottom edge of your tablet, near the left corner.
HP Slate 8 Pro 78xx Tablet
HP Slate 10 HD Tablet
HP Slate 500 Tablet
Figure : Slate 500 label tray location
Label tray location
