Document ID: c03737148
Version: 1
HP ProBook Notebook PCs - Cyberlink PowerDVD Will Not Play DVDs
Release date : 16-Apr-2013
Last updated : 16-Apr-2013
DESCRIPTION
Cyberlink PowerDVD cannot play a DVD. The following message appears:
CyberLink PowerDVD cannot play this media file. It may not contain a video stream, its file extension was changed, or the program cannot decode the video stream correctly.
Figure : Error Message
SCOPE
HP ProBook 4340s Notebook
HP ProBook 4341s Notebook PC
HP ProBook 4440s Notebook PC
HP ProBook 4441s Notebook PC
HP ProBook 4540s Notebook PC
HP ProBook 4740s Notebook PC
RESOLUTION
To resolve this issue, follow these steps:
1. Uninstall the IRST driver.
2. Uninstall the Cyberlink PowerDVD and restart the computer.
3. Download and install the following SoftPaq:
Softpaq Description
Release Notes
Download SoftPaq
Intel Rapid Storage Technology Driver
Version: 11.6.5.1006
Revision: A
A more recent version of this software may be available. Check for newer versions at http://www.hp.com/.
4. Restart the computer.
5. Click Start, click Computer, double-click Local Disk (C:), click SWSetup, click APP, click Applications, click CyberLink, click PowerDVD, click PowerDVD.exe, then click Run to install.
6. Restart the computer and play the DVD.
Hardware platforms affected : HP ProBook 4340s Notebook PC, HP ProBook 4341s Notebook PC, HP ProBook 4440s Notebook PC, HP ProBook 4540s Notebook PC, HP ProBook 4740s Notebook PC
Support Communication Cross Reference ID : IA03737148
