Document ID: c03763066
Version: 1
Advisory: HP Z420, Z620, and Z820 Workstations - Unknown Device Showing in Device Manager with Windows XP
Release date : 14-May-2013
Last updated : 26-Jun-2013
DESCRIPTION
If a user installed Windows XP Operating System on HP Z420, Z620, or Z820 workstation, the Device Manager may show an 'Unknown Device' with Device ID: ACPI\ACPI0004\CPUSCK0 (and CPUSCK1 on dual-CPU systems).
sourceInformation
SCOPE
Systems:
  • HP Z420 Workstation
  • HP Z620 Workstation
  • HP Z820 Workstation
Operating Systems:
  • Microsoft Windows XP Professional Edition
  • Microsoft Windows XP Pro 64-Bit Edition
RESOLUTION
Perform the following procedures to resolve the issue.
NOTE
Use the Arrow keys to select various menus, menu items, and to change values (unless otherwise specified).
  1. Start or restart the computer.
  2. Press the F10 key when the F10=Setup message appears on screen.
  3. Select Advanced > Bus Options > Legacy ACPI CPU Tables > Enabled.
  4. Press the F10 key to accept the change.
  5. Select File > Save Changes and Exit.
  6. Press the Enter key.
  7. Press the Enter key to save the changes and exit the F10 Setup utility.
Hardware platforms affected : HP Z420 Workstation, HP Z620 Workstation, HP Z820 Workstation
Operating systems affected : Microsoft Windows XP Pro 64-Bit Edition Microsoft Windows XP Professional Edition
Support Communication Cross Reference ID : IA03763066
