HP ProBook 6570b Notebook PC - Removing and Replacing the RTC Battery
This document pertains only to the HP ProBook 6570b Notebook PC with the following case design:
This document is provided to assist in removing and replacing the RTC battery for the HP ProBook 6570b Notebook PC .
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Tools required
flat-bladed alignment tool
Parts required
The replacement part number will vary depending on the RTC battery that is being replaced. If a part is listed as "Yes" under "Requires Return", then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
RTC battery (includes cable and double-sided tape)
652650-001
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
RTC battery removal instructions
To view a video demonstrating the procedure for removing/replacing the RTC battery, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select RTC battery from the menu on the upper left hand side of the screen.
Review the safety considerations before performing the steps listed below by clicking on the following link:
Failure to comply with the precautions could result in damage to the product or loss of data.
Step
Procedure
Instruction
1
Remove the battery, and bottom cover.
2
Disconnect the RTC battery cable from its connector on the system board.
3
Using a non conductive flat bladed tool, gently pry the RTC battery out of its cradle on the base enclosure and remove.
RTC battery replacement instructions
Step
Procedure
Instruction
1
Place the RTC battery into its cradle on the base enclosure.
2
Press down on the RTC battery to adhere it into place on the base enclosure.
3
Connect the RTC battery cable into its connector on the base enclosure.
Parts return
