HP LaserJet Pro MFP M521 - Use paper output options
Print to the standard output bin
The standard output bin collects paper face-down, in the correct order. Use this bin for most print jobs, including transparencies. To use the standard output bin, be sure that the rear output bin is closed. To avoid jams, do not open or close the rear output bin while the product is printing.
The standard output bin holds up to 250 sheets of 75 g/m2 paper.
Print to the rear output bin
The product always prints to the rear output bin if it is open. Paper that is printed to this bin will exit face-up, with the last page on top (reverse order).
The rear output bin holds up to 50 sheets of 75 g/m2 paper.
Printing from Tray 1 to the rear output bin provides the straightest path. Opening the rear output bin might improve performance with the following items:
  • Envelopes
  • Labels
  • Small custom-size paper
  • Postcards
  • Paper heavier than 120 g/m2 (32 lb)
To open the rear output bin, grasp the handle at the top of the bin. Pull the bin down to a 45° angle, and slide out the extension.
Figure : Location of rear output bin
Opening the rear output bin makes the duplexer and the top output bin unavailable. To avoid jams, do not open or close the rear output bin while the product is printing.
