HP MP4 Digital Signage Player - Specifications
Physical specifications
Feature
Dimensions (W x D x H)
HP MP4 (vertical orientation):
  • Without stand: 22 x 4 x 24 cm (8.7 x 1.6 x 9.4 in)
  • With stand:22 x 4 x 25.1 cm (8.7 x 1.6 x 9.9 in)
HP MP4 (standard chassis):
  • Without stand: 1.49 kg (3.285 lbs)
  • With stand: 1.55 kg (3.417 lbs)
Power specifications
Feature
Power
  • 65 W
  • Worldwide auto-sensing 100-240 V ac, 50-60 Hz
  • Surge-tolerant
Energy consumption1
115 V ac (60Hz)
  • Idle state: 12.17 W
  • Sleep state: 1.46 W
  • Off mode: 0.78 W
230 V ac (50Hz)
  • Idle state: 12.42 W
  • Sleep state: 1.39 W
  • Off mode: 0.88 W
100 V ac (60Hz)
  • Off mode: 0.78 W
Heat dissipation (BTU/hr)
115 V ac (60Hz)
  • Idle state: 41.53
  • Sleep state: 4.98
  • Off mode: 2.66
230 V ac (50Hz)
  • Idle state: 42.38
  • Sleep state: 4.74
  • Off mode: 3.00
100 V ac (60Hz)
  • Idle state: 41.53
  • Sleep state: 4.98
  • Off mode: 2.66
1: These measurements represent HP MP4 with WES 2009, 2 GB Flash and 8 GB RAM installed. Other OS configurations may vary, but do not significantly exceed these measurements.
This product is in compliance with US executive order 13221, WOL (wake on LAN) disabled. Off Mode measurements are made with WOL disabled.
The actual power consumption at your location could vary and is dependent on many factors including but not limited to software load on the player,, attached peripherals, and environmental factors.
2: Heat dissipation is calculated based on the measured watts, assuming the service level is attained for one hour.
Environmental specifications
Feature
Operating temperature range
Standard: 10° to 40° C (50° to 104° F)
Using Quick Release with a flat panel monitor: 10° to 35° C (50° to 95° F)
Non-operating temperature range
-30° to 60° C (-22° to 140° F)
Humidity
Condensing: 20% to 80%
Non-condensing: 10% to 90% non-condensing
Specifications are at sea level with altitude derating of 1° C/300m (1.8° F/1000 ft) to a maximum of 3 Km (10,000 ft), with no direct, sustained sunlight. Upper limit may be limited by the type and number of options installed.
Country: Flag Serbia
